{GAPPS - INVERTED}
Gapps
9 replies to this topic
#1 marxman3
marxman3
  • 290 posts
Posted 08 April 2014 - 04:50 PM
First off – this package is derived completely from the hardwork of others. The base is the SlimRoms minimalist GAPPS, the keyboard is the PA addon and the blacked out apps were themed by Team Blackout. They have many apps beyond what I have included and they can be found here:
ttp://www.designrifts.com/teamblackedoutapp/category/blacked-out-apps/google-apps-black/
My role in this is simply kanging what I like and rolling it into one neat package instead having to flash multiple addons, delete system apps, or worry about anything else.  This will not work on stock based ROMS.  I have tested these with Carbon, CM11, Beanstalk and Liquid Smooth and they worked perfectly with all. In theory they should work with any non-blur base, but because I am removing some stock apps through the updater script you may find a bug if the base rom has a different name for an app I need to remove or uses code not from the AOSP tree.  In theory this should also work for any phone type that calls for 4.4.2 Gapps.
What is blacked out:
Maps & Pandora which are not installed as system apps and therefore easily removed if you choose
System Apps (Use SDMaid, Rom Toolbox, TiBu, etc. to remove):
Android Weather
Google Calendar
Drive
Keep
Hangouts
Youtube
Play Store
GoogleNow
Google Settings
MMS
Because I have run into many problems with the stock keyboard I have also integrated the PA keyboard module into this package. It will remove the stock keyboard, replace it with a working Google Keyboard as well as install the iWnn keyboard and emoticons.
Instructions:
  1. Use a 4.4.2 Rom that is not blur based
  2. Flash after ROM
  3. A few apps will require manual permissions to sign in after reboot
  4. The end
IF YOU UPDATE ANY OF THESE APPS IN THE PLAY STORE YOU WILL LOSE THE BLACKED OUT THEME!
Enjoy!
Download:
I don't use all the apps in the package, but here are some screenshots
  • Memnoch73, usmcamgrimm, Noigel and 4 others like this
#2 marxman3
marxman3
  • 290 posts
Posted 08 April 2014 - 04:51 PM
4/9 - updated Gmail
4/11 - removed blacked out gmail & added option for Firefox instead of stock browser
  • jcyanide likes this
#3 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 08 April 2014 - 04:57 PM
oooh, nice.  I need these ported to my ASUS Transformer Infinity running cROMBi-kk stat.
I'll PM sbdags over at XDA and see if he can get them in that ROM - these would go fantabulously with tthat darkened KK look.
Good job for your package, and to TB for the originals!
#4 marxman3
marxman3
  • 290 posts
Posted 09 April 2014 - 02:28 AM
I was on a crack flashing binge tonight and gmail gave me problems on a couple roms, but worked on a few so I made some changes to it and replaced the link with the modded one. The new one worked perfect on the roms I tried, but I also added a 2nd version with the stock Gmail instead just in case.....
  • johnlgalt likes this
#5 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 09 April 2014 - 02:57 PM
Awesome man, thanks for the inverted gapps :)
Need Help? Send me a message
#6 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 11 April 2014 - 09:40 AM
4/9 - updated Gmail
Gmail still has issues. I know its the security stuff Google is pushing out. Also Google drive isn't working either. Just a FYI.... Awesome put together though thanks....
$3π+ £®m€ ×X× ®∆z® |/|@xX Π¶ oπ $ø|/|£ťhïñğ ¢ű$ț¤|/|
#7 marxman3
marxman3
  • 290 posts
Posted 11 April 2014 - 10:11 AM
I ran into the gmail issue again last night so I removed the themed version and replaced it with stock. Drive acts funny at first boot giving an option to report crash, but ignore it and open the app from  the drawer, it will log in (someitmes ask for permission, sometimes doesn't) work perfect.
I just flashed Vanir for the first time, logged in and opened drive, took the below screenshot than used Drive to upload the screenshot so I can downlaod to my pc and post this:
Changelog is in post 2
#8 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 11 April 2014 - 02:22 PM
Awesome. Yeah I am on a search for a updated inverted Gmail myself. No thanks to Google Settings. Don't use Drive on mobile as much as DB, so no hard feelings when I dumped it.
#9 marxman3
marxman3
  • 290 posts
Posted 18 April 2014 - 07:21 PM
Just a heads up - when I flashed the latest gummy using the gummy cwm recovery it caused fcs. When I flashed it with twrp 2.7 it worked fine.
Sent via my SlimBean RAZR M
#10 ThonyMelendrez
ThonyMelendrez
  • 7 posts
  • LocationLeon,gto.Mexico
  • Current Device(s):Motorola RAZR M xt907
Posted 08 February 2015 - 02:19 AM
Yeah I'll try this whenever I flash a Flash back to KK n.n
Enviado desde mi DROID RAZR M mediante Tapatalk
Also tagged with one or more of these keywords: Gapps
