#241
Posted 12 September 2012 - 03:27 PM
#242
Posted 12 September 2012 - 04:16 PM
I really do hope they remove the soft menu buttons and integrate the hard buttons. Arctic HD has that song when turning on the start which is defining. LOL. Good job guys!
Please read the whole thread. There is a separate download for no soft key version. It is a full rom, not a fix.
#243
Posted 12 September 2012 - 05:18 PM
#244
Posted 13 September 2012 - 03:07 AM
I'm running HD 1.02 on 2.15 and I entered this script by bytecode into ROM Control, then went to the Performance section and upped the CPU Max to 1325
and it over-clocked to 1325. I tried 1350 and then 1340 but my phone locked up. 1325 seems to work fine.
Note: Your mileage may vary.
echo 0 300 1025 > /proc/cpu_control/tweak_cpu
echo 1 600 1195 > /proc/cpu_control/tweak_cpu
echo 2 800 1320 > /proc/cpu_control/tweak_cpu
echo 3 1000 1388 > /proc/cpu_control/tweak_cpu
echo 4 1325 1400 > /proc/cpu_control/tweak_cpu
Sweet!
#245
Posted 13 September 2012 - 03:22 AM
Works great on the rom itself so if i replaced every app that's on stock with what's in the rom, idk why it won't work because it has the same s#!t!
Anyways, for now just use the rom i guess. Nice rom though, i do love it.
#246
Posted 13 September 2012 - 03:58 AM
Please elaborate, I have the script and previously have entered it in Int.d under etc folder, where is ROM Control? and by Performance section do you mean no frills cpu control in settings? Please give the steps you took, A little lost here.... thanks.This is interesting,
Sweet!
#247
Posted 13 September 2012 - 04:22 AM
ROM Toolbox has a 'Tools' section where you can select 'Scripter' and enter your script and then save it and then run it.
ROM Toolbox also has a 'Performance Section' where you can select CPU Control to set speed.
Once you run the script (via ROM Toolbox), you can change the Min & Max CPU speed either in ROM toolbox or via No Frills CPU Control.
#248
Posted 13 September 2012 - 05:06 AM
in the XDA thread on the Google Now to ICS port, this has been discussed a lot and no solution has been found.
there are some Apps that worked to do this, but none work on ICS. Google really borked BT in ICS. there have been bug fix requests to Google, but they won't acknowledge the issue or give any indication that any fix is being worked on.
Actually I think I found a way to do this and it was posted on XDA just yesterday. I used sys/app mover to move google search from a system app to a user app but the user on the link below used Titanium:
#249
Posted 13 September 2012 - 06:54 AM
Sorry, It's called ROM Toolbox in the Android Market.
Thanks a bunch for the prompt reply, no worries, wow we have a great forum!
#250
Posted 13 September 2012 - 07:35 AM
#251
Posted 13 September 2012 - 07:53 AM
#252
Posted 13 September 2012 - 07:57 AM
Im Just Letting U Guys Know I Found a battery defect on this rom wen charging and draining its off by like 5% the battery thing may say its on 95% but when u lock it its rly fully charged
Is it a 'defect' or did you not wipe battery stats after a new ROM flash? (you should)
#253
Posted 13 September 2012 - 08:01 AM
im thinking defect
#254
Posted 13 September 2012 - 10:16 AM
That was the solution I was looking for! By changing Google Search from a system to a user app with Titanium backup the old voice actions can be used by bluetooth headset and google search still works when manually activated. Very cool.
#255
Posted 13 September 2012 - 11:17 AM
#256
Posted 13 September 2012 - 11:32 AM
#257
Posted 13 September 2012 - 12:02 PM
BAtMAN softkeys link is live you can get it here
- moksha51 likes this
#258
Posted 13 September 2012 - 12:06 PM
Try clearing cash on market app
Didn't work.... this is a first for me with this issue...
#259
#260 Guest_BDH_*
Posted 13 September 2012 - 12:07 PM
Epic softkeys! Nice work bro!
