1073 replies to this topic
#221 moksha51
moksha51
  • 144 posts
  • LocationBoston, MA
Posted 12 September 2012 - 06:52 AM
You might try downloading this and replacing this file in SYSTEM--ETC
Didn't work for me. It's been 3-4 minutes and counting.
#222 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 12 September 2012 - 06:57 AM
Did you overwrite the file that was in their?
#223 moksha51
moksha51
  • 144 posts
Posted 12 September 2012 - 06:58 AM
Yes
#224 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 12 September 2012 - 07:03 AM
I'm not sure what to say (I am not expert by far)...This worked for me though...
#225 moksha51
moksha51
  • 144 posts
Posted 12 September 2012 - 07:07 AM
Are we talking about Navigation or Maps?Maps works fine. Navigation takes forever.
#226 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 12 September 2012 - 07:09 AM
navigation
#227 quangtran1
quangtran1
  • 243 posts
Posted 12 September 2012 - 07:19 AM
GPS uses a combination of Internet access and satellite responses to establish a lock. If either option is less than optimal (as in rural area, or lack of cellular strength), you may not be able to establish a GPS lock. There are many apps that go through these "pre-lock" scans and create a cache file. I believe there's one called GPS Status & Toolbox in the Play store. Your phone must be rooted and has Busybox for this app. What it does is scan NTP time servers, determine GPS coordinates, then write back a cache file for your other navigational apps. From then on, it takes a second to lock your GPS. Try that!
#228 chavist
chavist
  • 69 posts
Posted 12 September 2012 - 07:30 AM
#229 moksha51
moksha51
  • 144 posts
Posted 12 September 2012 - 08:38 AM
Awesome. I'll try this. I was wondering if just clearing the cache after replacing the gps.conf to this file might help.
#230 Razr1221
Razr1221
  • 43 posts
Posted 12 September 2012 - 09:10 AM
I m experiencing something odd in this rom, the first day I installed it the battery life was great, after the first cycle the battery is garbage, its consuming 2% a hour. So my question is why am I getting worse battery life as the room settles more?
  • 210droid likes this
#231 Mr.Rzr
Mr.Rzr
  • 102 posts
  • LocationThe InterWebz
Posted 12 September 2012 - 09:35 AM
flashed this just now and took awhile to boot up but as soon as it did i kept getting "unfortunately, the process, com.android.phone has stopped. any ideas?
#232 quangtran1
quangtran1
  • 243 posts
Posted 12 September 2012 - 09:57 AM
You probably couldn't pull any cell signal. When you get that message, pull down the notification bar and likely it said 'No service'. Not uncommon, keep hitting OK at the error prompt, and proceed with initial set-up. After a reboot, the error will go away.
#233 patchm00
patchm00
  • 48 posts
Posted 12 September 2012 - 10:01 AM
in the XDA thread on the Google Now to ICS port, this has been discussed a lot and no solution has been found.
there are some Apps that worked to do this, but none work on ICS. Google really borked BT in ICS. there have been bug fix requests to Google, but they won't acknowledge the issue or give any indication that any fix is being worked on.
I agree the new search is a piece of junk. The old one worked great...now I have two issues, one of which I fixed on a different ROM but can't on this one for some reason
1. BlueTooth search - i was able to disable Voice Search and then BlueTooth started using VoiceCommands instead which is much better. I am not able to go to Manage Apps and "disable" voice search on this ROM like I was on another ROM....maybe I'm doing it wrong?
2. Second issue is that the new search on the Google bar sucks and i want the one on ICS stock. I don't understand how this is an issue when it is on the Stock .21X, where did this new one come from?
EDIT on #2...on this ROM when I clicked the mic on the search bar on the background it asked which app i wanted to use so I'm set now on that one.
thanks
#234 Torito
Torito
  • 9 posts
Posted 12 September 2012 - 11:40 AM
I really do hope they remove the soft menu buttons and integrate the hard buttons. Arctic HD has that song when turning on the start which is defining. LOL. Good job guys!
#235 robthefive0
robthefive0
    Sarge
  • 315 posts
  • LocationN.J.
Posted 12 September 2012 - 11:56 AM
You are complaining about 2% per hour? I lose 2% in 10 minutes. I would love 2% per hour.
  • fastfoodfred likes this
#236 Razr1221
Razr1221
  • 43 posts
Posted 12 September 2012 - 12:07 PM
Everyone uses their phone in many different ways, I used it at work only in my breaks and i dont use it a lot at home, so i consider myself a moderate user, I used to be in the latest FLICK ROM and it would usually last me 2 days with 2 or soemtimes 3 hours of screen time, i love this ROM, is great , i would like to find out if my crappy battery life is because of the ROM or my device.
#237 robthefive0
robthefive0
    Sarge
  • 315 posts
  • LocationN.J.
Posted 12 September 2012 - 12:10 PM
I'd give it a few days, then make your decision.
#238 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 12 September 2012 - 12:24 PM
Right on thanks man I'll flash it again! Other than that is data usually pretty solid?
From my Zombie Annilated Razr
#239 quangtran1
quangtran1
  • 243 posts
Posted 12 September 2012 - 01:33 PM
All ROMs based on .211-.225 should have no data issue.
#240 keej
keej
  • 6 posts
Posted 12 September 2012 - 03:21 PM
I'm loving this ROM! Stellar performance.
I've tried to update the Gmail client but it won't permit updating and suggests I uninstall and re-install Gmail. That would be fine, but I can't seem to uninstall it either (no uninstall button). Has anyone else been able to update Gmail? Any advice?
Thanks!
