Ics Lockscreen Ring Mod
lockscreen handle ring
16 replies to this topic
#1 disturbed58
disturbed58
  • 55 posts
  • LocationLancaster, PA
Posted 03 September 2012 - 07:42 PM
If you have wanted your very own ring and lockscreen slider like the Arctic Rom, I have a write-up for you. This way uses a flashable zip for those who do not have a theme or rom software. The hardest part is getting the image cleaned up.
INSERT STANDARD DISCLAIMER. DROIDRZR, myself or anyone referenced are NOT RESPONSIBLE FOR WHAT YOU DO TO YOUR PHONE.
Thanks to:
Mopar57 – for the update zip
The Arctic Rom (mattlgroff/Kebob) – inspiring me to learn how to dig further into android and create my own.
Part 1 – The flashable update zip
Go the thread by Mopar57 link above and download the zip file and save it to your computer. While you are there I would recommend reading some of the thread for background information. It appears the update.zip link is dead, use this
for now.
Part 2 – The Images
1. I’m going to walk through only 2 icons, you can do more.
2. Find the image or images you would like to use.
3. I used the stock icon size for a template.
For example: the ring and lock I replaced from the Simplex rom are 162 x 162 pixels. This is the total image size, not the ring size. I am not sure if there is a size limit but I’m happy with the results I get with the 162x162 pixels.
4. Using an image manipulation program edit your image, the better quality the image the easier it will be. I used GIMP for the whole process.
a. Get the image to fit within the 162x162 pixels, preferably only 75% of the square but that is up to you.
b. Make sure the edges are clean, if you zoom into the image sometimes you will see shading, this can show up and look messy.
c. The best way to explain how to clean up the image is to use my Chevy Bowtie as an example.
I chose a bowtie emblem and resized it to fit within the 162x162 template.
I then made sure the edges of the bowtie had straight clean edges and anything outside the clean edges I filled in with a color not used, I used blue. The reason for this is when using GIMP I selected the color and then made it clear. If the color you select is also in your image you may end up with holes. After making the background clear or you can leave it a solid color if you desire; save the image as a .png file.
d. Save the image(s) as the file you are placing. I only replaced the images named ic_lockscreen_handle_normal and ic_lockscreen_handle_pressed, I actually used the same image for both since you can’t really see the handle when pressed anyway.
Part 3 – Getting the frawework apk and updating.
1. Using a root browser (ES File Explorer, Rom Toolbox, etc…) navigate to SYSTEM/FRAMEWORK.
2. COPY the framework-res.apk file onto your sd card so you can edit it with a computer.
3. Move the framework-res.apk copy to your computer.
4. Right click on the apk and using 7zip click the option to “Open Achieve”
5. Go to res\drawable-hdpi and leave the folder open. Drag and drop the images you created into the folder, replacing the existing file.
6. Close the archieve.
Part 4 – Update zip
Open the update zip you downloaded earlier and place your new framework-res.apk in the system\framework folder. Rename the zip as you wish.
FINALLY
Reboot into Safestrap (Safestrap is the only tested recovery, you are on your own if you try another)
Make a backup
Flash your update zip
Post a screenshot if you got it to work.
See examples below. I can send any of the images I have if you are interested.
  • Rebel541 likes this
#2 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 04 September 2012 - 05:55 AM
Link to update.zip is dead. Awesome job by the way, although I am a Ford guy that Chevy Bowtie looks pretty sweet. :)
#3 disturbed58
disturbed58
  • 55 posts
Posted 04 September 2012 - 08:48 AM
Thanks for the heads up. I added a new link for the update zip.
I thought about putting a Ford image together but haven't gotten around to it.
  • lownslow200sx likes this
#4 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 04 September 2012 - 11:17 AM
When I look through the drawable-hdpi there's another file named zz_moto_lockscreen_alt_key.png. That file seems to be the image that is on the lockscreen on the ROM that I'm using. Do I need to replace that file with my created image as well? Thanks.
If we question our own actions, our thought process, make a conscious decision to what we feel is right every single day, that's what I believe to be Divinity. That's true Shamanism.
#5 disturbed58
disturbed58
  • 55 posts
Posted 04 September 2012 - 02:23 PM
I did not have to change it on the roms I tried, I tried Eclipse and Simplex. That looks like an alternate image but I haven't seen it on any of my roms.
#6 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 05 September 2012 - 07:47 PM
Here's my current lockscreen. I actually replaced the two images mentioned in the OP plus zz_moto_lockscreen_alt_key.png just in case. Thanks for the write-up disturbed58.
  • mising and Rebel541 like this
#7 Thach
Thach
    Motorola Fanboy
  • 2,364 posts
  • Twitter:thach2639
  • Google+:Thach26
  • LocationGrand Forks ND
Posted 05 September 2012 - 07:49 PM
I may just have to give this a try. Thanks for sharing and the great write up.
#8 fishaholic
fishaholic
  • 157 posts
  • LocationSan Diego
Posted 06 September 2012 - 06:25 PM
great idea! i did something similar but i changed the file in the rom so i had to flash the entire thing lol..... nice to have an update zip :)
#9 fishaholic
fishaholic
  • 157 posts
  • LocationSan Diego
Posted 07 September 2012 - 11:13 PM
Worked great!
And you only need to change the zz_moto_lockscreen_alt_key.png.
#10 mising
mising
  • 8 posts
Posted 09 September 2012 - 08:02 AM
Got it, Thanks!
#11 Rebel541
Rebel541
Posted 12 September 2012 - 01:40 PM
Thank you!
#12 logan3824
logan3824
  • 308 posts
  • LocationHouston, Texas. GO TEXANS!
Posted 12 September 2012 - 06:39 PM
Love your wallpaper...Mind sharing it? :)
#13 gatorbeetle
gatorbeetle
  • 7 posts
Posted 14 September 2012 - 11:41 AM
I got the message E:Signature Verification Failed when I tried to install the update from recovery.
Any Ideas?
Edit:
+++Nevermind...I'm not using a friendly recovery method for install of an unsigned zip. Don't have Safestrap.+++
#14 gatorbeetle
gatorbeetle
  • 7 posts
Posted 17 September 2012 - 09:20 AM
Worked!!! Had to clean up the image a couple times, but happy with how it looks now!
Thanks for the info, guys! Haven't modded a phone since the ORIGINAL Razr years ago, which I did to get around paying Verizon for games. LOL
Havinmg fun so far with this one!
#15 disturbed58
disturbed58
  • 55 posts
Posted 18 September 2012 - 10:58 AM
Yeah, the hardest part is getting the image cleaned up and looking the way you want.
#16 milkshed27
milkshed27
  • 195 posts
  • LocationFlorida
Posted 18 September 2012 - 12:59 PM
So sorry for the delay, I've been out of town for a few days. Here you are. Enjoy.
#17 gatorbeetle
gatorbeetle
  • 7 posts
Posted 20 August 2013 - 11:15 AM
Anyone figure this mod out yet for the new OTA Update. Flashed JB on my Razr and lost my cool Lockscreen Ring.  :(
Also tagged with one or more of these keywords: lockscreen, handle, ring
