[Rom][Bionic] Darksp33D 2.1 By T3T3Droid And Jp1044
227 replies to this topic
#101 Bulldog88
Bulldog88
  • 93 posts
Posted 04 September 2012 - 10:23 PM
Safestrap2.0 and everything works
#102 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 05 September 2012 - 01:40 AM
BS BP-TOOLS everything works but wifi tether and foxfi.
#103 idivorceyou
idivorceyou
  • 41 posts
Posted 05 September 2012 - 02:06 AM
I flashed with ss 2.11. Everything works fine. Except : Rotation has an obvious lag. Tether is not reliable and fails. And ends in a reboot.
Hope this helps development.
#104 T3T3droid
T3T3droid
    D3v3lop3r/Th3m3r/Machin3
  • 1,115 posts
  • Google+:t3t3droid@gmail.com
  • LocationConnecticut
  • Current Device(s):Droid Bionic, Droid Razr M, SGS4
Posted 05 September 2012 - 03:11 AM
Thanks everyone for your input! I hope you know that these roms are only able to be made better and better thanks to you! :D
Sig by Bama
If you like our work please consider
Donating towards
Phones and Site costs :D Thanks!!
#105 matjmonk
matjmonk
    Pack Leader to Bubba
  • 3,662 posts
  • Google+:matjmonk@gmail.com
  • Current Device(s):Nexus 6, Nexus 7 (2013)
Posted 05 September 2012 - 04:51 AM
Flashed using SS 2.10 (didn't know that there was a 2.11, should read Obsidians posts more!). Everything appears to work, rotation lag is a bit high and haven't gotten a chance to use WiFi tether on this ROM.
Thanks for the great work!
Edit: I did notice one thing that doesn't work quite right, I've tried to apply a custom wallpaper for the lock screen but even though it doesn't give any errors, it doesn't display the wallpaper, only the one used by the system.
#106 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 05 September 2012 - 05:25 AM
For all of you having issues did you do a full data wipe/ factory reset. My roms are not made to flashed over other peoples roms.
#107 matjmonk
matjmonk
  • 3,662 posts
Posted 05 September 2012 - 05:38 AM
Did the whole magilla, data/cache/dalvik as well as formatted system (from force of habit).
#108 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 September 2012 - 07:21 AM
I'll take a look at that and get back to you thanks
Sig by Bama
Donating towards
#109 RetalX
RetalX
  • Twitter:shayne6717
Posted 05 September 2012 - 07:36 AM
This is probably a noob question but how do I get the LED flashlight toggle to work? Other than the flashlight this rom is great!
#110 kjens0815
kjens0815
  • 18 posts
Posted 05 September 2012 - 08:02 AM
Ok everyone I have a question for you.
Please Post what safestrap version you used to flash AND if you having Wifi Tether or Root issues of any kind.
Safestrap 2.11
Can't get either Wi-Fi tether or Fox Fi to work
No, rooting issues and I did a full wipe on install. Awesome ROM none the less!
#111 DrJay
DrJay
  • 63 posts
  • Google+:jconawayiii@gmail.com
  • LocationRancho Cucamonga California
Posted 05 September 2012 - 10:36 AM
Installed with SS 2.1 over .232
Installed with a full wipe.
I have a bit of lag launching apps...The app will open fine, but is slow to load - like I'll open contacts and the header will open, but it is slow to load the contacts. Happens with nearly every app. I am thinking maybe a governor/memory tweaks? I've tried ondemand and interactive with no difference. InteractiveX force closes everything- system/market/google apps etc...Tried pegasusq with no noticible improvement.
What governor is everyone else using?
Also on another note regarding the lockscreen, Like matjmonk said, I have also noticed the target icons don't stick either, No errors when applying, they just don't stay..... but I have seen this problem with all CM9/AOKP roms too.
Sent from my ICS Bionic using my fingers
#112 captainnemo
captainnemo
  • 8 posts
Posted 05 September 2012 - 05:55 PM
Wow, I've been really amazed with this ROM. I've been on Liberty 2.0 (Gingerbread) since I got my Bionic (apx 11 months ago) & I decided it was time for an upgrade.
After searching for a ROM with a working camera, I came across Darksp33D & decided to give it a try.
I wasn't able to install SafeStrap 2.11 because it only runs on ICS, so I had to:
  • Revert to stock .905 GB FXZ with RDS lite
  • Wipe/flash to stock .2233 ICS leak
  • Root ICS
  • SafeStrap/Wipe/Flash to Darksp33D 1.0.1
Needless to say it’s been a day for my phone. The Interface is clean & really smooth. I've been super impressed with the Awesome Beats & Apollo. I'm sad that Beats doesn’t work with WinAmp, so it looks like I might be switching music players.
After spending HOURS on this whole project I went to make my first phone call since I reverted to stock .905 and... no audio... at all.
  • I don't hear any ringing/sound from any speakers
  • They can't hear me
  • I can't hear them
  • Same problem on handset or speakers
  • Same for incoming or outgoing calls
  • Battery pulled numerous times- nothing.
Please help?! I'm not sure what to do. I'll have to revert & try another ROM of I can't get this working... & I don't want to. Thanks!
#113 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 05 September 2012 - 05:56 PM
  • Root ICS
  • I can't hear them
Turn bluetooth off, its a known bug.
#114 captainnemo
captainnemo
  • 8 posts
Posted 05 September 2012 - 06:06 PM
HAHA! I literally laughed out loud when I read that. Thanks for the instant reply.
Ouch. That may be a deal breaker. I ALWAYS have Bluetooth on because I have the Sony Smartwatch. :-( Any idea if/when the bug will be worked out?
#115 kendog
kendog
  • 234 posts
  • LocationMillville, NJ
  • Current Device(s):droid bionic
Posted 05 September 2012 - 06:07 PM
For wifi tether I have used it over 50 times already try putting device profile on razor cdma and check router fix... working fine for me. No errors... o and after I flashed this I went into safe strap. And fixed permissions no FCs after that.
#116 kendog
kendog
  • 234 posts
Posted 05 September 2012 - 06:10 PM
I think I had one fc on the phone app but I locked it to stay on and i never got fc anymore
#117 nhugh406
nhugh406
    Developer
  • 171 posts
  • Twitter:@nhugh486
  • Google+:nhugh406@gmail.com
Posted 05 September 2012 - 07:54 PM
The apps I'm dropping in are replacing ones that already exist within the system. I have attempted to force stop these apps, however, still no result. My workaround has been to decompile the zip, replace what I'm looking to replace (with the addition of some tweaks) and then recompile the zip again.
Kind of a convoluted way of doing things, but hey, that's what I got.
And fyi, it does take care of the vibe issue.
Just to follow up, finally got all issues taken care of.
rom is running awesome. Thanks to the devs!
#118 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 05 September 2012 - 08:03 PM
You used kendog's suggestion which fixed your wifi tether issue?
#119 kendog
kendog
  • 234 posts
Posted 05 September 2012 - 08:21 PM
What vibe issue are you talking about?
#120 kjens0815
kjens0815
  • 18 posts
Posted 05 September 2012 - 09:35 PM
For an update on WiFi Tether, I got it to work by switching the profile to Generic ICS/JB (wlan0) but my phone does reboot after turning it off. Hope this helps you JP, thanks again for the sweet ROM.
