[Rom](Razr-Cdma) Flick 5.0 Tornado [12/3/12]
Blur based ICS deodexed Bytecode Flick inverted AOSP Razr CDMA
2610 replies to this topic
#1 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 23 August 2012 - 06:54 AM
POPULAR
What I wanted to do when I started to create Flick was make a ROM that was smooth, optimized and minimalistic, but fully tweakable, had the features I wanted and only what I wanted. I feel like I've succeed! :)
Thanks to:
Google for being so awesome!
tablecrasher - Hosting space! :)
vtwinbmx and 2tealth for helping me out when I needed it..
Nitro and EmericanX for doing what they do for us.
Whirleyes for letting me use his Kernel modules.
Kebob - The .215 base.
Kebob - For making the toggles for Blur ROMs.
Kebob - For helping me out with so much all the time.
Kebob - For some code that I used as a guide to put apps in Settings
Kebob and Matt - For the Atrix HD Launcher and widgets from other Moto phones.
andlaw, and HouseMD, and especially DSGMach1 for helping me with themeing!
24v - Being 24v :P
Nitro - for the original Pulldown toggles
Nitro - For the "quickpanel" toggles
Nitro - For the android.policy.jar
SmurfedOut - For some of the tweaks.
halo13 - For recoloring the battery icons
andlaw - For helping me black the ROM out
rgocal - For being inspiring and for libs and EGL stuff
EmericanX - Just cuz
EmericanX - Blacked out Gnow, Phone, Conacts
gytole - For the noob guide
PM me if I forgot anything, I want to credit you :)
Don't post this thread anywhere else! I will post this on other sites, I just want to make sure everybody is getting the experience that I wanted them to get!
Thank you!
The Tweaks:
  • Debloated
  • Deblurred
  • Deodexed - Kebob's .215 base
  • Zipaligned - Kebob's .215 base
  • Ziapligned at boot
  • Database files defragged at boot
  • Supercharged services.jar
  • Ultra fast GPS lock on
  • Kernel tweaks for battery life
  • All kinds of network tweaks
  • Dalvik VM tweaks
  • Launcher locked in memory
  • Scrolling tweaks
  • SUPER smooth scrolling
  • bugtogo.sh removed
  • 100% V6 Supercharged
  • SIO as default I/O and pegasusq as default CPU Governor
  • More soft rendering by Android via egl.cfg edits, less response latency
  • Faster data connection via ppp-ril.options
  • Built in tweaks for:
  • Pegasusq
  • Ondemand
  • Interactive
The UI:
  • 1% battery mod - EmericanX and halo13
  • AOSP as much as possible
  • Pulldown Toggles
  • It's BLACK
The apps:
  • Inverted AOSP Phone
  • Inverted AOSP Contacts
  • Inverted AOSP Messaging
  • AOSP Clock
  • AOSP Gallery
  • Inverted AOSP Calendar
  • AOSP Calculator
  • Inverted GTalk
  • Razri Camera
  • Root Browser Lite - JRummy16
  • Google Play Music
  • Apex Launcher
  • Gmail
  • Swype
  • Blur Email
  • Smart Actions
  • Google Now
  • Apps in Settings:
  • Beats Audio
  • No Frills CPU Control
Extras:
  • Zipalign and sqlite3 binary included
  • CM9 sounds
  • Sysctl enabled
  • Init.d support
  • Extra Kernel Modules:
  • Pegasusq
  • hotplugx
  • SIO
Known Issues:
Can't install Google Calendar from the market.
Coming next:
Most likely last big release Flick Prime:
No-nonsense
Every bug that I know of will be fixed
Screw Benchmark scores
It will have more than sufficient battery life.
It will have some apps with added functionality that should have been there in the first place.
More original and stylized UI/ theming
More optimized and minimal all around
This is estimated to be out at after Christmas.
Suggestions????????????
Let the ROM settle for 5 minutes, just let your phone sit.
Complete setup
Reboot
Profit?????????????????
Flashable zips:
Extras:
Important: When applying the overclock, you now have to delete "UV" in /system/etc/init.d.
Copy those files into /system/etc/init.d to get the corresponding overclock.
Donations mean a lot to me, but is by no means necessary. Thank you for your consideration.
  • Nubia1, vannope, weaponx and 42 others like this
#2 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 August 2012 - 06:55 AM
FAQ:
Q: Should I wipe for "XYZ" update?
