1073 replies to this topic
#481 nsaechao
nsaechao
  • 48 posts
Posted 18 September 2012 - 09:21 PM
Does anyone know if webtop is supposed to work with this rom? I tried it on my lapdock
And it partially works but system ui keeps FCing. Is there a fix for this?
Try extracting welcomewebtop. Apk from an other rom and replace it in the system /app of this rom. In system app.... Set the permission and install. Reboot to ss and wipe cache and reboot
#482 nsaechao
nsaechao
  • 48 posts
Posted 18 September 2012 - 09:58 PM
After uninstalling Gmail with TB and going to the Play Store to install the newest version, I get an "Incompatible update" error. Is there any way around this?
try going to manage app ...located gmail clear data and cache- go to system /app and delete it from there or rename Gmail.apk to Gmail.bak- reboot to ss and wipe cache- reboot the phone go to market and download the newer versionwhile trying this if you going to update Gmail if you happen to also want update the street view- do the same thing to kill two bird with one stone
#483 yuri2008112073
yuri2008112073
Posted 19 September 2012 - 01:29 AM
looks good!thank you very much!
#484 hackersnu
hackersnu
  • 12 posts
Posted 19 September 2012 - 01:45 AM
Excellent rom. Thank you.
#485 shadowwar99
shadowwar99
  • 7 posts
Posted 19 September 2012 - 01:58 AM
. I tried that but it doesn't work like I said it partially works the like I said it partially works the HDMI works but web top mode doesn't start
#486 tsdy008
tsdy008
Posted 19 September 2012 - 02:36 AM
ah......i know it's only for verizon,but,do it include the chinese language?because i am a chinese with XT912
mybe my english is poor,sorry,i try my best
#487 zxcvbnm
zxcvbnm
Posted 19 September 2012 - 03:18 AM
支持了·········哈哈 :D
#488 dbslsy
dbslsy
  • 48 posts
Posted 19 September 2012 - 04:20 AM
支持了·········哈哈 :D
Devil'?
#489 nsaechao
nsaechao
  • 48 posts
Posted 19 September 2012 - 04:37 AM
Not sure why it didn't work. It work for me and one other person and was posted here a few post back now. Replace. Set permission.. Install... Boot to recovery.. Wipe cache and dalvik and rebooted. I tried ..... hope u get urs to work
#490 shadowwar99
shadowwar99
  • 7 posts
Posted 19 September 2012 - 04:45 AM
what do you mean by set permission? Also what rom did you get the welcomewebtop.apk from?
#491 jasong127
jasong127
  • 25 posts
Posted 19 September 2012 - 05:12 AM
Can the soft keys be turned off? I know there's a ROM w/o them, but development on this one seems to come faster.
#492 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 19 September 2012 - 05:36 AM
You could just pull it from one of the ics leaks as well....just sayin'
Yeah, I know. Was trying to make a point......
Instead of having a pi$$ing match about who said what, how bout throwing that apk up on dropbox so we can all try it?
Not many of us back up system apps with tibu and would not likely have it....
Cheers!
Since this is a SS ROM that requires the .211-.215 base, I would think that most everyone running it has the Smart Actions files on their non-safe side. Why not swap modes, backup the files with Rom Toolbox (or your favorite app), swap back and restore. That worked for me anyway.
#493 Shinare
Shinare
  • 235 posts
Posted 19 September 2012 - 06:35 AM
... Why not swap modes, backup the files with Rom Toolbox (or your favorite app), swap back and restore. That worked for me anyway.
Well what-do-ya-know. I didn't know you could do that. I thought once you went back to un-safe you wiped out your safe side. I thought that was what that warning was all about when you try it (thats why I didnt). I didn't know you could flip-flop back and forth willy-nilly.
#494 sirphobos
sirphobos
Posted 19 September 2012 - 06:37 AM
Not so much faster, but a themed rom just turns me off, which is Arctic.
#495 DroidPS08
DroidPS08
  • 5 posts
  • Google+:https://plus.google.com/103977815629661513510/posts
Posted 19 September 2012 - 07:21 AM
Didn't think that I would like the soft keys but I thought I would give it a shot. Very glad I did. Love the ROM and the soft keys. Keep up the great work and look forward to future updates!
#496 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 19 September 2012 - 07:35 AM
Sure you can do it. Haschode's original intention with SS was for developers to be able to have a stable (non-safe 'to screw with" side) ROM and have the safe side as a place where ROMs could be flashed for testing purposes. The /system of each ROM (non-safe/safe) is not backed up when swapping modes, only the data. This is because he uses the normal /system partition for the non-safe side and the /preinstall partition for the safe side. When you swap modes in recovery, is where the trickery goes on. The recovery mounts the original /system as "systemorig" and mounts /preinstall as /system if you are booting into safe side instead of the normal /system. The data for each is backed up to internal storage when swapping modes and restored according to which mode you are swapping to. This is the one area that some people have trouble with, since there is kinda limited space on the internal emmc, sometimes there isn't enough room for the backup and the swap may fail to in the backup process, that means that when you swap back, there will not be any data to restore. To avoid this, I always make sure there is plenty of room in internal storage and also usually make a manual backup to the external storage when swapping modes, just in case something goes wrong, though I have never had to use it.
I realize that's probably way more information than anyone wanted to read, but I was on a roll. :D
#497 nsaechao
nsaechao
  • 48 posts
Posted 19 September 2012 - 08:35 AM
when you replace it app you will need to set the permission....Set permission to rw-r-r - if you long press on the app a property pops up allowing you to set permission...check the permission on other app in system/app and copy it. -- I extracted mine for simplex because I have that rom in my sd card at that time.
#498 edge317
edge317
  • 55 posts
Posted 19 September 2012 - 09:51 AM
Well since we're already on the subject. I thought the "toggle" option erased your safe side and "quick toggle (dangerous) did not erase the safe side and allowed you to switch back and forth. Is this accurate?
#499 carracerz14
carracerz14
  • 119 posts
Posted 19 September 2012 - 09:53 AM
As far as I know anytime you toggle safe or unsafe it backs up before it does it, and quick toggle doesn't back it up
Sent from my RAZR MAXXIMUS ;)
#500 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 19 September 2012 - 10:42 AM
No, not correct. While the normal toggle does erase the current systems /data, it makes a backup of it first so that it can be restored (automagically) when swapping back to that system.
The "quick toggle" does not backup or restore the /data partition. The same /data would be shared between both sides. This is included so that devs can tweak various things on the safe side without having to waste time with the backup restore process between swaps. It's only useful if the ROMs in both systems are compatible. Thus, the (dangerous) warning.
