Block Ota Updates
7 replies to this topic
#1 vols4life
vols4life
  • 123 posts
Posted 03 September 2012 - 06:41 AM
Didn't want to clog up the other threads so just starting a new one. I'm going to stay stock rooted with unlocked bootloader for the time being and don't want some ota update coming along and bricking me if I don't cancel and it just throws it on the phone. How would I go about blocking it from receiving the ota or even checking for one?
#2 bstrong
bstrong
    Savior of the Razrs
  • 264 posts
  • Twitter:bstrong11
  • Google+:bstrong9211
  • LocationNorth Carolina
Posted 03 September 2012 - 07:55 AM
A dialog box will keep coming up and you can keep denying it. Or if say delete the "know your phobe" videos in preinstall. This will make you fail the system check and get a status 7 error during ota
Invictus Maneo!
#3 leviwg
leviwg
    News Writer
  • 563 posts
What phone do you have? And freeze the update thingy. Using a root explorer.
a what? an android? whats that?
#4 tucstwo
  • Google+:tucstwo@gmail.com
Posted 03 September 2012 - 07:57 AM
I don't know how samsung devices work. But I know for the Razr or Bionic, freezing and preinstall bloat will cause any ota to fail. So even if it d/l while your're sleeping, it will attempt to install it and then fail. Again, I don't know if the updater scripts for Samsung follow the same process.
#5 vols4life
vols4life
  • 123 posts
Posted 03 September 2012 - 08:32 AM
Galaxy SIII. Thanks guys I'll freeze most the Verizon bloatware so hopefully that will block it.
#6 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 03 September 2012 - 12:15 PM
I know for Motorola at least it uses the System Version to check for updates. If you changed it to something like Go.Suck.It.Verizon instead of normal you won't get updates on Motorola... maybe its the same for Sammy?
#7 vols4life
vols4life
  • 123 posts
Posted 03 September 2012 - 01:56 PM
That would probably work, first Samsung so don't know the ins and outs either
#8 tucstwo
Posted 03 September 2012 - 06:19 PM
That too, if you edit the build.prop (if your rooted) under the ro.build.fingerprint, like Matt said to "bite me VZW" it might not update because it thinks you're on unofficial software. But I've had luck freezing bloat ware and pissing big reds updates off that way.
