Epic softkeys! Nice work bro!
Thanks !! I need to pm icons to matt
Posted 13 September 2012 - 12:08 PM
Posted 13 September 2012 - 01:15 PM
Posted 13 September 2012 - 01:19 PM
Is there any way to port the launcher/circle widgit to a separate apk that can be used on stock or another rom?
Good work on this one too....been trying them all out latley
Posted 13 September 2012 - 01:29 PM
Posted 13 September 2012 - 01:36 PM
Well guys im running 1.1 beta atm its running smooth and app updates are working. Few more fixs and ill release todat
Posted 13 September 2012 - 01:45 PM
+1Woohoo!!! Don't forget us nonsoft peoples !!!
Posted 13 September 2012 - 02:05 PM
Posted 13 September 2012 - 02:25 PM
Hey can I use the inverted apps with this?
Posted 13 September 2012 - 03:26 PM
So i don't understand why this circle widget is such an arse with trying to get work without flashing the whole rom. I took everything new from the rom and put it in the stock rom and then opened up the new launcher that comes with the rom and then try to see if circle widget would work but still nothing! It says instead of not aloud on 3rd party launchers, it says "Problem loading the widget" I've been trying to get it to work on stock but looks like someone else might need to try for a little...
Works great on the rom itself so if i replaced every app that's on stock with what's in the rom, idk why it won't work because it has the same s#!t!
Anyways, for now just use the rom i guess. Nice rom though, i do love it.
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
Posted 13 September 2012 - 05:51 PM
Posted 13 September 2012 - 05:54 PM
SameI'm getting anxious waiting for the new build lol
Posted 13 September 2012 - 05:58 PM
Posted 13 September 2012 - 06:00 PM
Posted 13 September 2012 - 06:14 PM
Posted 13 September 2012 - 06:15 PM
Posted 13 September 2012 - 06:32 PM
Posted 13 September 2012 - 07:21 PM
Worst parts of this rom is the battery and the launcher. Wish it has swipe to the left for quick settings.
Posted 13 September 2012 - 07:25 PM
I guess i have bad download? What do you think is causing this?Battery is definitely not an issue.... almost 13 hours, still at 66%. Moderate use.
60.2KB 5 downloads
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
Posted 13 September 2012 - 07:51 PM
