[Boot Animation] - Frac-Droid And Other Odd Animations
#81
Posted 12 January 2013 - 07:56 AM
#83
Posted 12 January 2013 - 11:08 PM
#84
Posted 13 January 2013 - 08:23 AM
^^^ Freakin' awesome! God I wish these worked on the JB leak.. I would flash this one above with the quickness! Great work man!
I cannot find the boot animation file in the leak. Can you copy the OG file to me? There may be a code in the desc.txt file that is different.
Sent from the 8th dimension using Quantum Entanglement.
This IS my stress relief.
If you are feeling extra generous - I like coffee.
#85
Posted 13 January 2013 - 09:01 AM
I am using Dual Boot and have some JB ROM's and have tried some of your terrific Boot ani's and they work fine except no sound, which has to do with the ROM since their ani's have no sounds as well.
#87
Posted 13 January 2013 - 09:59 AM
I believe it the leak ROM that has the issues. Likely due to the kernel. Trying pin it down.
The JB ROMs are based on the leak....
#88
Posted 13 January 2013 - 10:27 AM
Sent from the 8th dimension using quantum entanglement.
#89
Posted 14 January 2013 - 03:11 PM
AWESOME!!!!!!!!!Ah.... ha ha ha!
Apple~Terminated:
tank you thank you thank you
#90
Posted 14 January 2013 - 03:44 PM
That helps.. it appears that the base leak does not like the boot animations in their current forms. It could be that the kernel requires some adjustment to play the custom. zips.
Thinking and looking at the posts, I believe the link you were given is the actual OTA JB update. I think the file you would need would be a ROM similar to what you have done already. If you want, there is a plain vanilla Jellybean ROM in the forum. Works fine on my setup, except for the sounds and I have heard others having issue with sounds as well.
#91
Posted 15 January 2013 - 02:34 PM
- JaeKar99 likes this
#93
Posted 15 February 2013 - 09:56 AM
#95
Posted 15 February 2013 - 03:13 PM
#96
Posted 11 March 2013 - 07:58 AM
Oh wait whats this I see here... Blue Tron Droid Boot Animation??? Wha??? Ok thats it, you are absolute KING in the Boot Animation section of this site.
Just give me a minute to warm-up my donation credic card... lol
Enjoy!
#98
Posted 22 March 2013 - 11:37 AM
Appreciate the effort you're putting forth trying to get this to work on the leak, Jaekar.. As soon as you do, Apple terminated is mine!
Its OK, I used to run ROMs on the Leak and they worked then, just give it a shot! Now I'm on the official OTA JB for my Razr and they are working here too! I now have Apple Terminated lol.
#99
Posted 23 March 2013 - 09:22 AM
I will try it again, but they were not working on the JB leak from Christmas before.
#100
Posted 23 March 2013 - 09:29 AM
Also tagged with one or more of these keywords: boot animation, custom
