1073 replies to this topic
#661 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 29 September 2012 - 11:03 PM
Nothing special. It is just normal use. I add nothing to my rom.
#662 pm1066
pm1066
  • Validating
  • 140 posts
Posted 30 September 2012 - 03:13 AM
Anything special you did to have amazing battery life on both non soft versions my percentages on battery seems to drop 10% every hour
Realistically, nobody has had this ROM loaded long enough to tell. Have you tried cpu sleeper or using the built in CPU throttle?
#663 ryan8r
ryan8r
  • 37 posts
  • Twitter:@ryan8r
  • LocationBeyond the Grave..
Posted 30 September 2012 - 05:18 AM
I manage 0% drops for upto 4 hours with sync enabled on 3G
Sent from my Droid Razr using Tapatalk 2
#664 matther22xdroid
matther22xdroid
  • LocationIndiana
Posted 30 September 2012 - 05:38 AM
I did a data wipe/factory reset but next time I will be sure to back up my nova launcher first so I dont have to place everything again where and how I had it. ROM is awesome by the way!
Droid Razr Rooted Running Droid Hd 1.02 + Nexus 7 16gb Rooted, unlocked, stock rom, OC'd to 1.7ghz.
#665 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 30 September 2012 - 05:51 AM
How is that possible 0% battery drops after 4 hours of sync.
#666 cliffnelson
cliffnelson
  • 94 posts
Posted 30 September 2012 - 06:15 AM
Would somebody be kind enough to post the download link for this new rom? I have looked but cant find where kebob posted it
#667 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 30 September 2012 - 06:17 AM
Links are in the OP. Have to pick between soft keys and no soft keys.
Sent from my Droid Razr Maxx Arctic HD
#668 Oaklands
Oaklands
  • 312 posts
Posted 30 September 2012 - 06:20 AM
He didn't say battery. Believe he was referring to data drops.
Sent from my AT100 using Tapatalk 2
#669 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 30 September 2012 - 06:27 AM
My bad :D
#670 cliffnelson
cliffnelson
  • 94 posts
Posted 30 September 2012 - 08:11 AM
Sorry. I thought the OP were older versions. Didnt know that he updated the OP with the current versions. Thanks for the help though
#671 midas
midas
  • 40 posts
Posted 30 September 2012 - 09:21 AM
Just installed the non-soft version yesterday. Very well done. Only issue I'm having is I can't update YouTube. No big deal, the installed version still works.
#672 Torin_93
Torin_93
  • 137 posts
Posted 30 September 2012 - 09:46 AM
Is there a changelog somewhere?
#673 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 30 September 2012 - 12:52 PM
Has anyone else noticed that Google Now sometimes seems to be very slow in responding to key presses? Sometimes it even freezes my phone up and I have to wait until my phone states Google Now isn't responding and whether or not I wish to wait or end the process.
#674 johnny5126
johnny5126
  • 8 posts
Posted 30 September 2012 - 01:19 PM
Am I the only one here with a problem installing this ROM and the Artic HD version as well? I did a data wipe, cache wip, and Davlik wipe, install the ROM in Safestrap 2.11, and at the boot screen (droid eye) it immediately reboots and keeps doing so. The same happens with the Arctic version as well. Im installing this over the .215 leak.
#675 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 30 September 2012 - 01:28 PM
I uninstalled YouTube and the Authenticator with but when I try to install through the store I get that the phone isn't compatible with that app.
Did you reboot first before you tried to reinstall it? Using TB, I unistalled both system apps, rebooted, and then reinstalled youtube from the Play Store with no issues.
#676 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 30 September 2012 - 01:30 PM
Personally, I'm not a big fan of Google Now. I replaced it with the stock google search and am much happier.
Did you also format /system before you tried to flash it? I had 0 issues during install, just follow the instructions in the OP. It could also be a bad download.
#677 johnny5126
johnny5126
  • 8 posts
Posted 30 September 2012 - 01:36 PM
Yes, reformatted /system. Plus both the Arctic and Droid HD ROM did the same thing, so I doubt its a bad download.
#678 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 30 September 2012 - 01:40 PM
That's strange! Not sure what to tell you as I'm also running Droid HD 1.1 HK over the 215 kernel. Hope you figure it out, great rom!
#679 midas
midas
  • 40 posts
Posted 30 September 2012 - 02:06 PM
Thanks, I didn't reboot before trying to reinstall. That worked.
#680 AscensionX
AscensionX
    Code Breaker
  • 363 posts
  • Current Device(s):Motorola Droid Razr Maxx, Droid Razr Maxx HD, Nexus 7, Samsung Galaxy SIII
Posted 30 September 2012 - 02:29 PM
Just installed the update for the non-soft version last night and wow! This rom is tight! Fast, fluid and it just looks great! Major props to kebob & mattlgroff for an amazing job on this one. There are a lot of options out as far as roms go but this one just nails it! Keep up the great work guys!
