i recently decided to upgrade my razr to OTA 9.18.94.en.us since the phone kept asking me and it was getting annoying. after doing so, i kept getting "upgrade failed" and was unable to upgrade, so i removed root with OTA voodoo rootkeeper and upgraded again, but still had the same problem. i decided to then "restore all factory settings" to be able to upgrade, but after trying to restore my phone gets stuck in a loop with the green robot and a spinning square. it doesn't go anywhere from there. i'm trying to find the OTA 9.18.94.en.us download or instructions somewhere so i can install the update myself since i'm stuck with this infinite loop. could you guys please help me out with this? thank you!
boot/restore problems...
Posted 04 March 2014 - 07:07 PM
Posted 04 March 2014 - 07:23 PM
Then go to the house of moto and read the op and thread before beginning. This will flash the stock firmware in the version you were trying to upgrade to. There is also a moto safe root option for you to regain root.
sent from my One Max, damn it's big
Posted 04 March 2014 - 08:12 PM
You can download the fxz here -
(Droid%20RAZR%20HD)/VRZ_XT926_9.8.1Q-94-1_RSD.xml.zip
thanks, currently trying this out. using the RSD lite 6.1.5. chose option 1. RSD, and 1. full_xt926. it's currently in status "reboot" and on the phone has the green robot with the spinning square. is this normal? not sure if it's on a loop again or if this is part of the process.
Posted 04 March 2014 - 08:17 PM
ok, for some reason, even after i followed those steps, the RSD boots the phone, but then it just goes to the green robot with spinning square and gets stuck there. how can i fix this?
Posted 04 March 2014 - 08:27 PM
i get the following error in the FastBoot screen.
"No valid PIV block in SP for system piv validation failed (system) fastboot reason: boot failure"
anyway to restore the fastboot so i can flash my phone to the OTA 9.18.94.
sorry about the noob question guys, but i haven't done this in such a long time. please help me out.
i think my phone may be bricked. the version livinginkaos might of given me was probably the wrong one for my phone. i seem to be stuck now and everytime i try to flash with "FULL_xt926.html", RSD opens up and just closes back down. also, i get that "no valid piv..." message at the AP Fastboot Flash mode screen. i would really appreciate your help guys. thank you.
here is the houseofmoto log if anybody needs it...
POST THE CONTENTS OF THIS FILE IN THE HoM THREAD
FASTBOOT DEVICES:
FILE STRUCTURE:
Volume in drive C has no label.
Volume Serial Number is ACFF-EBE5
Directory of C:\HouseOfMoto
03/04/2014 09:46 PM <DIR> .
03/04/2014 09:46 PM <DIR> ..
11/24/2013 11:02 AM 281 CreateLOG.bat
03/04/2014 09:07 PM 4 flashmode.ini
03/04/2014 09:45 PM <DIR> FXZ_xt926
03/04/2014 09:46 PM 95 house.log
11/24/2013 10:55 AM 4,787 HouseOfMoto.bat
11/24/2013 10:51 AM 2,770 HouseOfMoto.sh
03/04/2014 08:58 PM 7 phone.ini
11/23/2013 03:07 PM <DIR> root
03/04/2014 08:30 PM <DIR> rsd
6 File(s) 7,944 bytes
Directory of C:\HouseOfMoto\FXZ_xt926
03/04/2014 09:45 PM <DIR> .
03/04/2014 09:45 PM <DIR> ..
09/26/2013 09:33 AM 10,485,760 boot.img
09/26/2013 09:33 AM 54,536,192 cdrom
09/26/2013 09:33 AM 524,288 device_tree.bin
09/26/2013 09:33 AM 262,144 emmc_appsboot.mbn
09/26/2013 09:33 AM 2,769,192 fsg.mbn
03/04/2014 09:10 PM 861 FULL_xt926.bat
03/04/2014 09:10 PM 810 FULL_xt926.sh
03/04/2014 09:10 PM 1,946 FULL_xt926.xml
03/04/2014 08:19 PM 10,329 FXZ-ScriptGenerator.jar
09/26/2013 09:33 AM 32,768 gpt_main0.bin
03/04/2014 09:10 PM 861 KEEP-DATA_xt926.bat
03/04/2014 09:10 PM 810 KEEP-DATA_xt926.sh
03/04/2014 09:10 PM 1,946 KEEP-DATA_xt926.xml
09/26/2013 09:33 AM 1,750,320 logo.bin
09/26/2013 09:33 AM 49,356,800 NON-HLOS.bin
09/26/2013 09:33 AM 10,485,760 recovery.img
09/26/2013 09:33 AM 143,360 rpm.mbn
09/26/2013 09:33 AM 103,296 sbl1.mbn
09/26/2013 09:33 AM 128,896 sbl2.mbn
09/26/2013 09:33 AM 524,288 sbl3.mbn
09/26/2013 09:33 AM 878,262,728 system.img.ext4
09/26/2013 09:33 AM 196,608 tz.mbn
09/26/2013 02:29 PM 2,862 VRZ_XT926_9.8.1Q-94-1_RSD.xml
23 File(s) 1,009,582,825 bytes
Directory of C:\HouseOfMoto\root
11/23/2013 03:07 PM <DIR> .
