[Recovery] Safestrap 2.11 For Bionic [08/19: Kexec + Charger + Stock Rom Fixes]
22 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 20 August 2012 - 02:28 PM
Originally posted by Hashcode on rombot.org, saving the thread from being deleted.
SAFESTRAP 2.11 for BIONIC (2nd-System Bootstrap / Recovery)
[ After installation, when you first enter recovery do a BACKUP of your original Non-Safe system. You will need this backup when you want to go back to stock for upgrades. ]
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. **
** BRICK WARNING: DONT USE IN COMBINATION WITH BOOTSTRAP -- REMOVE BOOTSTRAP PRIOR TO INSTALLING SAFESTRAP **
CHANGE LOG:
  • [08/19] Fixes for booting stock-based ROMs
  • [08/16] Now using a new splashscreen by Niko99
  • [08/16]: Supports KEXEC boot if kernel/ramdisk files are present.
  • [08/16]: Check for wall AC power on reboot and bypass KEXEC boot to allow for charge-only mode.
TO ENTER RECOVERY:
Enter recovery via the Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the [ MENU ] button, it takes you to Safestrap Recovery. Hitting [ SEARCH ] key will continue with the boot.
QUICK SUMMARY OF SAFESTRAP:
  • Safestrap attempts to keep your device in a relatively "safe" state while flashing custom ROMs.
  • This means that you are not clobbering your original system and taking a chance at bricking.
  • Where does the ROM get installed? Safestrap uses the preinstall partition instead.
  • Inside the recovery your preinstall partition is known as the "system" partition. And if you ever need to reference the main system it's called "systemorig"
  • The recovery handles 2 sets of data. 1 for your stock phone ROM (non-safe system) and 1 for your custom ROM (safe system). When you swap from non-safe to safe or safe back to non-safe, the recovery will back the current one up and replace it with the other. That's why it takes a minute. Be patient, let it happen. Profit.
  • You can only flash custom ROMs to the safe system.
  • Almost everything else about the recovery works like ClockworkMod Recovery.
KNOWN ISSUES:
  • USB Mounting from inside Recovery doesn't work yet. I show that the LUN file is being written to, but it just doesn't do anything. This may differ depending on the kernel in your particular leak.
SPECIAL THANKS TO:
  • Koush who develops such a GREAT recovery system and the makes the source available for others to use.
  • The Atrix dev team who I pulled the internal/external SD card support from
  • The Defy dev team that originally developed the Bootmenu source which I stripped down and used for the Splashscreen.
As always, let me know what you think!
  • johnlgalt likes this
#2 gmorgan056
gmorgan056
  • 9 posts
  • Twitter:gmorgan056
Posted 21 August 2012 - 08:12 AM
Download Link not working...
#3 YouthD
YouthD
  • 31 posts
  • Twitter:YouthD
Posted 21 August 2012 - 08:33 AM
here is a working Download link
#4 gmorgan056
gmorgan056
  • 9 posts
Posted 21 August 2012 - 08:35 AM
Great, thank you!
#5 YouthD
YouthD
  • 31 posts
  • Twitter:YouthD
Posted 21 August 2012 - 05:35 PM
This might sound noobish, but how do you get the phone in charge only mode?
#6 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • Twitter:kcalebcole
  • LocationColorado
  • Current Device(s):Motorola Droid RAZR M
Posted 21 August 2012 - 05:42 PM
Turn off the power. Then plug it in.
From my N7 w/ CM10 & Motley kernel @1.6Ghz
#7 YouthD
YouthD
  • 31 posts
  • Twitter:YouthD
Posted 21 August 2012 - 05:44 PM
*facepalm* thanks
#8 k.c.cole
k.c.cole
    Droid Ninja
  • 140 posts
  • LocationColorado
Posted 21 August 2012 - 05:46 PM
*facepalm* thanks
Glad I could help. :-)
#9 Dburger66
Dburger66
  • 27 posts
Posted 24 August 2012 - 09:57 AM
Question, will SafeStrap 2.11 with Kexec Support work with any ROM? Thanks!
#10 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 25 August 2012 - 02:38 PM
Yes
Sent from my Droid Razr
#11 mhous33
mhous33
  • 480 posts
Posted 29 September 2012 - 11:40 AM
so is the inability to restore safe-side nandroids a known issue with this version of safestrap? non-safe-side restore works, but safe-side restores always fail during restore of /system; have tried with backups of latest versions of both cm10 and aokp.
I knew that backups don't work on bootstrap ics, but I thought they were supposed to be working on safestrap.
#12 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 04 October 2012 - 08:32 AM
Were they made in safestrap?
#13 mhous33
mhous33
  • 480 posts
Posted 04 October 2012 - 09:12 AM
yes, of course.
#14 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 04 October 2012 - 09:33 AM
I figured you did, but I had to ask to be sure.
I had issues in the past with restoring backups made in SS, and nothing I could do would fix it. I ended up having to scrap the backups, start from scratch and make new backups.
There was a thread about how to supposedly fix the issue (on older versions of SS), but I had already wiped everything by the time I found it so I could not verify if it worked or not. Let me see if I can find it.
#15 mhous33
mhous33
  • 480 posts
Posted 04 October 2012 - 09:38 AM
yeah it's strange, i tried making fresh backups numerous times with both cm10 and aokp, same results every time. oh well, ss 3 should be out soon and will hopefully have this fixed. sounds like it's going to be quite an improvement over 2.11.
#16 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 04 October 2012 - 10:14 AM
Yup. I hope it will be. Still, though, since I haven't ROMmed my phone in a while, it'll be mostly academic for me.
#17 BossJ
BossJ
  • 19 posts
Posted 05 October 2012 - 09:40 AM
I"m having the same issue... I'm backing up to EXTERNAL SD // going to try to backup to INTERNAL SD
#18 mhous33
mhous33
  • 480 posts
Posted 11 October 2012 - 07:48 PM
yeah i was backing up to external also, although i wouldn't think it would make a difference. did your experiment with internal backup work?
#19 OldBaldy
OldBaldy
  • 425 posts
  • LocationSouth Carolina
Posted 11 October 2012 - 08:27 PM
You don't happen to have Voodoo installed, and have your su backed up do you? That will cause system restore to fail.
Sent from my DROID RAZR
#20 mhous33
mhous33
  • 480 posts
Posted 11 October 2012 - 08:40 PM
no, yeah I found that out awhile back.
