Screen Resolution Problem
2 replies to this topic
#1 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
  • LocationThe Southern State That Started It All.
  • Current Device(s):Raspberry Pi, Droid Razr Maxx HD XT926 - Droid Razr XT912 - TF201 Asus Transformer Prime
Posted 15 March 2014 - 07:15 PM
I have a 21.5 inch monitor and no matter what I try it will not go full screen.
I have it hooked up via HDMI and tried a settings on the monitor.
Anyone have a suggestion?
''Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.'' - Albert Einstein
#2 Malakai
Malakai
  • 56 posts
  • Twitter:@Raspians
  • LocationUSA
  • Current Device(s):Pi, iPhone, etc..
Posted 15 March 2014 - 07:21 PM
Try looking over these settings in
sudo nano /boot/config.txt
http://elinux.org/RPiconfig#Video
It's also can be edited from the visible partition on the SD Card from a PC or in a MAC
More info in this thread:
http://www.raspberry...php?f=28&t=7693
hdmi_drive= 1
hdmi_group=2
hdmi_mode=58
The above is an example:
hdmi_drive=1 Normal DVI mode (No sound)
hdmi_drive=2 Normal HDMI mode (Sound will be sent if supported and enabled)
hdmi_group=1   CEA
hdmi_group=2   DMT
hdmi_mode=58   1680x1050 60Hz
  • GTIM2L8 likes this
#3 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 16 March 2014 - 12:56 PM
Thanks Malakai.
It turned out to be easier than I thought.
I just opened LXTerminal on my Raspberry and entered the following command:
sudo nano /boot/config.txt to open the config.txt file for editing.
Then I just uncommented the line disable_overscan=1
Ctrl + x then Y to save it then sudo reboot.
Voila, I now have a full screen.
Thank You Sir.