A: I always recommend full wipes, no wipes, no gripes.
Q: What can this be flashed over?
A: The 6.16.211 OTA and the 6.16.215 leak.
Q: My Google app won't sign in?
A: Move it to /system/app and try again.
Q: How do I overclock?
A: There are several methods that will work:
1. Delete UV and place your desired OC file into /system/etc/init.d and apply the same permissions as the other files in there.
2. Navigate to /system/etc/init.d and open UV in a text editor. Look at the 6th line:
Change 1200 to the desired frequency and 1386 to the desired voltage. You'll most likely want 1398-1410 for your voltage if you do 1300Mhz - 1325Mhz.
Q: How to switch sdcard and sdcard-ext as primary storage?
A: Navigate to /system/etc/rootfs/init.mapphone_cdma.rc. Look at the top of the file.
To have sdcard as primary:
To have sdcard-ext as primary:
Q: My phone isn't going into deep sleep.
A: Most likely not the ROM. Use
from the Play store to see what is keeping the phone awake.
  • weaponx, todroid, trikotret and 4 others like this
#3 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Changelog:
Flick 1.0:
Initial release
Flick 1.0.3:
Overclock to 1300Mhz at boot
More kernel Modules
Tweaked Smartassv2
Build.prop tweaks
Fixed Statusbar
Flick 1.1:
Pulldown Toggles
Apex Launcher and Gmail
Blur Lockscreen
Flick 1.1.2:
Apex Launcher, Gmail, Maps, Google Music, Street Viewer, Root Browser Lite as user apps
Added Overclocking as a flashable zip
Added Stock Moto Launcher back in for user choice
Fixed Flick version #
CM9 Ringtones(But there is about 1 million of each of them,lol)
NOTE: To work around apps not updating uninstall it and then reinstall it via the market!
Flick 1.1.4:
Fixed stability issues
Flick 1.1.6:
REQUIRES A DATA WIPE!
Genie Widget
Theme Keyboard - 24v and EmericanX
More tweaks
Took away Voice Commands and Maps
Apps update properly
Got the right Flick version #
Fixed duplicate ringtones
Added Swype
Flick 1.3.0:
Debloated more
Apps in Settings.apk:
Beats Audio
OTA Updater
Deleted bugtogo.sh
More data tweaks
More performance tweaks
More battery life tweaks
SuperSU root permissions management
Fixed Blur Corporate Sync
Atrix HD launcher along with all of the goodies
Fixed USB dock and webtop
Fixed the "hangs" some people were describing
Blur settings icon is now AOSP icon
Thanks to brees75 for inspiring me to use cron to dump caches so I could use more aggressive cache values resulting in more fluidity.
Flick 1.3.1:
Wipe data with format of /system!
Flick 1.4.5:
Debloated more
Ditched cron
Tweaked kernel tweaks
build.prop tweaks
More init.d tweaks
Interactive is now defualt gov
Slightly UV'd
Tweaked framework-res.apk:
Enabled charging LED
3G connection tweak
Enabled 180 degree rotation
And lots of other stuff I forget
New default wallpaper
AOSP lockscreen handle
AOSP signal icons
AOSP quick settings in status bar
Added Notification Toggles for customizable Pulldown Toggles -j4evlin
Updated Apex launcher
Fixed Beats Audio icon being out of alignment
Took out OTA Updater
More stuff I don't remember
Wipe it all!
Flick 1.8.0:
Blacked out framework-res.apk - Saves battery and looks pretty
Took out lots of useless apps - Took up space and I didnt use them
Made the status bar transparent - Looks sexy
Took out theme keyboard for Swype
Debloated it like a boss - One of the smallest Blur ROMs now
Reworked init.d scripts - Just some cleanup
Supercharger V6 memory management - should fix freezeups and add speed
Made pegasusq the default governor again - faster with better battery life
Disabled scrolling cache for smoother vertical scrolling
Gave music and blue tooth 30 volume steps - Find the perfect volume
Removed stock homescreen and all the widgets - Never used it
1% battery mod found in simplex with some recoloring - 34% down to 15% is yellow
Disabled 180 rotation - Some people had issues with it
Put in prefab toggles - No more app you have to use
Took out kernel modules I thought were useless - BoostedASSV2, Smartassv2
Switched back to Superuser - Too many problems with SuperSU
Disabled charging LED - Was really annoying
Razri camera - Opens faster and works with any gallery
Tweaked kernel tweaks for better battery life
Changed default ringtone to Cyantone - l love the ringtone
Changed up CPU frequencies - 800Mhz is now 900Mhz
Using cron to dump caches - More fluid now
More net tweaks - Faster web
Tweaks to init files - Better performance
Updated libs and EGL - Smooth!
