1073 replies to this topic
#361 phatdaddyz01
phatdaddyz01
  • 288 posts
Posted 15 September 2012 - 08:30 AM
Anyone else's built in caller id readout random numbers when you get a call from someone not in your contacts? Mine will read out "four million, six hundred thousand, eight hundred, etc." And its not even close to the number that's calling. Any ideas?
#362 graxall2
graxall2
  • 6 posts
Posted 15 September 2012 - 08:40 AM
I had that issue running the Apex launcher on stock .215. Are you running Apex by chance?
Nope I am not. However, when I flashed, and first rebooted, and hit home, it gave me an option of 2 homescreens?
Homescreen
com.motorola.home
Homescreen
com.motorola.homescreen
Either one I goto, still all the same issues.
Everything that I mentioned as being a possible bad download is weird because it comes bundled with the rom by default.
I used the link from page 8 to download. Re-downloading from matt's devcrackers right now and will reflash and let you guys know.
#363 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 15 September 2012 - 08:47 AM
Yeah this is weird because there are almost 0 differences between the non soft and soft key version. So this sounds like you messed up in flashing or you had a bad DL
#364 bluex
bluex
  • 98 posts
Posted 15 September 2012 - 09:12 AM
Mine does this as well. The only thing I can come up with is the phone is doing the phone number as a mathematical equation an telling you the answer. I find it quite funny. It reads my contacts out fine though....
#365 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 15 September 2012 - 09:20 AM
I need an update for the non softkey version
#366 saycbone
saycbone
  • 68 posts
Just a suggestion as we report any findings to note on the post what version of Droid you are running..build and soft or non soft..
#367 Mr.Rzr
Mr.Rzr
  • 102 posts
  • LocationThe InterWebz
Posted 15 September 2012 - 09:23 AM
so is there only supposed to be 3 soft keys? thought there were usually 4?
#368 carracerz14
carracerz14
  • 119 posts
Posted 15 September 2012 - 09:37 AM
There's always only been 3... And the non soft key one is artic hd
Sent from my RAZR MAXXIMUS ;)
#369 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 15 September 2012 - 09:52 AM
Here is the paid theme chooser version i offer on market. Its not that extensive yet, but im working on it :)
This will be a free theme i provide only to droidrzr.com
Link to Theme ONLY for Droid_hd_xt912_v1.1
This is just an early preview. i will add more and refine in the coming days/weeks
Screens
how do we apply this just flash in recovery?
#370 saycbone
saycbone
  • 68 posts
Posted 15 September 2012 - 09:55 AM
Actually there is a Droid soft..a Droid nonsoft and Arctic
#371 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 15 September 2012 - 09:58 AM
i like having the soft keys i just thought there were normally 4 so was just wondering
#372 carracerz14
carracerz14
  • 119 posts
Posted 15 September 2012 - 10:15 AM
I thought the only difference between Droid and Arctic was the soft keys?
#373 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 15 September 2012 - 10:16 AM
Default is three. I'm sure kebob can and will be able to bring more into the rom
#374 carracerz14
carracerz14
  • 119 posts
Posted 15 September 2012 - 10:17 AM
It's normally back, home, and recent programs.
On some roms you can add more, like aokp and cm9
#375 mind game
mind game
  • 55 posts
  • LocationEast Coast
In a sense, yes. Artic HD is more themed, while the DroidHD non-soft version is this version without softkeys.
#376 graxall2
graxall2
  • 6 posts
Posted 15 September 2012 - 11:46 AM
Did these steps 4 times and still not installing correctly:
How to flash:
1) Boot into Safestrap.
2) Switch over to the Safe-Enabled side.
3) Wipe Data.(wiped 3x in a row to make sure)
4) Wipe Cache.
5) Advanced -> Wipe Dalvik Cache
6) Mounts and storage -> Format system
7) Install the zip downloaded from the link below.(using install zip from sd card option)
8) After first boot (which can sometimes take upwards of 10 minutes), reboot your device for best results.
Its almost as if the ROM half installs or something. Everything functions fine, but I have no DroidHD settings, no OTA Update settings, no Google Now, and widget is broken..also, when i hit home, i get multiple homescreen options like i previously stated. I downloaded the link from page 8, then again from matts dev page.
There must be something I am missing, or for some reason its flashing incorrectly....But i am following those steps, to a T every single time.
#377 Kebob
Kebob
    Dev
  • 246 posts
Posted 15 September 2012 - 11:52 AM
What Safestrap are you using?
#378 graxall2
graxall2
  • 6 posts
Posted 15 September 2012 - 11:55 AM
Newest
2.11
#379 graxall2
graxall2
  • 6 posts
Posted 15 September 2012 - 12:00 PM
One think I did notice when wiping Dalvik Cache..I get:
"E:unknown volume for path [/sd-ext]
Dalvik Cache wiped."
#380 ruokuo
ruokuo
  • 10 posts
Posted 15 September 2012 - 12:14 PM
So far, 1.10 has been running good. The only issue I see is fail to go to sleep mode, where it will stuck on airplane mode.
