[Rom][Bionic] 8-25-2012 - Liquid-Blur-*v1.1R2*-Jmod
111 replies to this topic
#1 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
  • LocationStarkvegas, Mississippi
  • Current Device(s):Galaxy S4 Active
Posted 23 August 2012 - 11:36 PM
CHANGED BASE to MotoICSBean!!!
#This one should make up for all the broke builds!!!!!
#MUST FLASH MY DATAPACK OR WILL BREAK IT!!! ITS UNIVERSAL TO V1.1 ALL
Changes for V1.1
-Updated Camera ICS
-Force Format Script added to Update Script
-Added True AwesomeBeats Audio (All Modules)
-Added/Updated Google Now M7
-Added All apps from LIQUID ICS
-Jelly Bean Boot Anitmation
-Added OneX and Tbolt Ringtones
-Added GPS Fast Lock Fix
-New JellyBean Nexus Boot Animation
-Windows animatons 200 for better battery
-Added Toggle Menu Customizer
-Added Nova Launcher
-Added Liquid Tweaks to Init.d
-Build.prop Tweaks
-Tweaked Signal Type on boot
-Added Tweakers Kernel Modules
-1% Battery Icon for Blur
Changes for 1.1R2 (Patch Release)
-Fixed/Changed to AOSP Email SSL
-Added VVM
-Edited bug2go script to Block your Serial :)
NOTES:
1. Google Now, Youtube, And Google Play Music are included in the DATAPACK
2. Nova Launcher can be Uninstalled, BUT IT IS THE DEFAULT LAUNCHER!
Removing it will cause a dead in the water effect if you dont have a
alternative installed.
#BUGS
- Camera Panorama FC most the times
-Adaway cant create symlink (Go get Adfree)
- Nothing serious as of now
-Google Now Wont stop Searching from Voice
QUESTIONS
-What is datapack? It is all the custom apps and gapps needed to function. Split rom in half for Safestrap to
installwith no errors or glitches with the size limit. Google Now, Music, Etc.. is included
Posted ImagePosted Image
PLEASE: FORMAT DATA, AND SYSTEM PARTITION FOR CLEAN INSTALL
Downloads (HOSTED ON OUR
LIQUIDSMOOTH BLUR V1.1R2 FULL:
MD5sum:65dce54161110e7936b0da5cf7572471
LIQUIDSMOOTH BLUR V1.1 to V1.1R2
Upgrade Patch:
MD5sum:4cec2fc339367355a0edcce35918d89b
Downloads For V1.1
LIQUIDSMOOTH BLUR V1.1:
MD5sum:bd91cd93e88eb1de5a957aa2a20846a6
LIQUIDSMOOTH BLUR V1.1 AOSP EMAIL SSL FIX:
IF YOU HAVE THE FIRST DATAPACK YOU CAN STILL USE IT!!
Its the same package just renamed.
JMOD CM9/BLUR DATAPACK V1.1:
MD5sum: 83550bfad44dda8bcb55123936ce671d
  • mattlgroff and basoodler like this
>> I'VE BEEN AROUND A WHILE. LETS GET TO IT <<
Current Device: AT&T Samsung Galaxy S4 Active
Retired Devices: Moto Droid, VZW HTC Thunderbolt, VZW Moto Droid Bionic
#2 mrlolli
mrlolli
    Put Member Title Here
  • 763 posts
  • LocationNowhere
Posted 24 August 2012 - 05:42 AM
Looks sweet! Downloading now... :)
Sent from my XT875 using Xparent Blue Tapatalk 2
Nice job on the signature, jl90...thanks!
#3 basoodler
basoodler
  • 25 posts
Posted 24 August 2012 - 06:00 AM
Truly awesome news! Downloading now!
#4 basoodler
basoodler
  • 25 posts
Posted 24 August 2012 - 08:12 AM
Hey you got wifi teather working in blur :D
Everything works great.. Data comes right up, and battery looks good.
I do miss the options in the settings,.but think this.is a good step in the right direction
#5 kc69
kc69
    Droid Elite
  • 1,057 posts
  • Google+:kcmj6969@gmail.com
  • LocationEast Bernard TEXAS
  • Current Device(s):RAZR HD
Posted 24 August 2012 - 09:28 AM
I like it Matt pretty smooth after setup.
TEXAS state of mind
#6 deduct
deduct
  • 234 posts
Posted 24 August 2012 - 09:49 AM
Does visual voicemail and lockscreen animation work on this like it does on motoicsbean? If so I will give it a go. Thanks
#7 basoodler
basoodler
  • 25 posts
Posted 24 August 2012 - 10:11 AM
I can cofirm the lockscreen works.. From what i can tell if it works on bean it works on this
#8 basoodler
basoodler
  • 25 posts
Posted 24 August 2012 - 10:12 AM
Can i request that swipe kb be replaced in the next version :P
#9 FarmerKaine
FarmerKaine
  • 24 posts
Posted 24 August 2012 - 10:32 AM
I personally love Swype. It took me a good two weeks of swyping to get my dictionary set up and usable, and I occasionally have to add a few words that I would normally not have to add if I wasn't swyping across letters, but once you get used to it... Swype owns.
