641 replies to this topic
#321 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 14 October 2012 - 07:28 PM
so safestrap v3 uses the internal sd card? I have like 14 gb on my ext sd. Is there a way for the sd cards to be switched. Or once your first rom slot is created and i boot a jb rom will they be switched and i can use the ext sd?
#322 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
  • Current Device(s):Bionic
Posted 15 October 2012 - 12:51 AM
How do you mean? It's always going to use the internal to hold your ROM Slots. That's not going to change. Your external card will be considered your internal card when you boot into one of the new JB builds though.
#323 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 15 October 2012 - 04:23 AM
Yeah i think i figured it out lol.
#324 Obsidian
Obsidian
    Developer
  • 230 posts
  • Twitter:@Obsidian_22
Posted 15 October 2012 - 01:10 PM
Just clear out your /sdcard... It has 8 gb allotted to it and is purposely built to be used for storage. (think about phones without an ext sdcard) So unless you told an app(s) to move or store there you can pretty much format it without worrying about it ruining things. Always double check and ask us if you find something on there that you aren't sure of before you format because I don't feel like adding stupid end user statements to my posts... You know the whole "I'm not responsible..."
Nexus 7 [Rom] C&C (PA+CNA) [Kernel] Franco's r21
  • Int_Rnd_Pooka and Rootuser94 like this
OG ---------> DX ----------> Bionic
#325 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 15 October 2012 - 01:24 PM
Yeah i pretty much did this haha, i just did an sd card analyst thing in es file explorer and either moved or deleted big files. So ive got 3 rom slots now.
  • Int_Rnd_Pooka likes this
#326 TragicRemedy
TragicRemedy
  • 87 posts
The would sdcard folder deal is very confusing. Got to be a better way to do it. Not talking about ss3... but just android in general.
#327 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 15 October 2012 - 03:25 PM
Need some insight. On BS. 3-4 nandroids on bs, including my 232 root. If I restore my 232, delete all nandroids and bs, install ss 304, can I nandroid my 232 (I guess on unsafe side) and proceed to reflash the roms I prefer in the slots? Just trying to figure out the starting point (which i consider my 232 nandroid on bs). Or will restoring my bs 232 nandroid and going from there on ss screw me up? Any help would be appreciated.
#328 correarc1
correarc1
  • 108 posts
Posted 15 October 2012 - 04:52 PM
PS guys, I LOVE SS3. To be able to test roms while keeping my safe AND my daily... it's very nice - a great way to compare and pick what works for you.
  • Rootuser94 likes this
#329 Int_Rnd_Pooka
Int_Rnd_Pooka
  • 284 posts
Posted 16 October 2012 - 01:07 AM
I'm not sure how it's confusing. It's no different than having different drive letter designations for logical drives in Windows, or different folders for different drive mount points in linux. Actually, it's EXACTLY like having a folder mounted in linux, since android is essentially linux on a handheld device
I actually haven't made any nandroids since installing v3.04. I suppose I COULD make a clean 232 nandroid, but the way SSv3 handles switching slots allows for your original /system /data and /cache information to be left completely untouched when you're in one of the four slots. SSv2 used a common data and cache area, so there was the possibility of being a problem when switching between the two sides and backing up or restoring your data. 3.04 basically has little mini filesystems that it mounts like a virtual CD at boot. These are stored in the /safestrap folder on your internal SD, and contain system, data, and cache . It's isolated from your base system entirely.
  • correarc1 likes this
#330 correarc1
correarc1
  • 108 posts
Posted 16 October 2012 - 10:22 AM
All, I have a SS3 question. I have it set up so that I have 3 of the extra rom spaces open with 1gb of memory each. I don't really have much of anything else on my phone, but It is significantly lowering my memory left for use. I only have 1 GB left in the internal memory for some reason.
Is there anyway to make those slots go on my external SD? Is there something that I'm missing?
#331 freddy0872
freddy0872
  • 38 posts
  • Twitter:freddy0872
Posted 16 October 2012 - 01:51 PM
No ur not able to put ROM slots in the ext SD. I couldn't figure out where I was losing so much space. And I found that my LOST.dir had about 5.5 GB stored in there of just random junk. I deleted the directory and now have room for about 6 slots @ 1 GB each.
U can use tibu to apps to SD and transfer all ur apps to the ext SD then make sure u don't have pictures or music or anything on the internal storage then format it and ull be all freed up ready for stacking up some slots! Hope this helps you out! :-)
Sent from my iced out XT875 using Tapatalk 2
  • Int_Rnd_Pooka and correarc1 like this
#332 SamuriHL
  • 44,209 posts
Posted 16 October 2012 - 02:16 PM
The unrootable has been rooted. Those who appreciate Dan R's root exploit work should really go throw a few bucks into his paypal account. It's worth it.
#333 correarc1
correarc1
  • 108 posts
Posted 17 October 2012 - 07:53 AM
Hey guys,
when installing a new version of GAPPS. do I need to do anything first, or can I just flash it over top of what's there already?
#334 acordill
acordill
  • 97 posts
  • Twitter:https://twitter.com/@acordill
  • Google+:http://goo.gl/J90Lv
  • LocationCentral Florida
Posted 17 October 2012 - 09:08 AM
Flashing over the top is fine... thats what I did and don't have any problems.
HoB 246 (Thanks to SamuriHL) running Icarus Hd 1.0 (Thanks to Jp1044 and T3T3Droid)
#335 Obsidian
Obsidian
    Developer
  • 230 posts
Posted 17 October 2012 - 10:39 AM
Added 3 Roms
Rag3 v3 by SuperDallas
Rag3 Blackout v3 by SuperDallas
& Simple Redhead by Sparkyman216
Nexus 7 [Rom] C&C (PA+CNA) [Kernel] Franco's r24
#336 correarc1
correarc1
  • 108 posts
Posted 17 October 2012 - 11:11 AM
Added 3 Roms
Hey, what's the difference between RAG3 and RAG3 Blackout?
#337 Obsidian
Obsidian
    Developer
  • 230 posts
Posted 19 October 2012 - 12:55 PM
Blackout probably just has inverted gapps... So white writing on a black background
Sent from my Nexus 7 using Xparent SkyBlue Tapatalk 2
#338 Obsidian
Obsidian
    Developer
  • 230 posts
Posted 19 October 2012 - 01:19 PM
Hey guys I think I found a solution to the Rom building madness that's been going on and trying to keep the thread use able (too much data gets overwhelming for people)
I'm going to get rid of the download links and move the thread links up. I will keep download links to pookas cm compiles, hash & dh's targa folder and any other relevant build that needs a home.
Basically vanilla aosp cm9, cm10, AOKP ICS and AOKP JB.
The devs all use those four roms as their base and then add on from there so keeping the vanilla roms up top makes sense...I'll keep the dev links up to date, adding new ones when they come out @ droidrzr and romdroidhacks. Newest will be at the top and if one gets updated I'll put it back up top (with dates)
#339 Obsidian
Obsidian
    Developer
  • 230 posts
Posted 19 October 2012 - 03:10 PM
It's official Moto announced the Bionic will get Jellybean
Sent from my DROID BIONIC using Xparent SkyBlue Tapatalk 2
  • Int_Rnd_Pooka, Rootuser94, thetoolbox and 1 other like this
#340 correarc1
correarc1
  • 108 posts
Posted 20 October 2012 - 06:09 AM
Hey guys, is there any way for me to take the OTA update with out losing root or my other roms?
