1073 replies to this topic
#621 Shinare
Shinare
  • 235 posts
Posted 27 September 2012 - 05:22 AM
Ok everyone lol im back! And i managed my way out of that toilet that matt was speaking of......... its called school. Lol anyways i should be getting some work time on these roms this weekend so expect the long awaited update then
Got nonsoft 1.02 back on my phone and eagerly awaiting!!! WOOHOO!!!
#622 SUPERSPORT25
SUPERSPORT25
  • 25 posts
  • LocationTampa, Florida
  • Current Device(s):Samsung Galaxy 4S
Posted 27 September 2012 - 10:33 AM
I've noticed this on arctic 2.2 as well. Is this just a kernel feature? Similar to my incredible that would turn the led green (done) at 90% on aosp roms? Regardless on both phones it did continue to fully charge even if it says "charged" at 95%. Because its always 100% when I wake-up after charging all night
I tried the 1.1 soft key ROM first and it charged fine and matter of fact it stayed at 100% for awhile after unplugging it from the charger so I dont know. I cant wait for the update on the non soft ROM it would complete me lol
#623 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 27 September 2012 - 02:14 PM
I had the same issue. The fix that worked for me is to download the simplex rom and using a root explorer go into the simplex rom zip under system/app copy welcomewebtop.apk and copy it to system/app edit the permissions to r-w-r-r then install it. Then reboot into safestrap and wipe cache and delvik cache and reboot. Worked for me.
Thanks for the tip. I did what you stated. Unfortunately, it didn't stop the messages. They don't appear as frequently but it still happens.
Anyone know if hdmi is supposed to even work under this rom?
Sent from my Droid RAZR running Droid HD v1.1 via Tapatalk.
#624 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 27 September 2012 - 02:19 PM
i'll pay closer attention at the next charge, but i think on my phone it's still dropping to 99% immediately on unplugging (v1.1 soft-key)
  • drewski11 likes this
#625 Torito
Torito
  • 9 posts
Posted 27 September 2012 - 02:27 PM
Anyone else having issues updating the YouTube app that was released yesterday?
#626 subzero2000
subzero2000
  • 46 posts
Posted 27 September 2012 - 02:37 PM
Yep, getting the following message when I try to update during the installation phase after it downloads it:
Edit: I'm on 1.02 NonSoft if that makes any difference. I did update the Google Play store apk to 3.8.17 under /system/app because it wouldn't update the Google Play store from what was in the ROM originally (3.5.15, I think). Not sure if that makes any difference or not.
Edit: Also, I have no updates to YouTube installed, it's just the system apk, so following those directions would be a little difficult (well, I could remove the APK from /system/app, but I doubt you'd have to do that on a stock ROM ... :) )
#627 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 27 September 2012 - 02:42 PM
Same error here. I saw a post that said uninstall with TiBu, reboot then it will install from the store. Have not tried it yet
#628 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 27 September 2012 - 02:51 PM
FWIW, I got the same error, uninstalled with Rom Toolbox pro, re-downloaded from the Play store and installed without reboot and it worked fine.
Sent from my RAZR MAXX using Tapatalk 2
#629 drewski11
drewski11
  • 186 posts
Posted 27 September 2012 - 05:09 PM
i also had to uninstall "YouTube Authenticator" app with TiBU before I could install the new version.
#630 carracerz14
carracerz14
  • 119 posts
Posted 27 September 2012 - 05:17 PM
I wish they would stop including these apps as system apps. It's annoying to have to uninstall with titanium then restart just to update
Sent from my RAZR MAXXIMUS ;)
#631 pm1066
pm1066
  • Validating
  • 140 posts
Posted 28 September 2012 - 03:24 AM
This. Though YouTube isn't really that bad an idea. Apollo was the biggest PITA because it kept starting anytime I took my headphones out. Did I really need Emimem blaring over the speakers as soon as I unplugged?
Some apps it makes sense, but music players and home screen launchers are probably two of the most personalized choices people make on these phones. Making them system apps presupposes everybody loves YOUR launcher and music player, which automatically makes you wrong.
There was a dude back in the Droid X days who built in a utility to his ROMs allowing you to make system level changes easily, like keyboards, launchers, gallery, etc. Be nice to see that sort of utility included in this generation.
#632 edge317
edge317
  • 55 posts
Posted 28 September 2012 - 04:10 AM
Dang... I gotta +1 this. Not that I enjoy looking a gift horse in the mouth.
#633 B.L.E.A.K
B.L.E.A.K
  • 64 posts
Posted 28 September 2012 - 06:16 AM
Any way to disable to the search bar? The disable option is grey.
Sent from my RaZr HD.
#634 Torito
Torito
  • 9 posts
Posted 28 September 2012 - 07:49 AM
Yup, this works. Took me forever to figure it out.
#635 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 28 September 2012 - 06:56 PM
Well, you have to have a launcher in / system for the phone to work.....
maxx
#636 SUPERSPORT25
SUPERSPORT25
  • 25 posts
Posted 28 September 2012 - 08:07 PM
Just got the update for non soft.....preparing to download now so excited.
#637 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 28 September 2012 - 08:11 PM
Its quite Great :D
#638 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 28 September 2012 - 08:39 PM
Cool, thanks! I'm downloading it right now. This rom has been great!
Update: I had my phone plugged in while updating and upon first boot I had no data (as expected), so I tried to reboot, but my power button and hard keys aren't working. I'm waiting for my phone to die, so that I can reboot it and see if all is well. It's times like these where great battery life sucks.
#639 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 28 September 2012 - 09:21 PM
Hey so youtube is not working. When i donwload the update it says youtube was not signed correctly. Whats going on?
#640 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 28 September 2012 - 10:30 PM
Scroll up...
