Raspberry Pi give away winners, Report!
Raspberry Pi rasbian arch linux unix
90 replies to this topic
#61 Brutus06
Brutus06
    Drunken Monk Brewery
  • 407 posts
  • Google+:leereitz12@gmail.com
  • LocationSouth Dakota
  • Current Device(s):Bionic(retired), Lenovo Tablet, Moto G
Posted 07 April 2014 - 05:02 AM
You may want to try Rasp BMC instead.
I found xbian to be laggy as OpenElec as well. Let us know how it works out.
Sent from my DROID RAZR HD using Xparent Red Tapatalk 2
Interesting. The info I found suggested otherwise. Openelec was listed as a lightweight xbmc only implementation. Lacking on functionality but more responsive. Rasbmc was explained as being built on top of the rasbian os giving it more Linux functionality but making it laggy and slower to boot. Xbian was supposed to be the compromise of the two.
I'll probably try all three as well at some point. SD cards are cheap.
Sent from my SCH-I535 using Tapatalk
I believe you will find both of them being slightly laggy compared to a say a laptop running media center software. I have not tried Openelec but I know with Raspbmc you have to be patient. There are times with my center you have to wait several seconds for screen to render but given the hardware its running on that is to be expected. Using a Pi as a media center real strengths are being completely silent and low power usage. I am really glad I don't have to have a noisy laptop or mini pc hooked up to the tv.
I have been curious if stacking two Pi's together will help with the lagginess, if anyone tries this I hope you post your results.
#62 s3inks
s3inks
    Budding Zymurgist
  • 872 posts
  • Current Device(s):Moto NX6
Posted 07 April 2014 - 01:49 PM
After multiple trys, I could not get a clean install of xbian. Each time the RPI would not boot. I'm going to try flashing noobs and then installing raspbmc. I've been using xbmc on some android stick PCs. They lag a little compared to my desktop. I'll post back about a comparison.
#63 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
  • LocationThe Southern State That Started It All.
  • Current Device(s):Raspberry Pi, Droid Razr Maxx HD XT926 - Droid Razr XT912 - TF201 Asus Transformer Prime
Posted 07 April 2014 - 03:00 PM
Try downloading the individual files from the sources.
My experience with the "Noobs" card seem to have some corrupted or old files.
Try downloading RaspBmc alone and install it then let it set for a few minutes while it updates.
When it boots and updates itself go to the power icon and click on it and select "Exit".
This will give you the option for a command line or reboot on the Pi itself by pressing escape and choosing the command line option.
Then you can run the sudo apt-get update and sudo apt-get upgrade commands locally to get the latest updates.
I just finished updating one of the 2 I just bought of off Ebay and it is definitely a lot snappier than the stock that was provided.
Xbian and OpenElec caused me problems personally. OpenElec especially with just mouse movement being erratic and hard to control.
What are you using to format the card you are using and writing the image to it?
  • s3inks likes this
''Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.'' - Albert Einstein
#64 s3inks
s3inks
    Budding Zymurgist
  • 872 posts
Posted 07 April 2014 - 03:03 PM
I'm still wiping the SD card so I'll go your route since you've had good luck.
Is it a drag and drop install after downloading and extracting the files?
#65 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 07 April 2014 - 04:53 PM
I'm using windows so I download the .img files.
I am using SDFormatter to format the card as it formats the system part in FAT32 and the rest in EXT4.
Use the Full erase option and the format size adjustment set to "ON".
Then I use Win32DiskImager to write the image to the sd card.
I tried a lot of things but the instructions I posted earlier work best for me.
Using the command line directly on the Pi OS seems to work best especially to update the file you downloaded.
#66 s3inks
s3inks
    Budding Zymurgist
  • 872 posts
Posted 08 April 2014 - 03:25 AM
Well, I thought it was a bad install. On my last reformat I did a full overwrite which took about 5x longer than just a full format. I thought this was going to make the difference. I DL'd the raspbian image and mounted it using the suggested method. Plugged the card info the pi and still nothing. To verify the pi still worked I popped the original card in and the pi fired right up.
