1073 replies to this topic
#281 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 13 September 2012 - 07:56 PM
GUYS I AM GOIGN TO RELEASE A UPDATE. THANKS FOR THE CRITICISM BUT THESE ISSUES HAVE BEEN STATED FOR ABOUT 6 PAGES NOW. Its does not need to be posted time and time again. For the "battery issues" just turn off google now, it tends to use battery. You will see a update in about 50mins
Amen. Go to the search bar up top and search "this topic" for whatever keyword/problem you're having. It's probably already been answered.
#282 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 13 September 2012 - 08:11 PM
Can i just install google search?
#283 nsaechao
nsaechao
  • 48 posts
Posted 13 September 2012 - 08:43 PM
I would say if this rom is not right for you then move on.. If reporting an issue pls check prior post and stop hammering the dev over and over with the same thing.
I just want to say Thank you kebob and Matt for all you do if it wasn't for you two there wont be a Arctic or Droid HD rom.
My finding in using tibu. Is that Titanium backup always seem to have issue with restoring maybe should tried an alternative way of restoring apps... Just saying.
  • saycbone likes this
#284 Guest_BDH_*
Guest_BDH_*
Posted 13 September 2012 - 09:10 PM
I guess i have bad download? What do you think is causing this?
I would say it's probably an app. As Kebob mentioned it very well could be Google Now.
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
  • PillClinton likes this
#285 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 13 September 2012 - 09:12 PM
Ok, well i guess im gonna have to wait till tomorrow for the new update.
#286 bluex
bluex
  • 98 posts
Posted 14 September 2012 - 03:40 AM
Rom is working great for me, I love it! I'm sure a lot of us are really happy with it an just don't say anything. Thanks for all the work you've been putting in on this. I for one really appreciate it!
My battery is fine/same as stock, data drops way less than stock (though it seems to spend more time on 3G), and its super fast. What more do you need?
This Rom has made me decide to keep my razr instead of the galaxy nexus....
#287 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 14 September 2012 - 03:49 AM
I blued out a few more stock wallpapers and put them in the Droid HD folder of my dropbox.
Sent from my RAZR Droid HD Rom
  • c_live_lee likes this
#288 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 14 September 2012 - 03:55 AM
Ya know, you are right. Other than popping in and saying things are running great at first flash, without any issues there isn't much to post. For me, this rom has been fantastic right from the start. Battery issues have been close to non existent, data has been solid, its always been smooth, and the soft keys have really grown on me. There really isn't anything I could say bad about my experience with it.
  • usmcamgrimm likes this
#289 Papasmurf
Papasmurf
  • 135 posts
Posted 14 September 2012 - 04:27 AM
+1 totally agree with this
I've got a Maxx son!
If DROID DOES..... then iDroid
#290 aety9
aety9
  • 16 posts
Posted 14 September 2012 - 04:37 AM
Not sure if this is just a functionality issue, or a bug:
Whenever I go to add a widget from the app drawer; a window will pop up asking which widget to add, even after selecting the widget.
Is there any way to turn that off, fix it or is that just how the rom was designed?
Thanks!
#291 quangtran1
quangtran1
  • 243 posts
Posted 14 September 2012 - 04:43 AM
^^^^^^ +1000000
#292 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 14 September 2012 - 05:29 AM
Thanks!
It is supposed to work that way as of right now. I remember them mentioning that it as a work around they had to implement to set Widgets or something like that. Kebob or Matt may correct me if i am wrong on this.
#293 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
Posted 14 September 2012 - 05:30 AM
On a side note, downloading 1.1 now B-)
#294 droidrazrkid
droidrazrkid
  • 112 posts
Posted 14 September 2012 - 05:39 AM
Hey the update says dat wipe required do i need to only wipe data? or i dnt have to wipe at all?
#295 droidrazrkid
droidrazrkid
  • 112 posts
Posted 14 September 2012 - 05:42 AM
data*
#296 Papasmurf
Papasmurf
  • 135 posts
Posted 14 September 2012 - 05:44 AM
I am getting an error with the update. It won't even download.
#297 droidrazrkid
droidrazrkid
  • 112 posts
Posted 14 September 2012 - 05:50 AM
yea i got one to just leave wait 5 seconds and go try again and it will work
#298 Marcos915
Marcos915
  • 17 posts
  • Twitter:marx915
  • LocationEl Paso, TX
Posted 14 September 2012 - 05:55 AM
me too! been retrying every other min and still getting an error guess ill just download it when i get off work
#299 droidrazrkid
droidrazrkid
  • 112 posts
oh mine worked on second try
#300 jmack778
jmack778
  • 12 posts
Posted 14 September 2012 - 06:09 AM
I just attempted the flash through safestrap and it says update package and then error bad package. Any ideas?
