1073 replies to this topic
#421 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 16 September 2012 - 02:47 PM
yeah dont worry about it. Also everything seems to be working great according to your observations ;)
#422 AngelRyux
AngelRyux
  • 45 posts
Posted 16 September 2012 - 02:53 PM
NINE POSTS ABOVE YOURS!
On tapatalk and looked nine post above and am not seeing it.. You mean none pages? If so I was waiting for the newer version. If is could u just give me the link? Thanks.
#423 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 16 September 2012 - 03:00 PM
Ah, I always end up forgetting that. I'll update that now.
EDIT: New DL link for it is on OTA Update Center, but will not notifiy you as an update if you are on 1.02 already.
We will be posting this in its own thread "soon"
Here ^^^^
Did i miss a page for the nonsoft keys download or has he still not made it yet?
#424 AngelRyux
AngelRyux
  • 45 posts
Posted 16 September 2012 - 03:03 PM
Oh just have to check ota ok thank you.
#425 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 16 September 2012 - 03:44 PM
Next request. Anyone have an inverted mms app that works with this rom? The ones i have wont work.
Here you go
#426 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 16 September 2012 - 04:01 PM
Here you go
Bingo! Thanks again ;-)
#427 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 16 September 2012 - 04:48 PM
i like having the soft keys i just thought there were normally 4 so was just wondering
menu softkey (3-dots) will pop up on the right, depending on the program. newer programs optimized for ICS/JB will have the settings/menu in the main part of the screen. usually upper-right like you can see in Gmail.
Off the top of my head, a couple of programs that show the 4th softkey are Yelp & GSam Battery Monitor
#428 diasas
diasas
  • 11 posts
Posted 16 September 2012 - 05:08 PM
for 1.1 do I need to do a data wipe or can I just flash over the 1.02. I am just wondering.
#429 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 16 September 2012 - 05:16 PM
Been trying since yesterday to update via the OTA app but it doesn't seem to be working for me. When it finally downloaded the zip a little while ago upon trying to flash it SS aborted with a message it was "unable to open the zip (bad)."
I noticed the app won't DL via 4G connection and WI-FI in my house isn't the best. Any suggestions?
#430 jonwgee
jonwgee
  • 301 posts
  • Twitter:JonWGee
  • Google+:jonwgee
  • LocationDekalb IL
Posted 16 September 2012 - 05:52 PM
Oh yeah--Set CPU (or whatever) keeps whining about unclean shutdowns, so I disabled the safety that allows it to load on boot. I'm assuming that is no big deal...?
Does this happen when you power down and then power up? Or are you using a quick reboot app?
maxx
#431 drewski11
drewski11
  • 186 posts
Posted 16 September 2012 - 06:00 PM
data wipe needed.
the message in OTA says to do it, but i tried a dirty flash anyway (with Cache & Delvik wipe) and got a bunch of FC's.
wiped data and reflashed and am good to go.
#432 drewski11
drewski11
  • 186 posts
Posted 16 September 2012 - 06:05 PM
Here is the paid theme chooser version i offer on market. Its not that extensive yet, but im working on it :)
This will be a free theme i provide only to droidrzr.com
Link to Theme ONLY for Droid_hd_xt912_v1.1
This is just an early preview. i will add more and refine in the coming days/weeks
Screens
i like it! thanks!
the Nav buttons are a bit big for me so flashed the reflective blue soft key mod linked in the OP and, unexpectedly, it also overwrote the blue settings button that shows in Apps, the fade in the wifi icon, & the blue nav menu switch icons back to the regular ROM settings! :(
still retains the non-Blur settings icons. :)
oh well, but non-Dev modders can't be too picky! ;)
#433 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 16 September 2012 - 06:42 PM
i like it! thanks!
I can make the reflective for this theme what size you want. When we developers as a whole build themes and mods we use stock rom
For me to build on this theme will not take long. But remember every update you will lose your mod
  • drewski11 likes this
#434 Mikegold28
Mikegold28
  • 21 posts
Posted 16 September 2012 - 07:30 PM
Does any one have a problem with the phone shuting down on them rendomly with this ROM?
#435 D Stave
D Stave
  • 175 posts
Posted 16 September 2012 - 07:38 PM
Same here, and my wifi is terrific now that I have my new router.
#436 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 16 September 2012 - 07:40 PM
I've not had this happen at all nor heard of anyone else having this issue. At least if they have, its not been reported yet. Is there anything specific that you are doing when it happens?
Sent from my Droid RAZR running Droid HD 1.1
#437 Mikegold28
Mikegold28
  • 21 posts
Posted 16 September 2012 - 07:48 PM
Not that i can think of. Once in a while it just turns off and the only way i can turn it back on is by holding down Power and the Vol. up and down keys. Any ideas?
#438 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 16 September 2012 - 08:01 PM
Part of me thinks a bad download. But then I start wondering if a app may be causing this as well.
Sent from my Motorola Xyboard
#439 Mikegold28
Mikegold28
  • 21 posts
Posted 16 September 2012 - 08:18 PM
Thanks, i think you may be right. I think im going to switch to Arctic. I was reading some of the posts, and am i correct in assuming thats its just like this one but without the soft keys?
#440 Kebob
Kebob
    Dev
  • 246 posts
Posted 16 September 2012 - 09:14 PM
Yes kinda. Its way outdated though. I wasnt able to get to all the updating i wanted to get done this weekend. I will be updating it to 1.11 when i get the chance. If everything runs well it will be like this for awhile. Then i will get a nonsoft done and a Arctic update that will include DSGs theme
