How To Unlock Your Bootloader [Vzw Sgs3]
22 replies to this topic
#1 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 25 August 2012 - 11:33 AM
Well thanks to the hard work of many develoupers over at XDA and with the help of the community they got ahold of a unsecure aboot.img , that allowed us to break the wall that VZW put up. I am going to post the EZ Unlock way and post the manual way. Simply folks this does not get any eaiser then this.
EZ Unlock can be found in the Play store -------->
Big thanks to mmmeff for making two great EZ apps for us. His other app EZ Recovery can be found in the play store as well.
Just download the app and click unlock. Yep thats it. "NOTE" You must be rooted to use this app.
mmmeff
Here is another way to unlock if you want to do it threw ADB or Terminal on your phone. Download the aboot.img and put it on your SD card or push it .
aboot.img download >>>>>>>>>>
MD5= 0ba9ad45fc15cf3d62af7dd363686b3f
___________________________________________________________________________________________________________
1) adb push aboot.img /sdcard/aboot.img
2) adb shell
3) su
4) dd if=/sdcard/aboot.img of=/dev/block/mmcblk0p5
**** VERIFY YOU HAVE A MATCHING MD5 SUM >>>> 0ba9ad45fc15cf3d62af7dd363686b3f ****
5) dd if=/dev/block/mmcblk0p5 of=/sdcard/abootTEST.img
6) reboot
You can also do this threw terminal on your phone. Just put the aboot.img on the root of your SD.
1) Open terminal
2) su
3) dd if=/sdcard/aboot.img of=/dev/block/mmcblk0p5
4) dd if=/dev/block/mmcblk0p5 of=/sdcard/abootTEST.img
5) reboot
As i said before after you flash or before you flash and reboot the phone. Check the md5 sum if they match then reboot and profit . You can use Root explorer or md5 checker, 7z to check the md5 . I cant stress this enough. If you download the aboot file and already put in on your SD card you cand just flash it ,you dont have to push it.
Big thanks to Adam Outler for his time and effort and all DEV'S out there.
  • kpeiczarek likes this
#2 kpeiczarek
kpeiczarek
  • 25 posts
Posted 25 August 2012 - 11:46 AM
you guys are the best thank you everyone invloved in this
#3 Groundhound
Groundhound
  • 132 posts
Posted 25 August 2012 - 11:47 AM
Wait.....This is NOT April 1!
#4 Guest_DirtyDroidX_*
Guest_DirtyDroidX_*
Posted 25 August 2012 - 11:56 AM
Lol this is for sgs3 .
#5 Groundhound
Groundhound
  • 132 posts
Posted 25 August 2012 - 12:06 PM
Glad I didn't try to run it. I need to pay more attention to the board name when I click the "View New Content" button. The app listing on the Play store shows it as compatible with the Razr, which can be confusing if you don't immediately recognize the "GS3" part of the app name "VZW GS3 EZ-Unlock"
#6 kpeiczarek
kpeiczarek
  • 25 posts
Posted 25 August 2012 - 12:10 PM
yeah i realized that when i went to go download it, i was like crap so much for reading things thoroughly beforehand
#7 james
james
  • 620 posts
  • Locationsouthern cali
  • Current Device(s):LG G2 Verizon
Posted 29 April 2013 - 06:42 PM
will this work for jellybean as well i downloaded the 1.2  from the link or should i grab the newest one(1.4)
#8 Guest_BDH_*
Guest_BDH_*
Posted 08 May 2013 - 05:27 PM
Yes it works for Jellybean. Always use the most up-to-date version.
#9 droidian1441
droidian1441
    News Leader
  • News Team Leader
  • 474 posts
  • LocationVirginia
  • Current Device(s):HTC One M8 (primary); Nexus 7 (2013)
Posted 08 May 2013 - 05:50 PM
Not always. In this case he should use 1.2, 1.4 doesn't work and the dev never updated the app. 1.2 works just fine though.
Sent from my DROID RAZR MAXX HD using Tapatalk 2
HTC One M8 // 3.28.605.4 // CleanROM 3.0 w/HarmonKardon audio // Android 4.4.4
n5SOtgv.jpg - "White Noise" out November 4th!
(Recommended)
#10 JustAGuy
JustAGuy
    This is only a test
  • 4,258 posts
  • LocationSouthern New Hampshire
  • Current Device(s):Pixel 2 XL, Z300M, Nexus 7
Posted 23 May 2013 - 03:03 AM
I can verify this too. I had 1.4 and "unlocked", but when I flashed CWR, I got the Verizon yellow triangle of death. Using 1.2 to unlock fixed that problem.
Pixel 2 XL, Pixel XL, Nexus 6, Nexus 5, Nexus 7,  Samsung GS3, Bionic, OG Droid, SCH-i760, a flip phone or two, and a few others.
#11 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 26 May 2013 - 05:38 AM
Looks like EZ Unlock got pulled from the play store. Anyone have 1.2? Planning on getting the S3 in the next few days but may reconsider if I can't unlock the boot loader. One of the reasons I want to ditch my OG RAZR.
Sent from my XT912 using Xparent Cyan Tapatalk 2
#12 JustAGuy
JustAGuy
    This is only a test
  • 4,258 posts
Posted 26 May 2013 - 08:20 AM
Try
#13 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 26 May 2013 - 09:07 AM
Thank you sir! Just out of curiosity how're you enjoying your S3? Pros? Cons?
#14 nin
nin
  • 144 posts
  • LocationPA
  • Current Device(s):Galaxy S3
Posted 26 May 2013 - 09:32 AM
thought i'd just throw my 2 cents in
i was on the razr maxx
but i'd have to say i enjoy the s3 better
all the motions that it has are great
nfc
patched google wallet
and much more
only con i'd say would be the battery
but zerolemon battery took care of that
i'm not out for looks of phone just as long as i don't have to charge it all the time
and just to throw it in there hyperdrive is a nice rom alot of different options to choose from
and another thing i love about the s3 is i bought a
micro usb otg to usb 2.0 cable
plug in jump drive and transfer files to phone or from phone to drive
#15 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 26 May 2013 - 10:42 AM
Thanks for the info NIN (Trent Reznor is the shyte!!!!). I was checking out zero lemon earlier today. Puts quite a bit of heft on the phone but it is nice not having to charge as often as I do now with the Razr.
#16 nin
nin
  • 144 posts
  • LocationPA
Posted 26 May 2013 - 11:07 AM
yw any other info i maybe able help ya with just ask
and ya zero lemon is hefty personal preference i guess
and of course nine inch nails twenty thirteen
can't wait till they tour the states
  • raijin32 likes this
#17 Guest_BDH_*
Guest_BDH_*
Posted 26 May 2013 - 01:37 PM
I didn't go with zero lemon, instead I got a cheap 6280mAh off ebay for only $20. Well worth it. Phone lasts 2 days on 1 charge with moderate use.
#18 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 26 May 2013 - 02:25 PM
Does it add a lot of bulk to the phone Hicks?
Trying to get the guy on Swappa down to 290.00 from 320.00. He lives here in Miami so I may be getting the phone sooner than expected.  :D
#19 Guest_BDH_*
Guest_BDH_*
Posted 26 May 2013 - 02:41 PM
It makes it alittle bulkier but not much at all. As soon as I can get a pic of it i'll upload it. After adding the extended battery, it's now about the same weight as the OG RAZR.
#20 raijin32
raijin32
  • 277 posts
  • LocationMiami, FL
Posted 26 May 2013 - 02:45 PM
I can live with that.