I'm now thinking it is the new card the pi doesn't like. I've got another I'm going to play with today. It is a branded card instead of the generic one I was using yesterday. I'll post some results later.
#67 Brutus06
Brutus06
  • 407 posts
Posted 08 April 2014 - 04:55 AM
There is a table on this webpage that may help with the SD cards, maybe you have an SD card that has been verified not to work on with RPi. http://elinux.org/RPi_SD_cards
#68 livinginkaos
Posted 08 April 2014 - 04:56 AM
Make sure also that it is formatted in the proper format.
Sent From My DEV X
#69 s3inks
s3inks
    Budding Zymurgist
  • 872 posts
Posted 08 April 2014 - 05:01 AM
He was in Denver, I though he lived in NY?!?!?!?
My first go was with a generic card. I'm using a pny brand this time. The card is smaller capacity so I'll be unable to tell if that was also a factor.
Sent From My DEV X
I'm using the formatting tool from the SD card association's webpage as suggested by the RPi wiki. It seems to not have any settings other than the type of erase: quick, full or overwrite.
Edit:
I just achieved successful boot of raspbian. It is going through setup now. Seems the generic card was to blame. I'll post my thoughts on how it performs a little later.
#70 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 05:12 AM
Make sure you set the format size to "On". I also had a card that worked fine at first but then would not boot back up. It worked on other equipment but would not on my Pi. Still working on that one.
#71 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 05:14 AM
You may also use the mini partition tool that's available online. Most Linux users preferred that method.
  • livinginkaos likes this
#72 s3inks
s3inks
    Budding Zymurgist
  • 872 posts
Posted 08 April 2014 - 05:31 AM
Which utf locale code did you choose? I picked en.us.utf8. However after I chose my timezone my system time is wrong. Did you configure WiFi through xbmc settings?
#73 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 06:53 AM
I used the same utf locale and my time did not change either. It said you had to change it in xbmc also which it was late last night and didn't make sense.
I configured the WiFi from programs and Rasp BMC settings. Just tick on the big icon at the bottom.
#74 Guest_Dalvik_Cache_*
Posted 08 April 2014 - 07:03 AM
I'm going to use mine to make a CDMA war driver tool.
Sent from my A500 using Tapatalk
#75 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 07:41 AM
You nay need one of these Monitors then.
Looking for free wifi or cloning someones phone? Hahaha....
#76 Guest_Dalvik_Cache_*
Posted 08 April 2014 - 07:43 AM
Neither... Network Id and performance
  • GTIM2L8 likes this
#77 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 08:17 AM
Hmm. Nice idea :)..
#78 Brutus06
Brutus06
  • 407 posts
Posted 08 April 2014 - 10:13 AM
Edit:
Looks like PNY has 7 models that have issues
#79 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 03:25 PM
<p>This looks interesting!: <a href="http://www.element14...-compute-module">http://www.element14...-compute-module</a></p>
<p>&nbsp;</p>
<p>Different images anyone? <a href="http://www.raspbian.org/RaspbianImages">http://www.raspbian.org/RaspbianImages</a></p>
<p>&nbsp;</p>
<p>Software? <a href="http://www.raspbian....pbianRepository">http://www.raspbian....pbianRepository</a></p>
<p>&nbsp;</p>
<p>Looks like I'll be adding a little shot of NO2 to the Pi.</p>
Ok, after a copy and paste I now have HTML tags showing up in my post, WTH!!
#80 GTIM2L8
GTIM2L8
    A Man On A Mission!
  • 89 posts
  • Twitter:@GTIM2L8
  • Google+:gtim2l8
Posted 08 April 2014 - 04:14 PM
Try these commands and see if you can get the locales right.
You may not need the keyboard command.
You will have to reconfigure your timezone after the first boot:
dpkg-reconfigure tzdata
The keyboard layout:
dpkg-reconfigure console-data
And the localization:
dpkg-reconfigure locales
Also tagged with one or more of these keywords: Raspberry, Pi, rasbian, arch, linux, unix
