Problems with my Huawei my Touch Q U8730
touch u8730
1 reply to this topic
#1 dpcarlos03
dpcarlos03
  • Twitter:@Paul_xromero4
  • LocationHonduras
  • Current Device(s):huaweiu8730
Posted 27 March 2014 - 10:15 AM
Hello friends.... , i got a problem with my Huawei MyTouchQ U8730 , i get locks when i turn on idk i have make, factory reset, put a new room ,delete cache and nothing the phone wont start it's freezed on "Android" can anyone help me? ill be so thanksful is someone help me out !! thanks...
#2 frankvii
frankvii
  • 16 posts
Posted 24 April 2014 - 12:07 PM
From your post, It is not clear what caused your problem.  All I can suggest is that you flash a stock ROM on the phone.  I believe this will fix any type of problem unless the phone is bricked.  So here's what you do:
1.  Download the stock ROM from here:  http://forum.gsmhost...l#post8821770.
(if you don't know which version ROM you have, I'd suggest trying the one ending in SP01 first and if that doesn't work, try the one ending in B845).
2.  Unzip the ROM and put the "dload" folder on the root of the SD card.
3.  Start the phone by holding VOL-UP, VOL-DWN and POWER (all three buttons being held down together).
4.  Wait about 2 minutes as the phone automatically installs the ROM.
That's it.  Your phone should be useable after that.  If not, I won't be able to provide more help (that is the extent of my knowledge/fixes for this).
Also tagged with one or more of these keywords: touch, u8730
