[Boot Animation] - Frac-Droid And Other Odd Animations
boot animation custom
130 replies to this topic
#101 jrazrz
jrazrz
  • 26 posts
  • Current Device(s):droid razr cdma xt912
Posted 30 March 2013 - 10:19 PM
These look good! Do they work on official jb ota roms?
#102 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
  • LocationTwin Falls
Posted 31 March 2013 - 06:19 AM
Unlikely unless you have a custom kernel running.
This IS my stress relief.
If you are feeling extra generous - I like coffee.
#103 gobblinfool
gobblinfool
  • 23 posts
  • LocationElmhurst, Pennsylvania
  • Current Device(s):razr maxx
Posted 03 April 2013 - 02:56 AM
Ah.... ha ha ha!
Apple~Terminated:
ok.. i want to put this on my phone.. im currently running flying jelly.. when i download this file it is named 'Apple-Terminated-Rzr.zip' .. when i unzip this file, there is a bootanimation.zip file in it.. my question is do i use the bootanimation.zip located in the folder in replacement of the original bootanimation.zip that i will be renaming bootanimation.bak already there, or do i rename Apple-Terminated-Rzr.zip to bootanimation.zip and replace the orignal bootanimation.zip file.. im new to this so i want to do it right.. thanks
#104 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
Posted 03 April 2013 - 03:05 AM
Unzip the file and copy the bootanimation.zip file to data/local or system/media. If you copy to data/local you it should go into an empty folder and not replace the ROM boot animation. If you choose to copy to system/media it will either replace or your will have to rename the original.
j
#105 gobblinfool
gobblinfool
  • 23 posts
Posted 03 April 2013 - 03:18 AM
ok, thank you for clearing that up for me!
i guess im not able to do it with flying jelly ROM.. it wont let me rename the original bootanimation.zip nor can i delete it.
Edited by gobblinfool, 03 April 2013 - 03:30 AM.
#106 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
Posted 03 April 2013 - 03:36 AM
j
Very cool bootanimation.zip (apple destroyed one) worked like a charm.. would have never guessed there was a .zip hiding in the. zip!!
#107 iamhugger
iamhugger
  • 296 posts
Posted 03 April 2013 - 03:37 AM
root explorer
#108 iamhugger
iamhugger
  • 296 posts
Posted 03 April 2013 - 03:40 AM
Apple terminated works on JB ota, but iam sure u knew that!!!
#109 gobblinfool
gobblinfool
  • 23 posts
Posted 03 April 2013 - 03:51 AM
yes i know its in the root explorer.. but im assuming on the flying jelly ROM the permissions to delete/write are disabled on that bootanimation.zip file because it says failed when i try to rename it
#110 iamhugger
iamhugger
  • 296 posts
Posted 03 April 2013 - 04:08 AM
and the little box up in the corner says r/o?
#111 gobblinfool
gobblinfool
  • 23 posts
Posted 03 April 2013 - 05:59 AM
ah, i found it.. when in ES File Explorer, theres a setting for root that wasnt enabled.. durrr.. great boot animation.. are you still taking requests?
#112 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
Posted 03 April 2013 - 07:26 AM
Sure - What do you have in mind?
#113 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 03 April 2013 - 08:22 AM
Thanks for the animations. I just loaded and am running the Terminated animation on my Razr M. Good work!
#114 gobblinfool
gobblinfool
  • 23 posts
Posted 03 April 2013 - 08:42 AM
i love the terminator, can you do the animation with the electric green color instead of reds? with a glowing green eye and target acquired, etc all being green?
#115 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
Posted 03 April 2013 - 09:12 AM
Naw.. Got it done today...
Green Apple-Termi-Droid: (full rebuild)
#116 gobblinfool
gobblinfool
  • 23 posts
Posted 03 April 2013 - 02:37 PM
awesome! THANKS!
#117 portscan
portscan
  • 277 posts
  • Twitter:@JasonCollins23
  • LocationClarksville, TN
  • Current Device(s):Samsung Galaxy S4- Stock Rooted on 4.3/Samsung Galaxy Note 10.1- Redemption Rom v6.1
Posted 05 April 2013 - 03:30 PM
You still haven't figured out a work around with Jelly Bean?
#118 JaeKar99
JaeKar99
  • 222 posts
  • Twitter:JaeKar99
Posted 05 April 2013 - 03:38 PM
Without a custom kernel the bootanimation.zip won't play.
Sent from the 8th dimension using quantum entanglement.
#119 Langer6431
Langer6431
  • 36 posts
Posted 05 April 2013 - 04:23 PM
Could someone make the stock nexus 4 glowing X boot animation for the razr. That would be incredible.
#120 portscan
portscan
  • 277 posts
Posted 05 April 2013 - 07:15 PM
I have faith in you! You will get it!
Also tagged with one or more of these keywords: boot animation, custom
