#501
Posted 19 September 2012 - 11:09 AM
#502
Posted 19 September 2012 - 11:40 AM
Hi all, been a while. Tried this rom out. Flashed it on my way to school. I got no data link and when on wifi. Google account would not get past, this will take a few minutes. I gave it 15 and had to stop it as I needed my phone. Not a fan of the new on screen buttons.
I'm not immediately sure what the problem is but, I do know it isn't the rom. This rom has no data issues. Did you try a reboot to see if that brings it to life?
#503
Posted 19 September 2012 - 12:23 PM
Wipe... Flash.. Reboot.. After the phone reboot.. Reboot it again let it sit for a minute til the 4g signal to light up (blue) then set up the phone... If ur not a fan of the soft key there's an version w/o the soft key
#504
Posted 19 September 2012 - 01:48 PM
- Thach and larrydp like this
#505
Posted 19 September 2012 - 02:31 PM
Its obviously been so long you forgot how to read as it clearly states in the install and in the OP that you must reboot for those issues to be fixed. No big deal though as we all make mistakes I will have a non softkey out soon enough to satisfy your other needs
A little annoyed this evening, are we? Lol I was trying to be nice!
Sent from meh MAXX. That is all.
#506
Posted 19 September 2012 - 03:20 PM
I don't blame Kebob. Majority is ppl not reading the OP and start clogging the thread with all these issues again and again. Maybe I'm just lucky in flashing cause I have not experience most of the issue ppl are repeatedly reporting.
Here Kebob and Matt took their time out of their busy schedule and put aside their life to put this together this wonderful Rom for ppl to enjoy and appreciate .... and some ppl have a different way of appreciation
... I for one am really great-full for Matt and Kebob AND all the wonderful Devs out there showing support to the DROID community making Droid Phone an addiction
so once again Thank You Kebob and Matt.
- c_live_lee likes this
#507
Posted 19 September 2012 - 03:30 PM
#508
Posted 19 September 2012 - 03:38 PM
Thanks for the ROM, and thanks equally for clear concise directions to safely install.
#509
Posted 19 September 2012 - 03:49 PM
You said it.
#510
Posted 19 September 2012 - 05:31 PM
#511
Posted 19 September 2012 - 05:36 PM
It may have been a long time. But no reason to get disrespectful. I did wiped 2 times before I installed. I used matts one wipe to rule them all and did it manually. Phone sat a bit as I was in class and to let the rom settle. Not all phone work the same or take them roms well. I am not a rookie.
USMC4LIFE
#512
Posted 19 September 2012 - 05:42 PM
USMC4LIFE
I think what he was saying is that after you flash the rom and it boots up, you have to reboot the phone again to fix the data issue.
Sent from my Droid RAZR running Droid HD 1.1
- JoeProcopio likes this
#513
Posted 19 September 2012 - 05:57 PM
Yup. Just installed here and followed the OP. Rebooted right after first boot then set up phone. No data issues here
Also like to say thanks for this great rom. I am getting used to and coming to like the soft keys even though I thought I would hate them. Also my first venture into Google now and having fun playing with it.
Edit... I am gonna update the rom when I get home and get on wifi. Any special instructions? I see I have to install in safe strap but do I need to wipe anything??
#514
Posted 19 September 2012 - 06:09 PM
Anybody know what it would take to get any of the following working again in this ROM?:
1) Motorola Dock modes (both for Car Dock and HD Dock).
2) Visual Voicemail (I'm aware of alternatives; I like Visual Voicemail and would prefer to keep using it).
3) Motorola Music Player - I'm willing to give Apollo a shot, as it looks nice, but doesn't seem to have a landscape mode when in a car dock. If someone could make that work, I'd be willing to keep evaluating Apollo.
Devs, don't get me wrong, I think this ROM is by far what Motorola / Verizon should have shipped for ICS in the first place. The items I mentioned above would simply be icing on the cake for me.
Just thought I'd follow up on my previous post by adding that my issues with all of the apps that I mentioned above are now working for me on Droid HD 1.0.2 NonSoft by having extracted the following APKs from the deodexed 6.16.215 base and putting them in the /system/app folder:
MotMusic.apk (My Music)
SmartCarDock.apk (Car Dock Application)
SmartDock (Multimedia/HD Dock Application)
Vvm.apk (Visual Voicemail)
Also, NFL Mobile and My Verizon can be made to work by replacing VerizonSSOEngine.apk in /system/app. I know somebody posted a link to one via DropBox, but I just extracted mine from the deodexed 6.16.215 base, and it allows those apps to work just fine.
#515
Posted 19 September 2012 - 06:18 PM
Thanks again Matt and Kebob for an awesome ROM. I'm patiently waiting for the next non-soft version of the ROM. I don't think I've seen anyone say why they do or don't like soft keys or not, so I thought I'd chime in with my two cents worth. My biggest gripe against soft keys is the screen real estate lost when there are keys at the bottom that do this already. If the RAZR MAXX had soft keys to begin with, I'd have no gripe about using soft keys in the first place ...
#516
Posted 19 September 2012 - 06:22 PM
Thanks again for a great ROM, Matt and Kebob.
#517
Posted 19 September 2012 - 06:31 PM
Check out PowerAmp. It has landscape and looks great in my car dock. I bought it years ago and never glanced twice at another music player
#518
Posted 19 September 2012 - 06:45 PM
#519
Posted 19 September 2012 - 06:47 PM
#520
Posted 19 September 2012 - 07:00 PM
+1 to Power Amp
