1073 replies to this topic
#721 slwest78
slwest78
    TEAM RAGE!!
  • 141 posts
  • LocationAlabama-ROLL TIDE!
  • Current Device(s):Droid Razr Maxx-Asus Transformer TF700
Posted 04 October 2012 - 07:50 AM
I'm new here and I love this rom but the only thing that I would like to have is the stock motorola music app with the internet radio and to get the you tube update error fixed. Other than that awesome rom. Is there any way to get those 2 things.
#722 Shinare
Shinare
  • 235 posts
Posted 04 October 2012 - 07:53 AM
If you use Titanium Backup to uninstall both Youtube and Youtube authenticator, then boot into SS recovery and clear cache and reboot then install from play store your youtube troubles will be over. At least this is what I did and now my youtube is fine.
#723 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 04 October 2012 - 01:09 PM
Even simpler than that, just delete the app, reboot, & install from market.
#724 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 04 October 2012 - 05:02 PM
Love the battery life with my MAXX.
  64.55KB   17 downloads
Sent from my Droid RAZR running Droid HD v1.1 via Tapatalk.
#725 210droid
210droid
  • 16 posts
  • Locationsan Antonio
Posted 04 October 2012 - 05:12 PM
saw this ROM quite a while ago.. but totally forgot about it.
question 1: Which link do i download first??
Download:
Droid HD Soft Keys/Original
------ Droid_HD_xt912_1.00.zip
Droid HD Hard Keys/ Non soft
OR
for
(Droid_HD_xt912_1.1 zip)
reason I ask..because OP states.....
Matt-
Updated always, the links for downloading, use these first! <<<<??????
Much appreciated ;)
#726 slwest78
slwest78
    TEAM RAGE!!
  • 141 posts
Posted 05 October 2012 - 06:15 AM
Download:
OR
for
Matt-
Much appreciated ;)
You only use 1 download link. Depending on which one you want. The soft key download has the on screen keys and your hard keys won't work and the hard key download it work normally.
#727 moksha51
moksha51
  • 144 posts
  • LocationBoston, MA
Posted 05 October 2012 - 07:01 AM
Motorola Smart Car Dock
works! Thanks.
#728 anderson620
anderson620
  • 18 posts
  • Twitter:anderson620
  • Google+:anderson620
  • LocationNebraska
Posted 05 October 2012 - 10:25 AM
Sorry if this has been mentioned: everything works just fine, including Google Now. My problem is that if I use Now to search for something the links that it pulls up in the browser aren't "clickable". It's like I can see the search results but cannot open any of the links...anyone? Thanks.
#729 Shinare
Shinare
  • 235 posts
Posted 05 October 2012 - 10:34 AM
When this happens to me I just click on the little "magnifying glass" to the right of the link which shows a "preview" type of thing. Then click on the preview thing and it will take you there.
Edit: Not sure if that is a problem with the ROM or with goggle now not running on JB in general.
  • anderson620 likes this
#730 anderson620
anderson620
  • 18 posts
  • LocationNebraska
Posted 05 October 2012 - 10:45 AM
Thanks for the quick reply. I'll try that.
#731 edge317
edge317
  • 55 posts
Posted 05 October 2012 - 01:01 PM
I don't think Google now is a gimmick at all. It's meant to be functional, not a personal assistant like Siri. Sure, certain questions will get you a voice response answer, but it can do a lot more than that and it learns form your use of it. The implementation in this ROM (and any ICS ROM) is from a hack that allows it to be used on ICS. It's written for JB. Your problem with opening links is due to this. Right now, the only way to use the general search function is to press the little magnifying glass to the right of the actual link, this will bring up page preview mode, you can then scroll thru the pages (left - right) and click the page you want to open. The Google Now experience is much more complete on a true JB ROM, but I am glad that the Devs included it in this one.
This was answered
#732 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 05 October 2012 - 01:04 PM
This was answered
Not sure I understand your comment/point?
#733 johnnysyeah
johnnysyeah
  • 59 posts
Posted 05 October 2012 - 01:18 PM
At work right now. Just downloaded and installed this rom. Gotta say it is awesomely fast!
The only thing I would like to change is to get rid of the Google search bar on the main home screen. Anyone know if that is possible?
#734 Nubia1
Nubia1
    JUST A COOL OLD GUY WHO LIKES ANDROID
  • 270 posts
  • LocationCincinnati,Ohio
  • Current Device(s):DROID RAZR MAXX HD/ OG RAZR MAXX
Posted 05 October 2012 - 02:29 PM
Yes download "root tools" app from the market /Google play store. You want to find the Google search app in the list and simply remove it and go back to the home screen and the search bar will be no more. I. Find the screen to look much nicer without that bar at the top..
#735 johnnysyeah
johnnysyeah
  • 59 posts
Posted 05 October 2012 - 02:49 PM
Do you know the exact name? I can't seem to find it.
#736 johnnysyeah
johnnysyeah
  • 59 posts
Posted 05 October 2012 - 03:07 PM
Got it! Velvet.apk
Thanks!
#737 slwest78
slwest78
    TEAM RAGE!!
  • 141 posts
Posted 05 October 2012 - 03:14 PM
In this rom could we get the notification toggles changed to some other toggles that we can use that's not in the quick settings to the left, like brightness adjustment And mobile hotspot Etc. Can you do something about that keyboard icon that pops up in the notification bar everytime the keyboard comes up. I've went into the configuration settings and turned them all on and it still comes up and i've turned all of them off which stops it for a little while but starts popping back up again. Thanks
#738 dubsx
dubsx
  • 400 posts
  • Twitter:dubs_x
  • LocationThe OH
Posted 05 October 2012 - 04:31 PM
download either Nova launcher or Apex launcher...both good home replacements
#739 ringlord
ringlord
  • LocationKingston, Ontario
Posted 05 October 2012 - 04:35 PM
Anyone have any issues with chrome constantly closing without notice? I uninstalled it, cleared cache and reinstalled. Opens fine but closes after a period of time, which is less than a min.
#740 edge317
edge317
  • 55 posts
Posted 06 October 2012 - 04:20 AM
In response to to the google now comments 2-3 posts above mine ;)
17 user(s) are reading this topic
0 members, 17 guests, 0 anonymous users
