How to get AT&T 4G/LTE on XT925 from Claro PR?
10 replies to this topic
#1 chiquito3
chiquito3
  • Current Device(s):Razr HD XT925, AT&T HTC One
Posted 16 March 2014 - 01:56 AM
Hello guys,
I have a Razr HD XT925 from Claro Puerto Rico on AT&T and I have not been able to get 4G/LTA. Some people tell me my phone is not compatible other that I need a different firmware modem.
I tried flashing Rogers modem from Canada but it did not work. Only get H+ data services with original Claro Firmware and the modified one with the Rogers Modem.
Can you please help me with my problem?
Thanks in advance
#2 cmh714
Posted 16 March 2014 - 09:30 AM
take a look at this maybe...
#3 cmh714
Posted 16 March 2014 - 09:35 AM
I see you have posted this as well over at xda obviously with little luck. I see some think your SOL. You probably need the radio from the Claro PR ROM and then mess with settings.
Did this work on the stock rom? whats changed that made it not work.
#4 cmh714
Posted 16 March 2014 - 09:42 AM
it is possible that you are SOL. The specs for the 925 are:
LTE 800 / 1800 / 2600   LTE 700 / 800 / 1700 / 1800 / 2600
PR does 1900/850 according to what i can find.
#5 chiquito3
chiquito3
Posted 16 March 2014 - 09:53 AM
It works with Claro but not with AT&T at least that is what some people say. It is a Claro PR branded phone and I'm using it with AT&T but the 4G/LTE is not working and that is what I want to fix if there is a possibility.  Thanks for your reply!!
#6 cmh714
Posted 16 March 2014 - 10:25 AM
not sure ....is the APN settings for AT&T correct?
#7 chiquito3
chiquito3
Posted 18 March 2014 - 01:18 PM
Yes APN are correct. It does not get 4G or 4G/LTE
#8 cmh714
Posted 19 March 2014 - 06:04 AM
Sorry chiquito, I dont think I have any more ideas for you...
#9 BurriToS
BurriToS
  • LocationPoland
  • Current Device(s):XT925
Posted 02 April 2014 - 12:49 PM
I have the same issue. I have phone from Claro PR but I am from Europe. The LTE does not working due to wrong frequency.
Should I upload a new modem driver ? or should I flash my phone ?
My phone is rooted and I have unlocked bootloader.
#10 vze3dh95
vze3dh95
  • 12 posts
Posted 05 September 2014 - 12:37 PM
are you using it with att, or att via straight talk? cause you will only get h+ and will never hit h++
#11 vze3dh95
vze3dh95
  • 12 posts
Posted 05 September 2014 - 12:39 PM
ahh, i see you are still in puerto rico. i thought you were in the states.  sorry.  have you gotten the unlock codes from claro to unlock the gsm?
