XT910 Bricked ,unable to flash stock JB with RSD lite
9 replies to this topic
#1 suniljoy
suniljoy
  • 5 posts
Posted 09 March 2014 - 05:06 PM
I have RAZR xt910... previously i had stock 4.1.2 Vodafone Germany version on it ...i flashed mokee 4.4kitkat using safe strap on stock slot, after couple of days i flashed JBX KERNAL ...as after instaling new KERNAL i found lot of hanging ... i was trying to restore my backup of old KERNAL i found error and it wasnt booting up ..i did full factory reset but same problem and my safe strap also gone with that ...am unable to flash stock JB by using RSD lite, am getting faild message ...but i did used RSD lite flashing succesfully before many times with the same ZIP i used now.... I think i did somthing wrong with my kernal ...its been 4 days i coudnt able to use my RAZR,,,,could anyone here please help me to get back my RAZR , .......THANKS ADVANCE
i have linked my razr stock JB screen shot and the error which i got while RSD lite flashing below......
  126.63KB   14 downloads
  96.98KB   18 downloads
#2 cmh714
Posted 09 March 2014 - 05:52 PM
it seems that RSD doesnt see your device Suniljoy, that is why the Device window is empty. It does appear that you have the correct FXZ files.
You may have an issue with the drivers, the usb port or the usb cable you are using. I will assume that you are in fastboot mode on the device.....
You can try SamuriHL's utilities, make sure you read, and read again before requesting help and post in the HoM thread:
  • suniljoy likes this
#3 suniljoy
suniljoy
  • 5 posts
Posted 09 March 2014 - 06:51 PM
thanq so much for you kind information...i will look into that...i hope i will be able to make it work
#4 cmh714
Posted 09 March 2014 - 07:28 PM
we're here to assist if you get stuck, just read and you should be fine.
#5 suniljoy
suniljoy
  • 5 posts
Posted 10 March 2014 - 07:05 PM
My battery was dead low...am unable to flash and I couldn't charge it ..what should i do now..
Sent from my GS202+ using Tapatalk
#6 livinginkaos
Posted 10 March 2014 - 07:09 PM
You can get a team black hat adapter or make a factory cable.
Sent From My DEV X
#7 suniljoy
suniljoy
  • 5 posts
Posted 10 March 2014 - 07:20 PM
Thanq livinginkaos...any link to make a factory cable..?
#8 livinginkaos
Posted 11 March 2014 - 02:41 AM
Sent from my Unlocked Moto G
#9 suniljoy
suniljoy
  • 5 posts
Posted 14 March 2014 - 01:58 AM
Thanq for your support @cmh714,@livinginkaos .....i got my razr back to the condition by using factory cable to the the stock...thanks a lot...
Sent from my XT910 using Tapatalk
  • livinginkaos and cmh714 like this
#10 livinginkaos
Posted 14 March 2014 - 03:22 AM
Glad you got it going!
Sent From My DEV X