I came from a Blackberry mentality a couple years ago (3 BB's in a row), and I really wanted a physical Keyboard, so I got an Ally (decently priced and average features at the time)... I hated the keyboard on it, so I started using the soft keyboard. It was surprisingly easy for me. Therefore, when I changed it out for a Droid Charge (it got stolen later on) with Swype, then a T-Bolt (crap, from Asurion), then a Bionic through Asurion... I've stuck with Swype and can way outperform other people in my office both in accuracy and speed when it comes to typing anything on my phone. Granted, every single other person has an iPhone, so I naturally have an advantage to begin with... but still.
#10 FarmerKaine
FarmerKaine
  • 24 posts
Posted 24 August 2012 - 11:27 AM
Been running this ROM for a couple hours with no issues...
I usually just wipe cache/dalvik before a new ROM - yeah yeah, I know I should wipe data too, but I'm sooooo lazy.
However, this time, I wiped data, installed the ROM, installed the pack, and it all came up perfectly. Some stuff I've noticed, and can duplicate if I really wanted to:
#4 LiquidBlur: Quadrant is 2526. CPU is 1.0GHz. Phone seems to run very smooth, and GPS locks quick.
#3 SpeedLite: Quadrant is 2521. CPU is 1.0 GHz. Phone was very smooth, and GPS lock was fair to good.
#2 RedHead Rebirth: Quadrant is 2859. CPU is 1.2 GHZ. Phone was smooth, but lagged a bit going in and out of Chrome. Didn't try GPS at all.
#1 BlackholeBionic: Quadrant is 2601. CPU is 1.0 GHz. Phone was smooth and stuff, but I didn't try much because I quickly started crackflashing more ROMS - see above.
This is interesting... My CPU was faster with RedHead. I thought it was just a fluke, so after SpeedLite, I flashed RedHead back to my phone and the CPU was again 1.2. I put SpeedLite back and it was down to 1.0 again. I then wiped completely, and flashed LiquidBlur - 1.0 GHz as well. Now, I don't mind 1.0... though the Quadrant looked nice on 1.2 as shown above. But... Chrome was choppy at times, and lagged upon launch as I mentioned also, whereas it's just normal delay on the other ROMs I've tested so far.
I don't have some scientific benchmarks... I'm just crackflashing today, and putting the phone through some basic nonsense. I thought I'd share some experiences with you folks, however... as that's what the forum is all about.
  • SPJESTER and idivorceyou like this
#11 Halloween240
Halloween240
  • 83 posts
  • Twitter:Twitter.com/Halloween240
  • Google+:Halloween240
  • LocationCharlottesville, VA
Posted 24 August 2012 - 11:28 AM
Just Flashed this, seems to be running like a charm besides G-Now which hasn't worked well on any roms I have flashed so far, I can live without it, thanks for the awesome rom!
#12 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 24 August 2012 - 12:27 PM
make sure before you flash, you manually Format System, Format Data and erase Davlik Cache. Format is just a extra step i take to make sure its a fresh install. And make sure u tap the search bar on home screen. And go through the setup like in my screenshot above
#13 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 24 August 2012 - 02:03 PM
fixed thread links
#14 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • Twitter:kcalebcole
  • LocationColorado
  • Current Device(s):Motorola Droid RAZR M
Posted 24 August 2012 - 02:33 PM
Excited about this one.
#15 smileythom
smileythom
  • 389 posts
  • LocationCA
  • Current Device(s):Droid Bionic, Galaxy Tab 2 7.0"
Posted 24 August 2012 - 03:49 PM
Hey I thought webtop didn't work with safestrap! Well it does with this rom! Hurrah!
#16 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 24 August 2012 - 03:51 PM
Its blur? it should work lol
#17 nkmhockey
nkmhockey
Posted 24 August 2012 - 04:14 PM
Everything looks great - good job! I just have a question: is the /system partition supposed to be full by default? I did a clean install, full wipe of everything, and the system partition is completely full - 308MB used. Everything appears to be working correctly, just curious if this is normal - thanks!
#18 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 24 August 2012 - 04:16 PM
idk whats going on with that. It says its full but its really not... Might be a safestrap issue since we do have a preinstall limit. But doing the datapack was my only way around it and still get the rom to boot.
#19 nkmhockey
nkmhockey
Posted 24 August 2012 - 04:36 PM
That's fine with me - I just wanted to make sure I didn't mess something up during the install. Thanks for the quick response - everything is working great! Very fast - keep up the good work!
#20 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • LocationColorado
Posted 24 August 2012 - 05:10 PM
Anyone else have issues with Google Now?
It will launch, but it doesn't have the voice activation and voice search never stops listening.
