1073 replies to this topic
#641 bluex
bluex
  • 98 posts
Posted 29 September 2012 - 03:50 AM
Its quite Great
Yay! Thanks a ton for the update!
#642 cliffnelson
cliffnelson
  • 94 posts
Posted 29 September 2012 - 05:16 AM
I am on 1.1 Soft and i just checked for an update and dont see one. :(
#643 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 29 September 2012 - 05:41 AM
Update is for non soft key version
maxx
#644 cygnusloop
cygnusloop
Posted 29 September 2012 - 06:00 AM
Woo Hoo. Downloading 1.1_HK from crackflasher now! Safe to assume that I can flash over 1.1 soft with only cache/dalvic?
#645 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 29 September 2012 - 06:23 AM
Never assume, but yeah, I just dirty flashed it and everything
works great. Data on first boot too
maxx
#646 matther22xdroid
matther22xdroid
  • LocationIndiana
Posted 29 September 2012 - 07:14 AM
1.1 is the soft update you already got your update. The dev is just now rolling out the nonsoft update.
Droid Razr Rooted Running Droid Hd 1.02 + Nexus 7 16gb Rooted, unlocked, stock rom, OC'd to 1.7ghz.
#647 Stabone
Stabone
  • 109 posts
  • LocationNew England
Posted 29 September 2012 - 07:53 AM
I uninstalled YouTube and the Authenticator with but when I try to install through the store I get that the phone isn't compatible with that app.
#648 Shinare
Shinare
  • 235 posts
Posted 29 September 2012 - 07:54 AM
I started download of update and left it. When I remembered it was ready I forgot what it told me to wipe. Data or cache?
#649 pm1066
pm1066
  • Validating
  • 140 posts
Posted 29 September 2012 - 08:22 AM
Well, you have to have a launcher in / system for the phone to work.....
Of course you do. The Stock Moto launcher serves that purpose. Adding a second third party launcher as a system app isn't necessary at all, nor is making Apollo a system app necessary. That was my point--it would be nice to have some flexibility built in versus having to delete or disable baked in third party apps the vast, vast majority of users may have another preference for.
Just a suggestion. It's simple enough to remove these things.
The Youtube issue is bugging me though. And yes, I've gotten rid of the authenticator, still get the error.
#650 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 29 September 2012 - 08:46 AM
If you are coming from a version of HD rom below 1.1 then you are REQUIRED to wipe Data then jsut flash
  • PillClinton likes this
#651 pm1066
pm1066
  • Validating
  • 140 posts
Posted 29 September 2012 - 09:10 AM
What does it take to get motocast working? Can't get past the id step.
#652 crbdenver
crbdenver
  • 30 posts
  • Twitter:ChuckBanning
Posted 29 September 2012 - 09:12 AM
Downloaded the update, thanks! Can't open the default homescreen though, only can use go launcher, anything I can do to get it back?
#653 Kebob
Kebob
    Dev
  • 246 posts
Posted 29 September 2012 - 10:30 AM
Hmm let me guess you didnt wipe data as you are suppose to and as it is stated...... that should fix the problem as the launcher is not a system app so a data wipe is required
#654 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 29 September 2012 - 10:35 AM
Thanks for the update on the non-softkey version. Just finished installing, setting up now. I'll share any feedback after I have time to test it out.
I wiped data, cache/Dalvik & formatted system. Had no issues w/ default homescreen. It popped right up w/ the Circles widget, quick settings, etc.
#655 crbdenver
crbdenver
  • 30 posts
Posted 29 September 2012 - 11:25 AM
Yep, that'd be it. Didn't realize had to do that as it was an upgrade. My bad, but thanks though. So I can still just install the update like a normal flash rom?
#656 cliffnelson
cliffnelson
  • 94 posts
Posted 29 September 2012 - 01:39 PM
So i am on soft 1.1 i would like to switch over to the hard key version. Kebob said that if you are below 1.1 then you need to wipe, so since im on 1.1 i assume i dont need to wipe. So to easily switch over to the hard key version sounds like i need to download to. Zip and flash just like normal. I might do a wipe just to be safe. Where is the download for the new hard key version? I must have missed where it was posted.
Also, kebob. In future updates, what will you be adding feature wise ?
One more thing . I cant seem to redownload the music that i bought from the play store. It usually would say purchased but nothing that i have bought music wise shows up.
#657 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 29 September 2012 - 02:16 PM
Try clearing the play store data and cache. That usually fixes the issue for me.
If we question our own actions, our thought process, make a conscious decision to what we feel is right every single day, that's what I believe to be Divinity. That's true Shamanism.
#658 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 29 September 2012 - 03:24 PM
how's the battery ife with the new update :)
#659 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 29 September 2012 - 04:59 PM
Amazing! :)
#660 SUPERSPORT25
SUPERSPORT25
  • 25 posts
  • LocationTampa, Florida
  • Current Device(s):Samsung Galaxy 4S
Posted 29 September 2012 - 06:56 PM
Anything special you did to have amazing battery life on both non soft versions my percentages on battery seems to drop 10% every hour
