#301
Posted 11 October 2012 - 08:29 PM
I've put 4g kexec through it's paces and so far.... I'm impressed.
#302
Posted 14 October 2012 - 10:21 AM
When I posted my first post about it I was given v3.01 So obviously he has been putting in a lot of time and effort because Hash just sent me v3.03
The more I use it the more I like it. Having the ability to switch roms in a matter of seconds on reboot is amazing. For those of you who never actually use their unsafe side because of the time it takes to switch in v2.XX you will now. Also having the ability to install and test up to 5 roms (4 + stock) is amazing.
I'll check in again soon with another update
Nexus 7 [Rom] C&C (PA+CNA) [Kernel] Franco's r21
#303
Posted 14 October 2012 - 10:22 AM
- johnlgalt likes this
#304
Posted 14 October 2012 - 10:24 AM
I know that TeamHaters has current CM9 and CM10 compiles, and I want to say JB-AOKP too, so they're going to be current as well (provided they're updating those ROMs, I haven't checked for a bit)
Thanks for the info brother... Always looking out for us :-)
- Int_Rnd_Pooka likes this
#305
Posted 14 October 2012 - 10:28 AM
FYI SSv3 is making progress. Hashcode has been working on the "delete" function. It is what allows you to delete a rom slot you built. Obviously this is a good thing because it allows you to make space and also remake a slot if you realize you need more or less storage memory for that particular slot (remember I told you that you will have the option to choose between 1 - 4 gigs per)
Thats definitely some good news! Can't wait to be practically penta-booting my phone!
- correarc1 likes this
#306
Posted 14 October 2012 - 10:41 AM
Can't wait for public release. Thanks for the update. I almost wish I didn't know it was coming though since I hate knowing things exist but not being able to play with them.FYI SSv3 is making progress. Hashcode has been working on the "delete" function. It is what allows you to delete a rom slot you built. Obviously this is a good thing because it allows you to make space and also remake a slot if you realize you need more or less storage memory for that particular slot (remember I told you that you will have the option to choose between 1 - 4 gigs per)
#307
Posted 14 October 2012 - 01:32 PM
Hell yeah that truly is one of the best parts. Also the ui is laid out so much better than cwr (no offense to Koush)
When you select wipe it has data system cache and dalvik all together and it's very fast
Yeah I know I am the same way but I wanted to give you guys something to look forward to :-) also if you are running and Ics aosp rom right now as your DD it would not work for you anyway so it's worth the wait.
#308
Posted 14 October 2012 - 02:02 PM
~Bionic .247 courtesy of HoB
__________________sent from my bionic with dub_________________
#309
Posted 14 October 2012 - 02:03 PM
#310
Posted 14 October 2012 - 02:04 PM
COOL, yay!!!Open beta is just "release notes" away! @hashcode0f just tweeted
#311
Posted 14 October 2012 - 02:07 PM
#312
Posted 14 October 2012 - 03:11 PM
If you run into a problem or have questions please come back here. Myself and Freddy0872 will be able to help you much quicker than if you try to ask Hash himself. Both of us have been using and testing SSv3 for Hash so we know it very well now.
Also this is a whole moto platform release so Hash won't have time to help 6 different phone communities at once so I want to help keep the Bionic Community running smoothly.
Thanks,
Obsidian
Sent from my DROID BIONIC using Xparent SkyBlue Tapatalk 2
#313
Posted 14 October 2012 - 03:14 PM
#314
Posted 14 October 2012 - 03:26 PM
Ill be on Google talk always. I've got it up on my phone and nexus 7 as well.
Gtalk: fredsinzjr
This is a huge step for all of us! Probably one of the greatest/coolest/most awesome things I've tried yet!
Sent from my iced out XT875 using Tapatalk 2
#315
Posted 14 October 2012 - 03:28 PM
just to clarify, how do we switch from ss2.11 to ss3.0.4? just go to unsafe, remove ss, then install the new one?
Yes GO TO UNSAFE SIDE and uninstall and delete safe strap dirs that u see on ur SD card and ext SD. U must start fresh. Your stock side or unsafe will be just fine. Nothing will happen to it. Basically follow my guide to uninstall SS and install BS . Just stop at the BS part cuz ur gunna be installing a new apk for SSv3 :-)
#316
Posted 14 October 2012 - 05:22 PM
Just as obsidian stated. If anyone needs help with SSv3 hit me or obsidian up.
Gtalk: fredsinzjr
There's also instructions in the link for 3.04 that are simple and easy to follow.
The only thing I would add is that to create a slot, you have to enter "Boot Options" and select the slot you want to create to get it to prompt you to create it (Perhaps 3.05 could have a visual indicator of whether slots exist or not? I know, already asking for new features!)
#317
Posted 14 October 2012 - 05:31 PM
#318
Posted 14 October 2012 - 05:35 PM
#319
Posted 14 October 2012 - 05:45 PM
#320
Posted 14 October 2012 - 07:16 PM
There will be growing pains and some light updates but I think he really thought this one through and put in the work.
The best part is that he can update the whole line of them really easily so we'll see many more updates than before.
