#901
Posted 31 October 2012 - 03:20 PM
#902
Posted 31 October 2012 - 03:33 PM
#903
Posted 31 October 2012 - 03:39 PM
#904
Posted 31 October 2012 - 05:07 PM
My battery life is good. I have brightness set to ~30% andy CPU controls to hoptplug/noop, 1G max, 600mhz min. This setup works for all I do and it increased my batter life enough from where it was before. These are just my preferences and what works for me.
Curious as to the benefit of running 600 as minimum clock speed.....
#905
Posted 31 October 2012 - 05:41 PM
So am I...I keep my min at 300; works fine for me.
#906
Posted 01 November 2012 - 02:00 PM
I just havent tried 300, but if the phone still responds to the basic stuff (calls, text), then it should be alright. I will try that now and see if the battery life improves.
#907
Posted 01 November 2012 - 04:09 PM
No problems whatsoever handling basic stuff at 300, for me anyways....
#908
Posted 01 November 2012 - 06:30 PM
Nevermind... I think it is just on Jelly Bean Google now. Also wondering if the leak of Jelly Bean for RAZR hd might lead to something for this ROM... but I know that probably will take some time. These DEV's are way too busy as it is, so don't think I am being pushy, just thinking out loud.
#909
Posted 02 November 2012 - 09:34 AM
#910
Posted 02 November 2012 - 12:57 PM
#911
Posted 02 November 2012 - 05:59 PM
#912
Posted 02 November 2012 - 06:27 PM
I'm glad that worked for you, but I installed everything from scratch no back up whatsoeverJosh I had the same problem. I flashed the rom, booted fine, but could never boot again after setting up my phone. Turns out restoring my apps using Titanium was messing with the rom. Flashed again and set up apps and passwords manually and haven't ever had a boot problem since. Not sure if this is relevant, but it it what worked for me.
#913
Posted 03 November 2012 - 01:52 AM
#914
Posted 03 November 2012 - 04:30 AM
#915
Posted 03 November 2012 - 05:51 AM
#916
Posted 03 November 2012 - 05:59 AM
#917
Posted 03 November 2012 - 07:42 AM
#918
Posted 03 November 2012 - 09:39 AM
#919
Posted 04 November 2012 - 10:28 AM
#920
Posted 04 November 2012 - 06:23 PM
