Installing Official 6.12.173.xt912 [Guide]
Update Guide
249 replies to this topic
#201 superstargoddess
superstargoddess
  • 126 posts
Posted 01 February 2012 - 06:31 PM
You can update the SU on 173 if it asks for it while on the device itself.You click the notification. May also need to update Superuser.
I tried, I do believe. It just gave me an error that it could not update Su. And I downloaded the newest Superuser as well. I just can't figure out what went wrong. >< I did the RSD back to .744 then OTA updated to .748 and everything.
- Motorola Droid RAZR [IC3Razr- always most recent]
#202 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 01 February 2012 - 06:49 PM
i read in the arctic thread about updating SU if it fails you can update busy box from the market and that should take care of the SU issue.
#203 superstargoddess
superstargoddess
  • 126 posts
Posted 01 February 2012 - 10:48 PM
Thanks! I'm trying to remember if I tried that. I think that I may have. It was just a bad night for flashing apparently! :P
#204 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 02 February 2012 - 07:10 AM
Alwasy update Busybox & Superuser via the Market first before updating the SU binary or you are bound to ahve issues from what I've found.
#205 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 02 February 2012 - 07:15 AM
All these updating issues can be solved If the su binary is setup right in the ROM. By placing the binary in /bin and symlinking it in the updater-script to /xbin it will not have any issues updating. Also, busybox should be in /xbin only.
Its when there are multiple binaries that the issues present themselves.
#206 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 02 February 2012 - 07:34 AM
This.
#207 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 02 February 2012 - 07:35 AM
There's also an app that repairs superuser on the market. I think it's named something retarded simple like superuser update fixer or something similar if you don't want to do it manually.
#208 superstargoddess
superstargoddess
  • 126 posts
Posted 02 February 2012 - 12:01 PM
Yep, I tried that too, didn't work. I'll do what DT said next time I try it, if I do. :P
#209 jrtem9
jrtem9
  • 9 posts
Posted 03 February 2012 - 05:42 PM
Doesnt work for me and I have tried everything except using rsd lite, but I was trying to keep from doing that. Below is what I keep getting:
Install/sdcard...
Finding update package...
Opening update package...
Verifying update package...
Installing update...
Verifying current system...
assert failed: apply_patch_check("/system/app/Book phone.apk",
"4df2cfe445702906a0a02912826de3639739a1a4",
"91dc9cc860f9614afb2b8cb846cbbd558c0dcd6e")
(Status 7)
Installation aborted.
Any suggestions on how to fix this? Any help will be greatly appreciated.
#210 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 03 February 2012 - 05:43 PM
Install/sdcard...
(Status 7)
Your file has been altered/changed/corrupted by something. Easiest fix would be RSD and re-do the upgrade process. You shouldn't have to wipe. Make sure you re-root before proceeding past .748
#211 jrtem9
jrtem9
  • 9 posts
Posted 03 February 2012 - 08:29 PM
How do I RSD? I have been looking for more info on this and haven't found anything yet. Guess I haven't looked into the right place yet.
#212 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 03 February 2012 - 08:31 PM
Read the first line of the OP and click on the link in it...
#213 jrtem9
jrtem9
  • 9 posts
Posted 03 February 2012 - 08:38 PM
OK I saw it, somehow missed it. Will give this a go then try again. Is there a way to get the .173 update and still be able to get OTA updates? I don't want to miss the ICS update whenever it does finally come out.
#214 Tmc363
Tmc363
  • 182 posts
  • Twitter:@tmc363
  • LocationHouston, Tx
Posted 03 February 2012 - 08:54 PM
we have a fastboot file that your are currently trying to use with rsd that will always put you back on the upgrade path as a safety net. There are also zip files in the op that you can use to revert back to 748 that will put you back on the upgrade path.
Donate $10 or more to our Phones For Devs Giveaway and get a Custom Forum title and help the Make a wish Foundation details here: http://www.droidrzr....-custom-titles/
#215 jrtem9
jrtem9
  • 9 posts
Posted 03 February 2012 - 11:45 PM
I just installed this update and everything seems to be working so far, but I did not maintain my root access. I installed Voodoo prior and set it to protect root but it did not. I also noticed that it did not when I used RSD to flash my phone back to install this update. I had to root it again after using RSD to go back to .744 and again after I did the OTA back up to .748. now it has failed a third time to protect my root through the upgrade to .173. So as far as I can tell, Voodoo does not work and I followed everything I have done step by step according to the instructions. Anyone have any ideas on how to fixthis issue or have had the same problem? Please help!!!
#216 3a4yI7aTiY
3a4yI7aTiY
  • 22 posts
  • Twitter:3a4yI7aTiY
  • Google+:3a4yI7aTiY
  • LocationUkraine, Odessa
Posted 04 February 2012 - 12:32 AM
Root stock 6.11.748 with doomlord v2 root script, back up root with ota rootkeeper then install. 6.12.173 update. After intall restore root with ota rootkeeper ant all work great. if you root with superoneclick for windows rootkeeper dont restore .
root after install 6.12.173
Use only doomlord v2 root script for 6.11.748 , and root be working in 6.12.173 & 6.12.174 after restore with rootkeeper
#217 wyld
wyld
  • 845 posts
Posted 04 February 2012 - 03:58 AM
DooMLoRD_v3_ROOT-zergRush-busybox-su this the one i got and voodoo OTA rootkeeper works great for me. It even held up upgrading to .174
#218 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 04 February 2012 - 08:11 AM
Pretty much this. I've noticed that people not using doomlord's script are having trouble maintaining root through upgrades with rootkeeper.
#219 kobusestas
kobusestas
Posted 06 February 2012 - 08:30 AM
I am currently running stock and do not have root, If I apply this update will this make it so that I cannot receive any new OTA's in the future or will I still be able to receive them as normal?
#220 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 06 February 2012 - 08:40 AM
Unknown. Worst case you can RSD back to the upgrade path. This has been asked several times before. If the 173/174 updates go live then you'll still be on the upgrade path.
