[Rom][Bionic] Darksp33D 2.1 By T3T3Droid And Jp1044
227 replies to this topic
#181 rclark3113
rclark3113
Posted 18 September 2012 - 07:31 AM
Hey guys, much appreciate the update!!!! Can anyone tell me if the bluetooth issue was resolved? Thanks!
From what I understand, it's a Kernel problem.
I am curious to know why it works in the Stock build, but not in any of the roms though.
This bug is one of my biggest issues with any of the ROMs out for ICS.
#182 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
  • Current Device(s):Bionic
Posted 18 September 2012 - 09:22 AM
Because Motorola hasn't released source for THEIR libaudio files. We're compiling straight Google Android libaudio without Moto's patches to the source. Things aren't quite going to align because some Motorola files have to be pulled from their build and we're compiling what amounts to a slightly wrong source code. It mostly works, but not entirely.
#183 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 18 September 2012 - 09:26 AM
No. The bluetooth issue will NOT be resolved if the devs continue to use the same build as their base and only add a bunch of speed/memory/battery/graphic tweaks along with some apps for overclocking.
This issue either needs to be fixed after the fact by pulling apart the libraries and altering the machine language type guts of them, then repacking the libraries somehow, OR if they do roughly the same thing, but apply the changes to the source code and compile it properly.
#184 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 18 September 2012 - 09:28 AM
Think of it as a car with transmission problems. You can paint it any color you want. You can even adjust the way the engine runs to get more horsepower out of it. But to get rid of the growl in second gear, you have to rebuild the tranny. End of story.
  • killahkazx and dwhiteley87 like this
#185 docluv01
docluv01
  • 38 posts
Posted 18 September 2012 - 10:46 AM
My apologies....never insinuated any disrespect. First time using a cm9, didn't know issues were with base. Thanks guys!!!
#186 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
  • Current Device(s):Motorola Droid Ultra XT1080
Posted 18 September 2012 - 01:29 PM
Was wondering which version of GNow is being used in the version 1.1?
#187 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 18 September 2012 - 01:50 PM
Inverted M7 from xda
  • twinkyz1979 likes this
#188 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 18 September 2012 - 01:55 PM
Sweet Thank you.
#189 danthepunman
danthepunman
  • 9 posts
Posted 18 September 2012 - 02:23 PM
With ROMs there is always pluses and negatives. This one has a lot of +'s. Most don't even have cameras working. To get audio through the phone toggle off the BT.
I'll be flashing as soon as I my phone.
Q: Which governor is working best for everyone? At times it seems to over heat and causes a reboot.
#190 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 18 September 2012 - 06:03 PM
Don't even worry about it. I don't think anyone saw your question as disrespectful. Yeah, the issues are from the ROM this is overlayed on to.
Most don't have a working camera? Really?
I'm sure you couldn't swing a dead cat without finding at least a couple Blur based ROMs that have a perfectly working camera and more kangs of CM9/AOKP that have a working camera than you could count if you were buck naked!
The only ROMs that don't have a working camera are the ones that use a kexec kernel, or the VERY VERY recent jellybean ROMs that are based on the stock kernel
#191 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 18 September 2012 - 07:07 PM
Can you explain the purpose of the 2 calendar apk's in the /system/app folder? I mean the calendar.apk is the inverted one and i assume the calendarprovider.apk is the stock one but why would both be needed? Just trying to figure this out for personal reasons not that there is any problems caused by this or anything.
Nevermind i figured out the answer to my own question. Thanks for all the input on it though. I think i had a brain fart that lasted about a day and a half. LMAO
#192 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 18 September 2012 - 07:37 PM
CalendarProvider.apk is the background service for the calendar app, I believe. Things like syncing with Google are done there, while the actual app that displays and allows edits to that calendar are handled by the Calendar.apk frontend.
I could be way off, though. It just fits with the client/service pairing you see in a lot of programs for Linux.
#193 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 18 September 2012 - 07:43 PM
the syncing is done through googlecalendarsync. i just wasn't sure if those 2 apk's were just to give the user another choice for the calendar widget or what.
  • Int_Rnd_Pooka likes this
#194 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 19 September 2012 - 01:08 AM
Then .. I dunno? Maybe you're on to something with the widget?
#195 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 19 September 2012 - 06:42 AM
Here is a bit of info, posted in the OP of this thread about how to get the apk BACK :)
No matter what the actual purpose ends up being, I'd say that apk is probably a pretty essential one to this ROM (and every other ROM) and shouldn't be frozen or deleted if you use the calendar for anything. Looking through Titanium Backup, I see the Calendar app itself, the Google Calendar Sync, and the Calendar Storage app. Not really sure why they would be three separate apps.
#196 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 21 September 2012 - 03:05 AM
Hmmm. Just got the mms issue. No size pic sends. On 1.1
#197 T3T3droid
T3T3droid
    D3v3lop3r/Th3m3r/Machin3
  • 1,115 posts
  • Google+:t3t3droid@gmail.com
  • LocationConnecticut
  • Current Device(s):Droid Bionic, Droid Razr M, SGS4
Posted 21 September 2012 - 04:45 AM
I'm sure JP knows by now but I'll let him know :)
Sig by Bama
If you like our work please consider
Donating towards
Phones and Site costs :D Thanks!!
#198 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 21 September 2012 - 10:45 AM
Thanks t3. Had no issues till last night.
#199 danthepunman
danthepunman
  • 9 posts
Posted 22 September 2012 - 07:54 AM
I can send pics. 69kbs and on 1.1 When you get the fail is your data on for vzw? MMS can on be sent over vzw not wifi.
#200 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 22 September 2012 - 11:51 AM
I'm using 4g. No biggie. Everything else is running awesomely.
