[Rom][Bionic] Darksp33D 2.1 By T3T3Droid And Jp1044
#221
Posted 27 September 2012 - 03:35 PM
- T3T3droid likes this
#223
Posted 11 October 2012 - 03:26 PM
and wut ss should i use?
srry im new to the bionic....just came from razr maxx
#224
Posted 11 October 2012 - 03:45 PM
should i be on ics leak for bionic to install this rom???
You have to be on ics. I'm running 232 and 1.1. But I'm using bs. I think 2.1 on ss, but a newer version of ss is coming out shortly. If you're on 905 you have a lot of reading to do. Latest version you can sbf/fxz from currently is 232. There are about a dozen leaks since then, but currently no way to go back on them to 905. Does this make sense so far? You can pm me with any questions, and I'll try to answer them or point you in the right direction.
Sent from my DROIDX using Tapatalk 2
#225
Posted 17 October 2012 - 04:30 PM
#226
Posted 17 October 2012 - 06:20 PM
我非常喜欢这个ROM 感谢两位大神给我们带来这么好的包!!! 不过就是切换横屏竖屏的时候 画面会突然变小然后再变过去是怎么回事?
Probably, but you'll want to make a nandroid of your stock system before you do any of that
- ReservedName likes this
#227
Posted 17 October 2012 - 06:29 PM
שמתי לב כי בכמה roms אני מנסה. כנראה יש משהו לעשות עם JB זה להיות ולא OTA ליונית.
#228
Posted 15 May 2013 - 06:56 PM
I'm moving this into the Legacy ICS ROM section
