![](http://www.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
Gps Problems? Try This
Guest_DirtyDroidX_*
Posted 25 August 2012 - 09:47 AM
You need to be rooted to be able to grant R/W capabilities. To be safe , always make a nandroid backup and back up the original file you are replacing. My self or DroidRZR are not responsible for any malfunction to your device or anything else that may occur, while hacking your phone.
1) Download new gps.conf file>>>
2) Replace it in /ect . Rename the original one from .conf to .bak. using a file explorer with R/W enabled , so yes you have to be rooted!
3) Download GPS toolbox
4) Reboot.
5) Enable standalone GPS and Google services NOT Verizon services.
6) Open GPS status select options/tools/reset . Then options/ tools/download
7) Reboot
8) Open GPS status and wait for lock . Mine took 5 min a friends took 3. Then open up navigation .
9) Profit
★★NOTES★★
Always enable standalone GPS and Google location services ,FIRST! Then open up GPS toolbox to get a lock. The first time you do this it might take up to 10 to 15 min based on your location. After getting a lock threw the app, then open up navigation and you should be good to go. After using this yesterday I'm locking on in under 5 sec with 9-15 sat locked on. If you have bit used your GPS in a while, open app and reset and download again , then reboot. Then wait for lock threw app and your back on track.
Hope this helps a few and I will be updating this when I finish implementing other things.
DirtyDroidX
- mugsy77 and jw0914 like this
Posted 25 August 2012 - 12:23 PM
Posted 25 August 2012 - 01:09 PM
You think this would work on a razr?
Shouldn't hurt. Looks to be a standard gps.conf for NA/USA and GPS Toolbox is likely just forcing an update from the agps servers.
Guest_DirtyDroidX_*
Posted 25 August 2012 - 02:44 PM
Posted 25 August 2012 - 03:10 PM
Thanks for making it easier to implement because every time I've suggested it, its drawn a bunch of whining for its complexity.!
Posted 25 August 2012 - 05:57 PM
Posted 03 October 2012 - 08:33 PM
Thanks =]
Guest_DirtyDroidX_*
Posted 04 October 2012 - 04:12 AM
can you re-up the gps.conf file please? Your dropbox link no longer works, file is no longer there.
Thanks =
Here you go.
Posted 06 October 2012 - 05:13 PM
Posted 07 October 2012 - 12:22 AM
Here you go.
Thanks mate =]
