![Photo](http://www.droidrzr.com/uploads/profile/photo-thumb-40570.jpg?_r=0)
Posted 21 August 2012 - 04:08 PM
- projektorboy likes this
Posted 22 August 2012 - 09:15 PM
Here is the BootStrap I use which is touch. I am not sure where i got it from originally but it works.
Here is a Bionic Init.d installer for those who do not have it installed. (this is a somewhat modified version which can be found at )
Here is a Governor installer as well. Which includes the following modules. (requires Init.d to be installed 1st)
cifs.ko
cpufreq_boostedASS2.ko
cpufreq_hotplugX.ko
cpufreq_interactiveX.ko
cpufreq_pegasusq.ko
cpufreq_smartass2.ko
cpu_control.ko
ntfs.ko
sio-iosched.ko
symsearch.ko
I thank Tweakerz OC for this.
I am not responsible for any problems that may or may not happen from the use of said installers above.
- ax562 likes this
Posted 31 August 2012 - 10:15 AM
Posted 31 August 2012 - 09:56 PM
Posted 01 September 2012 - 03:39 AM
Posted 11 October 2012 - 10:35 AM
Thanks!
Posted 19 October 2012 - 07:32 PM
- twinkyz1979 likes this
Posted 19 October 2012 - 08:55 PM
Posted 19 October 2012 - 11:24 PM
Why is the kernel module d/l take you to the initd d/l
I am not sure but it is fixed now thanks for saying something
![:)](http://www.droidrzr.com/public/style_emoticons/default/smile.png)
- johnlgalt likes this
Posted 20 October 2012 - 06:38 PM
Droid Bionic - JB - Rooted
Posted 20 October 2012 - 11:34 PM
Correct me if I'm wrong but after doing everything here we still have to set the clock speed after a reboot right? This makes it so the modules all load on reboot but clock speed still reverts to 1.0g.
yes but using SetCPU, app's like SetCPU, or scripts will do it for you automatically.
Posted 21 October 2012 - 07:45 AM
Posted 04 June 2013 - 07:44 PM
Posted 04 June 2013 - 07:46 PM
Also tagged with one or more of these keywords: Bionic Overclock
Legacy Devices →
VZW Droid Bionic [XT875-CDMA/LTE] →
Droid Bionic Development [XT875] →
Overclock that sticks at boot :) Simple..Started by 6flip9 , 16 Nov 2012 ![]() |
