[Bionic][Ics] Motoicsbean 1.0
9 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 20 August 2012 - 02:26 PM
original rom and thread from shawn12350 of rombot.org. Copying it over to save from deletion.
Welcome to MotoICSBean!
This rom is based off of Sonofskywalker3's Blackhole rom. The goal of this rom is to make it as close to AOSP as possible. There are still more things that I would like to add and change but I am limited on time due to work. Let me know what you guys think. All feedback is greatly appreciated!
Credits- Sonofskywalker3 for letting me use his rom as a base! Thanks man!
Sparkyman216 for his mods and the images that I used from his rom. Thanks a lot man!
Features:
AOSP themed Statusbar and Notification drawer
AOSP themed Contacts and Phone
AOSP Calendar
AOSP Browser
AOSP Gallery
AOSP MMS Inverted
AOSP Email Inverted
AOSP Calculator
AOSP themed System Settings
Sense 4 Matte Clock widget (This widget is sized for apex launcher) Make sure to go into apex settings, homescreen and change vertical margins to none.
DOWNLOAD:
ADDONS/FIXES:
Stock Moto Sms(
Signal bar fix(
Visual voicemail (
My Verizon fix(
Bugs: The only bug I have found so far is the camera forcecloses when selecting panorama mode.
Screen Shots
Posted ImagePosted Image
  • johnlgalt, T3T3droid and linuxgator like this
#2 djr4x4
djr4x4
  • 80 posts
  • Twitter:djr4x4
Posted 21 August 2012 - 01:00 PM
If you would like power controls.
#3 psmak4
psmak4
Posted 23 August 2012 - 06:08 AM
I've run the Visual Voicemail update, but I don't see the Visual Voicemail app any where. Is there something else I need to do?
#4 linuxgator
linuxgator
  • 24 posts
  • Twitter:linuxgator
  • Google+:linuxgator
  • LocationNorth Central Florida
  • Current Device(s):Bionic
Posted 23 August 2012 - 09:15 AM
I gotta say that I'm really liking this ROM. I installed it a couple of days ago, and haven't looked back. It's nice that it has all of the functionality from the ICS leak, yet none of the bloat. The add ons are nice too and I really like the AOSP look/feel. This is the first ROM I've used on my Bionic that I haven't gotten frustrated about something or another enough to dump after a day. It's very smooth and fast, with decent enough battery.
#5 ndrwb
ndrwb
  • Twitter:ndrwb
Posted 09 September 2012 - 07:35 AM
Agreed. This is the first Bionic ROM I've tried that doesn't have the freezing problems or that goofy rotation bug (ie no CM9).
I was just missing the stock keyboard so I got that from here:
#6 nycqns983
nycqns983
  • 36 posts
Posted 17 September 2012 - 06:03 AM
I am loving this rom. The only problem that I have found is that when using Google navigation, it says searching for gps but will never lock on. Has anyone else had this problem? Is there a known fix? Thanks!
#7 syxia
syxia
  • 21 posts
Posted 17 September 2012 - 07:34 AM
Why am I unable to use Exchange as an account for the stock Email app? Otherwise this thing is pretty awesome...
#8 nycqns983
nycqns983
  • 36 posts
Posted 18 September 2012 - 08:40 PM
anyone?
#9 linuxgator
linuxgator
  • 24 posts
Posted 19 September 2012 - 06:20 AM
Google navigation gps locks on for me, though I am using .244 as my base and have this installed over it. The old standby for gps lock issues is to download an app called GPS status. Select Menu->Tools->Manage A-GPS state->Reset, then repeat the process and select Download instead of Reset. No guarantees that this will work, but it might help. Another suggestion is to try toggling the gps off then back on, sometimes that helps too.
#10 nycqns983
nycqns983
  • 36 posts
Posted 19 September 2012 - 05:34 PM
Unfortunately it ended up being a hardware issue. Verizon sent me a new phone tho so it's all good. Thanks man!