​Enhanced audio from build.prop - Awesome audio
Put back in Blur signal icons - Can see you're signal now
Took SuperSU and Notification Toggles out of the Settings menu
Tweaked Auto brightness values with more steps - Better battery life
Flick 1.8.1:
Fixed downloading large apps issue
Updated Busybox
Updated Superuser
Put some Blur stuff back in
Upped voltages slightly
Got version # correct
Changed some init script stuff
Flick 3.0.0:
Inverted AOSP Phone
Inverted Google Now
Smart Actions
Made "Mobile Hotspot" a hidden app
Updated to latest Busybox
Latest Superuser binary
Updated Apex Launcher
Updated Google Play Music
Disabled some sort of database caching
Memory management tweaks
Made all volume steps 15 except music and Bluetooth
Got version # right
Flick 4.0:
Ported Eclipse's quickpanel, removed Brightness toggle
Advanced Reboot menu - Reboot, Shutdown, Bootloader, Hot Reboot
Made the Status bar more AOSP and JB style
Tweaked auto brightness
Exported wallpaper with higher quality and took out watermark in bottom left
Added back Moto Alarm & Timer for functionality
Replaced Beats Audio with DSP Manager
Fixed modules not loading for some people by putting the scripts init
Put in the Android 4.2 gesture keyboard
Reorganized and cleaned up build.prop
Retweaked the Pegasusq governor for perfection
Cleaned up redundancy for faster boot times
Better Audio
Minor cleanup of SystemUI.apk
Now using JB Adreno GPU drivers for better hardware acceleration
Cleaned up redundancy with cron
The sdcard-ext is now the primary storage to go with SS3
Init script tweaks for performance and efficiency
Updated Play Store
Tweaked updater script slightly
Added Notification LED toggle from Eclipse in Settings<Display
Tweaked services.jar for less launcher redraws and better RAM performance
Added back Live Wallpapers
Took out the Preloaded Contacts
Flick 4.8.0:
Added more .8x and .7x animation scales in Settings< Developer options<Animation Scales - I feel like .8X is perfect
Added Infinitesimal and Enormous fonts into Settings<Display<Font size
Added Never for screen timeout in Settings<Display<Sleep
There is some more Settings stuff, see if you can find it.
Full GPU Rendering enabled - Smoother
Using SuperSU again
IO performance increased thanks to rwhite
Brought back IME Switcher
Switched sdcard back to default
CPU slightly more undervolted
Updated Apex Launcher and Google Play Music
Net tweaks
Some slight init script tweaks
Better battery life through better Wifi management and tweaking kernel tweaks and other scripts
Changed default alarm to CyanAlarm
Cleaned up tweak redundancy and fixed some tweaks that weren't working correctly
Some updater script tweaks
Tweaked gps.conf for even faster lock on
Tweaked Pegasusq again - ditching it next release
There is so much more in this release, but I feel can't remember any of it! :angry: Just enjoy the build lol
Flick 5.0:
Changed default governor to hotplugx - parameter tuning also
Fixed and brought back Accessibility settings
Brought 900Mhz back down to 800Mhz
Made Settings.apk more AOSP, the images for Tethering & Mobile Hotspot and Airplane mode don't look as good as the others
Put Superuser back in
Put Nova Launcher in and Apex out
Did some AOSP theme touchups in SystemUI and framework-res.apk
Changed battery icon
Balanced battery life and performance - MOST WORK WAS ON THE SCRIPTS
Slightly darkened Auto Brightness
Rezipaligned everything in case any of it wasn't
Took out Voice Search as Google Now can serve the same purpose even while deactivated
Took out some ringtones that were just.... there
Resigned everything
Cleanup in /system/lib
Updated SmartActions
Took out cron and upped cache pressure
New bootanimation by ZKK007
  • GroovyDeus, weaponx, jrbxx7 and 14 others like this
#4 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 23 August 2012 - 07:04 AM
Glad to see that you got this out, looks good. I think you achieved what you were aiming for ;)
#5 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 23 August 2012 - 07:05 AM
First good to see it got out, looks good. I think you achieved what you were aiming for ;)
Don't worry so am I, thanks, I sunk about an eighth of my summer into this ROM.
