[Rom][Bionic] 8/23/2012 - Liquidsmooth *cm9* Nokexec *v1.1* Jmod
33 replies to this topic
#1 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
  • LocationStarkvegas, Mississippi
  • Current Device(s):Galaxy S4 Active
Posted 21 August 2012 - 09:52 PM
Hey guys told you i would make it for CM9
* THIS ROM IS BUILT OFF OF THE DHACKER AND HASHCODE ROMS*
Many sleepless nights later we get this...
#CHANGED BASE TO CM9 WITH MODS!!
#MUST FLASH MY DATAPACK OR WILL BREAK IT!!!
So here we go
Chagelog for V1.0 (Coming from CM9)
-Force Format Script added to Update Script
-Added True AwesomeBeats Audio (All Modules)
-Added/Updated Google Now M7
-Added All apps from LIQUID ICS
-Added OneX and Tbolt Ringtones
-Added GPS Fast Lock Fix
-Added SuperSU
-New LiquidSmooth Boot Animation
-Windows animatons 200 for better battery
-Added Reloaded ICS/Toggle Menu Customizer
-Added Nova Launcher
-Added AOSP Music
-Added Liquid Tweaks to Init.d
-Build.prop Tweaks
-Tweaked Signal Type on boot
-Added Razr Kernel Module Tweaks + App
#Changelog to 1.1
-Fixed Market Issues
-Added Status Bar Toggles App
-Updated a few gapps and other things
-Jelly Bean Nexus Bootanimation
ENJOY, SHES STABLE!!!!
-Contains almost all the Apps From Liquid ICS
-Contains all known CM9 Bugs for Bionic
NOTES:
1. Google Now, Youtube, And Google Play Music are included in the DATAPACK
2. Nova Launcher can be Uninstalled, BUT IT IS THE DEFAULT LAUNCHER!
Removing it will cause a dead in the water effect if you dont have a
alternative installed.
BUGS
-Screenshot (Kernel Related)
-Rotation (Kernel Related)
QUESTIONS
-What is datapack? It is all the custom apps and gapps needed to function. Split rom in half for Safestrap to install
with no errors or glitches with the size limit. Google Now, Music, Etc.. is included
*2Roms 1Datapack - Compatable with CM9 V1.0 and CM9KEX V1.0*
Screenshots:
Posted ImagePosted Image
SATELITE LOCK WAS FROM INSIDE MY HOUSE
PLEASE: FORMAT DATA, AND SYSTEM PARTITION FOR CLEAN INSTALL
Downloads (HOSTED ON OUR
LIQUIDSMOOTH CM9 V1.1:
MD5sum:889d466bab950990e0989d92de9867ef
IF YOU HAVE ORIGINAL DATAPACK YOU CAN STILL USE IT!!
Its the same package just renamed.
JMOD CM9/BLUR DATAPACK V1.1:
MD5sum: 83550bfad44dda8bcb55123936ce671d
[/center
  • ted1735 and Negative7 like this
>> I'VE BEEN AROUND A WHILE. LETS GET TO IT <<
Current Device: AT&T Samsung Galaxy S4 Active
Retired Devices: Moto Droid, VZW HTC Thunderbolt, VZW Moto Droid Bionic
#2 berndt_toast
berndt_toast
  • 29 posts
Posted 22 August 2012 - 06:35 AM
Noticed that My Verizon Mobile cannot be installed (nor can yelp, google shopper, weatherbug, and a few others). Is this because of the jellybean market?
#3 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 22 August 2012 - 06:47 AM
it might possibly be the market. I have yet to figure it out. I need help with it. All thats in the datapack. The rom itself is fine
#4 berndt_toast
berndt_toast
  • 29 posts
Posted 22 August 2012 - 06:53 AM
Yeah, I saw it was in the data pak, but it is not installed. No biggie, just checking this out.
#5 basoodler
basoodler
  • 25 posts
Posted 22 August 2012 - 08:12 AM
Does this one have all of the status bar mods etc? Or is it too waiting for the update from liquid?
#6 nobreak1970
nobreak1970
    Transition Leader from Rombot
  • 130 posts
  • LocationAlabama
Posted 22 August 2012 - 09:05 AM
My Verizon is installed and working for me...it was in the rom or datapack. I wiped /system /data /cache so it's no a "leftover".
weird.
also this runs great on .238
God bless.
#7 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 22 August 2012 - 03:16 PM
Hey SPJESTER, what governor do you recommend running with this. I'm looking for pretty much lagfree expierience. Battery isnt totally important but i dont want it dying in like 3 hours? Thanks for all your work here boss
#8 bionicnino
bionicnino
  • 17 posts
Posted 22 August 2012 - 07:08 PM
This ROM is liquid smooth just like the name says. I love this ROM but had to go back to cm9 7-25 because of app compatibility issues. If this is somehow corrected, I will def be running Liquid Smooth. Best rom I've tried in a while.
#9 PinHigh
PinHigh
  • Twitter:bgulb610
  • LocationMadison, WI
Posted 23 August 2012 - 05:13 AM
What apps are you having problems with?
#10 bionicnino
bionicnino
  • 17 posts
Posted 23 August 2012 - 05:32 AM
Mainly Bank of America app. When I go to the play store it says "this app is not compatible with your device", or something along those lines. I use it daily, which is why I decided to go back to cm9 7-25. Any help with this would be greatly appreciated.
#11 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 23 August 2012 - 05:33 AM
yea still not sure what it is. Last time i use Cm9 for anything lol
#12 bionicnino
bionicnino
  • 17 posts
Posted 23 August 2012 - 05:50 AM
Still a kickass rom though.. for sure
#13 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • Twitter:kcalebcole
  • LocationColorado
  • Current Device(s):Motorola Droid RAZR M
Posted 23 August 2012 - 08:16 AM
have you changed your DPI settings at all? There are many apps that give you that error in the play store if the DPI is modified in any way from stock.
#14 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 23 August 2012 - 08:20 AM
try to change the model id of the phone to DROID BIONIC im testing a blur rom atm but im gnna try cm9 next to see if that fixes it!
#15 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 23 August 2012 - 11:31 AM
enjoy that update
#16 bionicnino
bionicnino
  • 17 posts
Posted 23 August 2012 - 02:03 PM
Cool. I'll give it a shot. Reflashing now
#17 bionicnino
bionicnino
  • 17 posts
Posted 23 August 2012 - 03:07 PM
Thanks for the update SP. I'm running it now and having no problems. Can't say it enough. This is a B A rom!
#18 SPJESTER
SPJESTER
    Like A Boss
  • 169 posts
  • Twitter:mhowell34
  • Google+:mhowell34
Posted 24 August 2012 - 02:03 PM
fixed thread links
#19 xcodybx
xcodybx
  • 48 posts
Posted 27 August 2012 - 06:51 AM
ok..... maybe because it's early, and I just can't fully understand................................ but what do you mean to split the rom in half? You don't just download v1.1, data, and flash?
#20 dragon
dragon
    Puff the Magic Dragon
  • 166 posts
  • Twitter:foamerman
  • LocationLand of Honalee
  • Current Device(s):Unlocked RAZR MAXX HD retired Bionic, Thunderbolt and OG Droid
Posted 27 August 2012 - 08:12 AM
safestrap only lets you instill so much what he has done is split it into two installs DL liquidsmooth cm9 v1.1 and DL blur datapack v1.1 and put them on your sd card then do your wiping then install the cm9 v1.1 then go back and install the datapack v1.1 then reboot your phone I think that is what your asking right
