Installing Official 6.12.173.xt912 [Guide]
Update Guide
249 replies to this topic
#21 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 12 January 2012 - 03:42 PM
Nice writeup arc
Signature Loading.................
thnx.
#22 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 12 January 2012 - 03:49 PM
This works flawlessly, thanks for your efforts.
#23 razrnater
razrnater
  • 13 posts
Posted 12 January 2012 - 05:50 PM
Nice!!
But.......I'm getting error status 7 for file Music2.apk
I have NOT deleted any files or apps on my phone.
Thanks,
Mel
  • Badger50 likes this
#24 jtelander
jtelander
  • 134 posts
Posted 12 January 2012 - 06:01 PM
Nice write up...very clear and easy to follow.
Now the bad news...OTA rootkeeper is unable to restore root. When I select "restore root"...there is a message that says rootkeeper has been granted superuser permissions..and then it says "su root restored"...
BUT two of the checkboxes "device rooted" and "root permission granted" remain unchecked and unfortunately the phone is not rooted.
Suggestions?
#25 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Nice!!
Thanks,
Mel
Something touched the file. Fixing permissions, edits, etc etc. May not have been you, but one of your root apps. It's failing the current system verification.
#26 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 12 January 2012 - 06:02 PM
Suggestions?
Roll back to 748. re root/protect. Upgrade again. I had the same issue during one of my trials.
  • y0brando likes this
#27 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 12 January 2012 - 06:11 PM
Wow great write up. You saved me time at the pc and my inbox is not flooded lol
I owe you one :P
#28 razrnater
razrnater
  • 13 posts
Posted 12 January 2012 - 06:25 PM
Thanks....I had to replace the vz nav app too....weird.
#29 DonDraper
DonDraper
  • 156 posts
  • LocationLexington, SC
Posted 12 January 2012 - 06:35 PM
Thanks arc.
I like the update so far. I think the camera is working better. I notice updates to a lot of stuff. Cardock looks slightly different. Everything seems quite snappy.
So if i reset/wipe my phone at this point, I'm gonna lose root correct?
#30 Droid_Razr
Droid_Razr
  • 30 posts
  • LocationForest Lake, MN, USA
Posted 12 January 2012 - 06:39 PM
It worked flawless for me.
#31 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 06:42 PM
Both times Ive done this I have gone from a rooted 748 w/no safestrap (**just a note that I rooted it after the OTA upgrade since this is a new phone today checked root and Root Explorer allowed me to switch to r/w),
installed the voodoo, backed up SU....
then flashed the 173 and then when I try and redo the voodoo...it says su restored but no checks.
Is there something missing from the OP that I need to do?
now, I am RSD'g stock 744...what should I try....
1) root...voodoo...back up SU....then goto 748? same process?
#32 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 06:53 PM
No use for safestrap until after your ready to use roms again. All you need is Voodoo, after you root.
#33 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 06:57 PM
thats what I thought, But why am I having issues?
#34 DonDraper
DonDraper
  • 156 posts
Posted 12 January 2012 - 07:01 PM
No safestrap or cwm here. I was stock rooted 748, ran voodoo, updated and it rerooted just fine. I unfroze all the frozen apps before updating. Otherwise I had not modified or removed anything.
#35 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:02 PM
Did you temp unroot before update?
#36 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 07:03 PM
No I didnt....is that needed? It doesnt say in OP
#37 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:04 PM
You can't have the update bust your root, you have to temp unroot using Voodoo before rebooting into motorecovery. Yes it does, for the last update, the first update it doesn't matter because that's over the air.
#38 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 12 January 2012 - 07:06 PM
For the record I've never temp unrooted. The one time i did temp unroot, it had the same issue he's having now. That's why i never did since.
#39 Droid_Razr
Droid_Razr
  • 30 posts
Posted 12 January 2012 - 07:08 PM
You didn't unroot for the last update either?
#40 islandfever
islandfever
  • 353 posts
Posted 12 January 2012 - 07:09 PM
Ok then Im now even more confused.