  • biggiesmalls657 and jamminjon82 like this
#6 eliX84
eliX84
  • 18 posts
  • Twitter:elivaldez84
  • LocationSan Benito, TX
Posted 23 August 2012 - 07:20 AM
Glad to see someone else in the Razr Dev scene! Just cause of that im gonna give his a try. One thing though, does this have motocast? I think im one of the few that actually like it and use it.
Thanx for your time into this great device and making mine a whole lot better.
#7 neur0tk
neur0tk
  • 123 posts
  • Twitter:neur0tk
  • Google+:neur0tk1@gmail.com
  • LocationLatrobe, Pennsylvania
Going to try this out!!
Sent from my Simplex maxx'd razr
  • jamryz likes this
#8 Maxxaholic
Maxxaholic
  • 628 posts
  • LocationWashington, USA
Posted 23 August 2012 - 07:26 AM
Sounds pretty good. Cant wait to see the screen shot!
Sent from my DROID RAZR using Xparent SkyBlue Tapatalk 2
#9 androidlearner
androidlearner
  • 904 posts
  • LocationPeoria, AZ
Posted 23 August 2012 - 07:28 AM
I'll give this a try. Love seeing a new dev for Razr!
Sent from my Droid Razr Maxx Arctic .215
#10 vtwinbmx
vtwinbmx
    Droid Elite
  • 2,486 posts
  • LocationOhio
Posted 23 August 2012 - 07:37 AM
Nice! Glad you got it running
#11 neur0tk
neur0tk
  • 123 posts
  • Twitter:neur0tk
Posted 23 August 2012 - 07:53 AM
Maps and street view will not update getting the package was not signed or something along them lines
#12 Aliceics
Aliceics
    Graphic Designer | Themer
  • 550 posts
  • Twitter:alicerzr
  • Google+:littlemissalice1@gmail.com
Posted 23 August 2012 - 08:05 AM
Sounds pretty nice, can't wait to see screenies ;)
#13 androidlearner
androidlearner
  • 904 posts
Posted 23 August 2012 - 08:15 AM
Is there a gapps to flash? Haven't flashed it yet
#14 neur0tk
neur0tk
  • 123 posts
  • Twitter:neur0tk
Posted 23 August 2012 - 08:22 AM
Nothing in the OP indicating that about Gapps
#15 mcjonesy
mcjonesy
  • 24 posts
Posted 23 August 2012 - 08:42 AM
Downloading now. Sounds pretty sweet.
  • arcangel979 likes this
This is where I would tell you which ROM I'm running, but I probably just flashed something else.
#16 f4113n_sh4d0w
f4113n_sh4d0w
  • 12 posts
  • LocationSouthern California
Posted 23 August 2012 - 09:44 AM
Looking forward to trying this one out. Cant wait for screens. Good luck in school, I started this week.
We process in shadow, to render unto others the truth and light.
#17 ThankMeLater
ThankMeLater
  • 42 posts
Posted 23 August 2012 - 10:10 AM
How's texting/typing on this rom? It was too choppy on the last rom I was on. I use the Motorola Input keyboard over swype.
Check out Flossycarter & QBKING77 @ Youtube.com
#18 pinkfloydviste
pinkfloydviste
  • 25 posts
  • LocationHumboldt Nation
  • Current Device(s):Droid Razr Maxx HD, Samsung Galaxy Tab 2, Samsung Galaxy Tab 3, Moto X
Posted 23 August 2012 - 10:49 AM
can't wait to try it out
#19 mrmoto55
mrmoto55
  • 30 posts
Posted 23 August 2012 - 10:50 AM
This for .214?
#20 Scipio
Scipio
  • 133 posts
  • LocationNew York
Posted 23 August 2012 - 11:20 AM
This for .214?
any ICS version, but if you're on 214, you really should upgrade to 215, pretty easy to do. But this will work on 214
Also tagged with one or more of these keywords: Blur based, ICS, deodexed, Bytecode, Flick, inverted, AOSP, Razr, CDMA
