[Boot Animation] - Frac-Droid And Other Odd Animations
#121
Posted 06 April 2013 - 10:33 PM
- JaeKar99 likes this
#125
Posted 02 May 2013 - 06:46 PM
- lowvolt likes this
#126
Posted 02 May 2013 - 07:06 PM
You are incredibly talented. Will these work on a RAZR M? Rooted stock 4.1.2 BTW. Would love to rock the. Blue ribbon android. Its dang sexy.
Yeah make some for the M
via Raging M that is color blind
- bwat1009 likes this
#127
Posted 03 May 2013 - 06:28 AM
I took a leap and tested the blue ribbons animation on my Razr M and it worked flawlessly... I didn't flash it though. I extracted the zip that I downloaded and cut out the bootanimation.zip and put it on my sd card. Then, i renamed the existing bootanimation.zip in the system\media folder to stockbootanimation.bak and cut and pasted the new one. rebooted and done. Looks awesome but then I stumbled across your sports themed ones and had to rock the Atlanta Braves one. that one I did flash through recovery and it went flawless as well.
#128
Posted 03 May 2013 - 09:59 AM
Anyone should be able to unzip the flash envalope and extract the bootanimation.zip file and do exactly as bwat1009 did above to use any of the Razr boot animations. The resolution is the same.
This IS my stress relief.
If you are feeling extra generous - I like coffee.
#129
Posted 03 May 2013 - 06:16 PM
#130
Posted 14 July 2013 - 05:30 AM
JaeKar99 you helped me create bootanis for the Fascinate. Its good to see you in the RAZR forums because your work is the F-ing TOPS! Thanks.
#131
Posted 14 July 2013 - 10:32 AM
Well - hello there!
Thanks.
Something I have just opted to do for fun..
Also tagged with one or more of these keywords: boot animation, custom
