#121
Posted 17 January 2012 - 03:32 PM
I installed this update. Everything runs smoothly for a week. However, since yesterday, I started to have a problem regarding the sim card, it said that my sim card not installed, I rebooted and it got back to normal. I just wonder if any of you have this issue.
Thanks!
#122
Posted 17 January 2012 - 03:37 PM
#123
Posted 17 January 2012 - 03:44 PM
http://www.mydroidfiles.com/downloads/Razr/Blur_Version.6.11.748.XT912.Verizon.en.US.zipsorry but i can not find the dl link for the .173 update. I have the eclipse rom, the fastboot files, rootkeeper and the downgrade to .748. am i missing something?
- jtsativa420 likes this
#124
Posted 17 January 2012 - 03:45 PM
thank you!!
#125
Posted 17 January 2012 - 03:58 PM
#126
Posted 17 January 2012 - 04:35 PM
Ill update the OP when I get home. Since the original post has fallen off the homepage its not as easy to find these files now.
Yes, I searched the forum and the web and clicked your embedded picture who knows how many times hoping it would work. Lol.
#127
Posted 17 January 2012 - 06:00 PM
#128
Posted 17 January 2012 - 06:07 PM
OK so I have rsd three times and went through the proper way. Keep getting validation errors. Please some one help.
I had the same issue many times and this fixes every time.. hang on.. you need the full fastboot combined and RSDLITE..
Its the very last download...
Download it, unzip, use rdslite to restore.
It will bootloop... that's ok... get to moto recovery and wipe data factory reset, wipw cache partition, reboot. Ill clean up my post in a few.. im.at the bar.
It will work. Promise
#129
Posted 17 January 2012 - 06:16 PM
#130
Posted 17 January 2012 - 06:31 PM
Enjoy the bar. I will try soon and you will most likely be my hero of the night.
It will work ;
Thats exactly what I do.. I flashed eclipse, with bootstrap, then installed safeatrap and put ic3 pre-alpha build on my safe, then installed SS in IC3 split my partition and placed Razrx on that.. i think.. all i know is i was FFFFFF-ED! THAT WILL WORK.. Droidrzr.com exclusive NEVER EVER POST ANYWHERE ESLE
#131
Posted 17 January 2012 - 08:25 PM
It will work ;
No go. Rsd did take longer and I was hopeful but after all steps I still get verification error.
#132
Posted 17 January 2012 - 08:40 PM
What the heck did u do? Lol
Ive done some bad stuff... but i make it back
#133
Posted 17 January 2012 - 09:06 PM
Uninstall SS. (not the apk, but within the app itself).
Factory restore (via Moto Recovery)
RSD using file found . (credit: eternity project)
Factory restore one more time just to make sure (again via moto recovery)
Restoring via SS/Bootstrap will not fix this issue.
Factory restore via SS/Bootstrap will not fix this issue.
Re-read the above two lines if you're confused.
When you're done you'll be full factory (.744) as if the phone had just come out of the box (except any files on your SD partition and your external SD card).
#134
Posted 18 January 2012 - 05:22 AM
Uninstall SS. (not the apk, but within the app itself). Factory restore (via Moto Recovery) RSD using file found
. (credit: eternity project) Factory restore one more time just to make sure (again via moto recovery) Restoring via SS/Bootstrap will not fix this issue. Factory restore via SS/Bootstrap will not fix this issue. Re-read the above two lines if you're confused. When you're done you'll be full factory (.744) as if the phone had just come out of the box (except any files on your SD partition and your external SD card).
What the heck did u do? Lol Ive done some bad stuff... but i make it back Sent from my DROID RAZR using Tapatalk
I quit. Ok so here is what I last did;
1. Installed SS again so I actually had something to remove.
2. Wipe Data\Cache
3. Full RSD
4. Wipe Data\Cache
5. Full RSD
6. Update to 748
7. Root\OTA RootKeeper
8. Tried to install 173 through STOCK Recovery (Either with file name left as download or as update.zip)
9. Validation error
Now I have downloaded the update on three different computers and from my phone because There have been times where files do not download properly. Doesnt work. The RSD has been downloaded on two different computers. This has been completed using two different computers. I have only used the Full RSD. I have not used the smaller command line method.
#135
Posted 18 January 2012 - 07:38 AM
2. Wipe Data\Cache
3. Full RSD
4. Wipe Data\Cache
5. Full RSD
6. Update to 748
9. Validation error
Are you failing the package verification or the current system verification?
#136
Posted 18 January 2012 - 07:46 AM
E: failed to verify whole-file signature
E:signature verification failed
So package?
#137
Posted 18 January 2012 - 07:54 AM
So package?
I assume you've checked the md5 of the package after you've downloaded it and once its on the SD card right? Because at this point I'm inclined to believe your card is bad and corrupting the file.
#138
Posted 18 January 2012 - 07:58 AM
Alright let me try something and will follow up here shortly.
#139
Posted 18 January 2012 - 09:33 AM
- mattlgroff likes this
#140
Posted 18 January 2012 - 07:59 PM
***IF YOU HAVE EVER USED HASHCODES SAFESTRAP... STOP HERE AND DO A FULL
Step 2: Disable Safestrap via the app. You do not have to remove the apk itself, but the system needs to be disabled.
Might I suggest that you change either the warning to say simply "SAFESTRAP" rather than "HASHCODES SAFESTRAP", or change Step 2 to say "Disable Hashcodes Safestrap (AFTER RSD Fastboot)" insead of "Disable Safestrap"? This one minor difference between the two (one calling it HASHCODES SAFESTRAP and the other calling it Safestrap) tripped me up simply because I didn't know that they are one and the same.
Legacy Devices →
Installing 6.12.174.xt912 [Guide]Started by arcanexvi , 02 Feb 2012 Update Guide |
