Installing Official 6.12.173.xt912 [Guide]
Update Guide
249 replies to this topic
#41 Droid_Razr
Droid_Razr
  • 30 posts
  • LocationForest Lake, MN, USA
Posted 12 January 2012 - 07:09 PM
I just did what the directions said. lol.
#42 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
You didn't unroot for the last update either?
nope. I RSD'd just for testing purposes and went from 744 all the way to 173 without unrooting.
edit: temp unrooting that is. i would just restore SU after each update
#43 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 07:12 PM
all well and good if it actually let me...Ive done this twice now.....and also just noticed after RSDing back to 744 with fastboot file I still have my accounts etc on there shouldnt it have been wiped out?
#44 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:13 PM
That's what I did. The directions say to temp unroot, before each update. Then restore after each update.
#45 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
RSD does not wipe the phone. it just replaces all the system files
#46 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
which directions do you speak of? god knows i didn't write that ;)
#47 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:14 PM
You did factory reset after flashing right?
#48 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 07:15 PM
....nope...but will now
#49 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:18 PM
I only had trouble with trying to get into the motorecovery menu, don't know what buttons I was pushing to get into the menu, but I finally found it. So use to using safestrap for everything.
#50 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 12 January 2012 - 07:21 PM
Volume + and - simultaneously when you see the exclamation mark.
#51 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:25 PM
Okay, thanks. If that would have been included in the directions last night, I would have had an extra half hour of sleep. lol. I was pushing up volume button most of the time trying different menu options and menu would close. Then finally pushed the right button combinations. I was up to the exclamation mark few times last night, but didn't know what to do then. Finally must have pushed the right buttons.
#52 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 12 January 2012 - 07:27 PM
It's been in my thread from the start. The original thread didn't have it listed.
#53 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 12 January 2012 - 07:28 PM
Lol I have to step in here. For all the new guys to the site or new to hacking your phone. Please read the whole entire other post at least 5 times. Then write it down on paper so you no what to fo in your own words. Any words or terms you see that you don't understand, read threw the pages, there is a good chance thayour question was answered already. If not, Google it, you are about to do many things to your phone,so you want to no what your doing.
I'm not trying to be a a$# or nothing like that. This is the way i learned and it is the best way to learn. The last thing you want is to be freaking out when something goes wrong. Or dive in head first its up too you :P
  • arcanexvi and zllibengood like this
#54 DroidRazrAZ
DroidRazrAZ
  • 198 posts
  • Twitter:konellaz
  • Google+:konellaz@gmail.com
  • LocationPDX 2 PHX
Posted 12 January 2012 - 07:35 PM
^^^^^ +1 ^^^^^
#55 DonDraper
DonDraper
  • 156 posts
  • LocationLexington, SC
Posted 12 January 2012 - 07:55 PM
DITTO!
#56 DonDraper
DonDraper
  • 156 posts
Posted 12 January 2012 - 08:00 PM
Sooo everything working fine here, but does a factory reset/wipe remove root? Or can I re-download the rootkeeper app and get it back? No matter how well my phone is working, I have this compulsion to start from ground zero after getting an update... :D
#57 todroid
todroid
  • 35 posts
Posted 12 January 2012 - 10:14 PM
I did not unroot (just protected root with OTA rootkeeper) or do anything to disable the bootstrap prior to installing the leak. Had no issues with install and the root restored just fine.
#58 DroidRazrAZ
DroidRazrAZ
  • 198 posts
  • Twitter:konellaz
  • LocationPDX 2 PHX
Posted 12 January 2012 - 10:20 PM
you can do both
You can Do a data wipe/factory reset using MOTO recovery
or a internally in Privacy.
I just tested both of them for you
Checked root with root checker and Bootstrap
:) if that help hit like ?
******SIDE NOTE******
UNLIKE THE OTA FROM .744 TO .748 THIS UPDATE DOES BREAK ROOT I HAVE TESTED AND IT DOES YOU MUST USE VOODOO
  • DonDraper likes this
#59 Z28nck33
Z28nck33
  • 36 posts
Posted 13 January 2012 - 12:49 AM
If the new cheesecake has a different kernel how can you downgrade with the 744 fastboot files?
#60 JungleKing76
JungleKing76
  • 446 posts
Posted 13 January 2012 - 01:10 AM
With the fastboot files they will flash the 744 system over in it's entirety which includes the original kernel. My question would be the link that was provided saying you could just flash a zip to get back to 748. With the locked bootloader, do flashes change kernels? I am not a dev so I am not up to speed on that one.
