1073 replies to this topic
#581 carracerz14
carracerz14
  • 119 posts
Posted 22 September 2012 - 05:38 PM
Someone else earlier in the thread had that same problem. I can't remember what they did but it was probably a complete wipe and and reflash.
he's wiped and re flashed probably about 3 times
Sent from my RAZR MAXXIMUS ;)
#582 nsaechao
nsaechao
  • 48 posts
Posted 22 September 2012 - 06:06 PM
Why do i keep getting this after flashing this ROM?
Would the fact that I have a limited edition Razr Maxx?
just pick one as your default launcher. Look like you two moto launcherBy chance did you restore your phone with backup?
#583 shadowwar99
shadowwar99
  • 7 posts
Posted 23 September 2012 - 08:12 AM
Any word on the nonsoft update yet???
#584 Razr1221
Razr1221
  • 43 posts
Posted 23 September 2012 - 03:23 PM
I check everyday for the non softkeys update,with no luck of course :*(
#585 edge317
edge317
  • 55 posts
Posted 23 September 2012 - 05:26 PM
I actually had a dream it was done... woke up checked...no lol. Ugh I need a life. Anyways, I'm almost concerned now. Matt, kebob you guys alright??
#586 tsdy008
tsdy008
Posted 23 September 2012 - 07:43 PM
Its obviously been so long you forgot how to read as it clearly states in the install and in the OP that you must reboot for those issues to be fixed. No big deal though as we all make mistakes :) I will have a non softkey out soon enough to satisfy your other needs
K大你好,我昨日在XT912上用Bootmenu安装了DROID HD 1.02(第二分区),自己修改了build和setting.db,顺利实现了中国电信3G网络。初步体验很不错,但是有个问题想请教一下:请问如何去除主屏幕最上方的google search插件?
另外,能否加入重启的选项?电源键只有一个power off,没有reboot很不方便啊
#587 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 23 September 2012 - 08:15 PM
I got these results on this rom over the weekend with moderate use. I am (needless to say) very impressed. For those of you frightened of underclocking, I have mine underclocked to 800Mhz and I haven't noticed any difference at all. I'm sure I might notice a difference if I played games and stuff, but for general usage I haven't noticed anything different except better battery life. I also use Llama instead of Smartactions, and have found it to have better functionality. Under heavier usage, I consistently get 18-19 hours per charge.
in case you're wondering: OG Razr (not Maxx!), Droid HD nonsoft
Edit: I also use cpu sleeper. (I'm not entirely sure this is necessary when using hotplugx)
Edit 2: I have the radio set to GSM/cdma auto (PRL) for 3g only. When I'm not on wifi, 3g is plenty fast for me.
GPosted ImagePosted Image
#588 robthefive0
robthefive0
    Sarge
  • 315 posts
  • LocationN.J.
Posted 24 September 2012 - 02:30 AM
I totally agree! :huh:
  • DarkOverDroid likes this
#589 webeougher
webeougher
  • 44 posts
  • Twitter:webeougher
  • Google+:webeougher
Posted 24 September 2012 - 05:02 AM
In the settings menu, look for "Launcher settings" and there will be an option that says something like "Google Search - Persistent" - uncheck the box and it will remove the Google Search box (as best I can tell, that was your first question). As for the second part, there is no reboot option in this ROM. You'll have to stick with powering off and then powering back on.
在设置菜单中,寻找“启动设置”,会有一个选项,上面写着类似“谷歌搜索 - 持久性” - 取消选中该框,它会删除谷歌搜索框(最好的,我可以告诉,这是你的第一个问题)。至于第二部分,在这个ROM有没有重新启动选项。坚持使用,你必须关闭电源,然后供电的。
(My apologies if the Chinese translation isn't up to snuff - I used Google translate to translate your message and then to translate mine back into Chinese.)
#590 edge317
edge317
  • 55 posts
Posted 24 September 2012 - 07:17 AM
Impressive. I couldn't help but notice that both your screenshots show 3g not 4g. Are u not in a 4g area? That would make a huge difference right there cuz 4g sucks the battery harder.
#591 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 24 September 2012 - 08:23 AM
Yes, I forgot to mention that. I have my radio set to GSM/cdma auto (prl). The 3g is already pretty fast in my area and feel that the cost/benefit of 4g isn't worth it. I'm on wifi most of the time anyway. I get a very strong 4g signal, though.
#592 edge317
edge317
  • 55 posts
Posted 24 September 2012 - 09:47 AM
I tend to agree... when I was on gingerbread my 4g was so wonky I turned it off. With the exception of downloading files or market app updates, 3g is plenty fast for everyday use. Honestly if I didn't have this maxx battery I still wouldn't be using 4g. The competition really needs to step up the battery size on 4g phones. Of course wifi is far superior and is a big reason your phone made it through a whole day plus some. But these stats seem pretty genuine. Your screen use is a tad low I'm usually more in the 60%+ range but your cell standby is low and u even have some Google maps use. That was definitely moderate use so not too shabby. If your happy with 800mhz I guess that's great but most people don't usually need an ACTUAL 24 hours if they charge at night.
#593 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
Posted 24 September 2012 - 09:57 AM
You should try 800 Mhz and let me know if you notice any difference in usability.
#594 Shinare
Shinare
  • 235 posts
Posted 24 September 2012 - 12:51 PM
I can probably guess that I'm the only one in this boat since I have not read a word about it in this thread, but here goes:
Anyone else having an issue where there seems like theres a fantom finger pressing somewhere on you rscreen when you are trying to do something?
Every now and then, when typing a text message its particularly noticable, but even just messing around on the home screens sometimes its almost like there is a fantom finger pressing somewhere on the upper right side of my screen... is this a software issue or is my touch-screen whacked? If the later, can I flash back to stock and take it into VZW store for replacement?
#595 Razr1221
Razr1221
  • 43 posts
hey do any of you guys are not able to sync your Hotmail email and calender with this Rom ????
#596 Razr1221
Razr1221
  • 43 posts
Posted 24 September 2012 - 12:56 PM
Maybe something Paranormal is happening at your house
#597 pm1066
pm1066
  • Validating
  • 140 posts
Posted 24 September 2012 - 01:05 PM
I started getting skipping during music playback 1.0 GHz. Nothing else was active. May explain why this phone is such a battery hog during playback.
#598 Shinare
Shinare
  • 235 posts
Posted 24 September 2012 - 01:23 PM
LOL they/it must be following me around then, heh.
#599 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 24 September 2012 - 01:54 PM
What's Hotmail?
maxx
#600 edge317
edge317
  • 55 posts
Posted 24 September 2012 - 03:29 PM
What's Hotmail?
Lol^^
Edit: Just in case your serious its Microsoft's email
