1073 replies to this topic
#201 mind game
mind game
  • 55 posts
  • LocationEast Coast
Posted 11 September 2012 - 05:11 PM
this appears to be a function of the GN version ported to ICS.
with the current JB version, you get a football icon. if another card pops up soon, i'll post a screen shot.
I figured that. Also guys if you could implement quick office into this rom it will be awesome!
#202 Mr.Rzr
Mr.Rzr
  • 102 posts
  • LocationThe InterWebz
Posted 11 September 2012 - 05:35 PM
Has anyone flashed this over another ROM and not stock .211?
From my Zombie Annilated Razr
#203 mind game
mind game
  • 55 posts
Posted 11 September 2012 - 05:47 PM
I flashed over Eclipse 1.2. Just wipe cache, data, dalvik cache, format system and bingo.
#204 Mr.Rzr
Mr.Rzr
  • 102 posts
Posted 11 September 2012 - 05:53 PM
Does formatting system wipe the internal SD card?
#205 RacerRon
RacerRon
  • 15 posts
Posted 11 September 2012 - 05:54 PM
Is there a way to switch from the google voice search default app when calling from bluetooth to the oe voice control app? The google voice never gets my calls correct but the original was pretty good.
#206 drewski11
drewski11
  • 186 posts
  • LocationSF Bay Area, CA
Posted 11 September 2012 - 05:58 PM
no. just the system partition.
#207 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 11 September 2012 - 05:59 PM
Nope, only the system partition.
#208 drewski11
drewski11
  • 186 posts
Posted 11 September 2012 - 06:02 PM
in the XDA thread on the Google Now to ICS port, this has been discussed a lot and no solution has been found.
there are some Apps that worked to do this, but none work on ICS. Google really borked BT in ICS. there have been bug fix requests to Google, but they won't acknowledge the issue or give any indication that any fix is being worked on.
#209 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 11 September 2012 - 06:20 PM
A few walls I made to go with the rom. Nothing special at all but it just seemed like the Razr wallpaper that came with it just didn't fit and the blue looks better. I've also recolored the bootanimation to be ICS blue and sent it to Matt. The link to the wallpapers in my dropbox is located in my sig. I again want to thank Matt and Kebob for making this awesome rom. This is by far the longest I've ran a rom without switching to another or going back stock.
  • emiliobadillio, adamjmtz and midas like this
#210 gdfnr123
gdfnr123
  • 48 posts
Posted 11 September 2012 - 06:44 PM
this is dope! thanks alot love the rom!
btw on the next releases is it possible if you guys can make it easier to enable/disable apps when not used?
like browser, apollo. i want to disable them. Overall Beast!
#211 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 11 September 2012 - 07:21 PM
Just installed & setting up now. These wallpapers look great, can't wait to check out the recolored bootanimation as well. Nice work as always Thach, & thanks Matt & Kebob for the rom!
#212 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 11 September 2012 - 09:40 PM
Thanks Thach! I will be releasing a very large update coming up. From now on every spare minute goes into this rom. Btw Thach, Im thinking of using one of those for the starting wallpaper :) they look great
  • emiliobadillio and moksha51 like this
#213 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 11 September 2012 - 10:31 PM
Coming soon... QuickSettings from RAZR M. Thanks to fastboot_oem_unlock and others.
Showing it off on my CM10 HTC One S
  • PillClinton and emiliobadillio like this
#214 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • LocationNorCal
Posted 11 September 2012 - 10:51 PM
Can't wait, love this rom so far! Great work guys.
#215 ktraub
ktraub
  • 98 posts
  • LocationSo. Maryland
Posted 12 September 2012 - 03:23 AM
Kebob,
Great ROM! I'm lovin' it. Smooth, fast, ton's of tweeks. Great Job!
Just one thing, I'm running HD 1.02 on ICS 2.15 and am lately seeing really slow GPS locks.
Anyone else seeing this?
-Kev
#216 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 12 September 2012 - 03:27 AM
Kebob,
-Kev
You might try downloading this and replacing this file in SYSTEM--ETC
#217 Kebob
Kebob
    Dev
  • 246 posts
Posted 12 September 2012 - 05:10 AM
Yeah Ill get some gps tweaks and add them in. That may help
#218 Shinare
Shinare
  • 235 posts
Posted 12 September 2012 - 05:31 AM
LOL I keep hitting the OTA-update screen as much as "System Updates" when ICS was dropping....
#219 chavist
chavist
  • 69 posts
Posted 12 September 2012 - 05:49 AM
Is there a version of this Rom without the soft keys?
#220 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 12 September 2012 - 05:56 AM
http://dev.crackflasher.com/mattlgroff/XT912.Verizon.en.US/DroidHdNonSoft1.02_fixed.zip
