Dst Toolbox
34 replies to this topic
#1 mhous33
mhous33
  • 480 posts
Posted 25 August 2012 - 08:01 PM
*removed*
  • mattlgroff, johnlgalt, acordill and 4 others like this
#2 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 25 August 2012 - 08:31 PM
If I used a Bionic as my daily driver I would totally download this. Nice work!
#3 mhous33
mhous33
  • 480 posts
Posted 25 August 2012 - 09:58 PM
thanks, hope others find it useful :)
#4 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 26 August 2012 - 12:26 PM
DLing. I'll check it out.
#5 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 11:07 AM
This is a cool and fun toolbox. But how exactly do i use it to put in my own animations and logos?
#6 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 11:28 AM
thanks! glad you like it :)
there's a 'DST' directory on your internal storage; navigate to it in a file explorer. there you'll find the 'bootanimation', 'fonts', and 'logo' folders.
rename your custom bootanimation 'bootanimationCustom.zip' and put it in the bootanimation folder
rename your custom bold font 'bold.ttf' and custom regular font 'regular.ttf' and put them in the fonts folder
rename your custom logo 'logoCustom.bin' and put it in the logo folder
then you can go to the menu and select the custom option.
  • johnlgalt likes this
#7 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 11:31 AM
Right on man!! Thanks for the help!!!
#8 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 03:06 PM
Hey, i followed your instructions for the font and i ended up bricking my phone. Luckily we have FXZ!! Any ideas on what i did wrong??
#9 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 05:32 PM
by 'bricking your phone' do you mean it wouldn't boot back up? the shell script is designed to automatically reboot after overwriting the stock .ttf files, because it has to reboot for changes to take effect.
#10 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 06:57 PM
Sorry, yes that was what I meant. It got stuck on the boot animation for about 5 minutes so I figured it was not going to boot back up.
#11 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 07:07 PM
what font files did you use? were they .ttf?
#12 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 07:08 PM
Yah, I downloaded one and renamed it like you said. And yes it was a .ttf file
#13 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 07:11 PM
can you point me to where you downloaded the font or upload it post a link?
#14 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 07:36 PM
I tried to use the fearless font.
#15 SamuriHL
  • 44,416 posts
Posted 27 August 2012 - 07:50 PM
Hey sweet! I'll be checking this out tomorrow! Thanks!!
#16 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 08:14 PM
i got the same result, android does not like that font for some reason; i'm thinking maybe because it's such a heavy font. it has nothing to do with the toolbox though; i tried installing it with a flashable zip in clockwork and same thing happened.
cool, hope you like it. big fan of your work. although i haven't gotten stuck, nice to know there's a plan b :)
#17 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 09:23 PM
Ok thanks! I never questioned your toolbox, sorry if you felt that way. I knew it was something on my half. Thanks for the help!
#18 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 09:54 PM
Also would Safestrap affect it in any way?
#19 mhous33
mhous33
  • 480 posts
Posted 27 August 2012 - 10:10 PM
no problem!
nah, it shouldn't matter whether you use it with bootstrap or safestrap.
#20 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 27 August 2012 - 10:51 PM
ok trying this one more time since im finished FXZing. So the same font as i use as my regular, im going to use as my bold but just name it bold instead of regular?