11/23/2013 03:07 PM <DIR> ..
0 File(s) 0 bytes
Directory of C:\HouseOfMoto\rsd
03/04/2014 08:30 PM <DIR> .
03/04/2014 08:30 PM <DIR> ..
07/05/2012 05:51 AM 421,978 BlankFlash.dll
05/14/2012 08:04 AM 1,106 cleancache.vbs
07/05/2012 05:51 AM 86,116 CommonXMLParser.dll
07/05/2012 05:51 AM 49,236 FBFlash.dll
07/05/2012 05:49 AM 41,054 FlashAdapter.dll
05/14/2012 09:52 AM 172,032 LCDriver_CNH1606432.dll
05/14/2012 09:52 AM 69,632 LCM.dll
05/24/2012 07:31 AM 59,856 libusb0.dll
07/05/2012 05:44 AM 1,159,259 pst.dll
07/05/2012 05:29 AM 26,177 PST.ini
07/05/2012 05:23 AM 23,431 pst_flash.ini
07/05/2012 05:50 AM 1,630,298 pst_fp_flash.dll
07/05/2012 05:50 AM 172,131 pst_fp_flashdevapi.dll
05/14/2012 07:44 AM 45,568 PST_INI.xls
05/24/2012 07:31 AM 2,292,736 QtCore4.dll
07/05/2012 05:44 AM 1,504 RSDLite.ini
05/14/2012 08:04 AM 53,323 rsd_service.dll
05/14/2012 08:04 AM 225 rsd_service.ini
07/05/2012 05:29 AM 1,973 sdk_common.ini
07/05/2012 06:42 AM 2,789,448 SDL.exe
03/04/2014 09:45 PM 7,966 SWDL.txt
07/05/2012 05:23 AM 397,824 xfstk-dldr-api.dll
22 File(s) 9,502,873 bytes
Total Files Listed:
51 File(s) 1,019,093,642 bytes
11 Dir(s) 8,020,135,936 bytes free
Posted 05 March 2014 - 10:06 AM
any word on this guys? is it possible to fix it? i'm still getting
AP Fastboot Flash Mode (S)
10.9B(*) )sha-1e9f557, 2013-09-26 12:31:42)
eMMC Info: Size 32GB
Device is LOCKED, Status Code: 0
Battery OK
Transfer Mode:
USB Connected
No Valid PIV block in SP for system
Fastboot Reason: Boot Failure"
or
Battery OK
Transfer Mode:
USB Connected
Fastboot Reason: Flash Failure
Posted 05 March 2014 - 01:12 PM
any suggestions before i take it to the verizon store. i can't seem to fix it. there is nothing i can do. everytime i plug it into my computer, i get "Fastboot VANQUISH S drivers not successfully installed" and on the phone "fastboot: flash failure" or "No Valid PIV block in SP for system piv validation failed (system) Fastboot Reason: Boot Failure"
Posted 05 March 2014 - 01:45 PM
sounds like you have driver issues at the very least....remove and reinstall. must be a usb 2.0 port and must be the real moto usb cable that came with phone.
GL.
EDIT: Ninja'd by a Hillbilly!
- johnthehillbilly likes this
Posted 05 March 2014 - 01:55 PM
Ninja'd further by PM HA ha ha.....
- johnthehillbilly and cmh714 like this
Posted 05 March 2014 - 02:22 PM
yes!!! i fixed it!! that was the problem. the drivers had to be reinstalled. for some reason, they were corrupted. anyhow, i managed to reinstall the drivers, used a 2.0 usb port and flashed my phone. all is well now. thank you so much everyone for helping me through my phone issues. i appreciate everyone's help.
- johnthehillbilly, livinginkaos and cmh714 like this
Posted 20 November 2014 - 06:42 PM
I fried my razr hd when flashing with rsd. moto device manager is not able to load drivers. It shows up in my pc device manager as fastboot vanquish s. cant update drivers or anything. my pc fails every time it tries.
Posted 06 July 2015 - 07:26 PM
i am having the same problem but i am not able to find the download for my drivers to re download them
Posted 06 July 2015 - 08:01 PM
