[Bionic][Ics] Aliasaokp V0.2 (Ics-Leak Only)
8 replies to this topic
#1 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 20 August 2012 - 02:25 PM
tehsusenoh from rombot.org created this rom/thread, I am copying it over to save it from destruction.
Introducing...
AliasAOKP v0.2
This is a ROM based off of dhacker's ICS-LEAK AOKP 7/25 build. There have been a few modifications.
The point of this ROM is to clean things up a bit. There are themes, improved animations, and performance options.
Changes in v0.1:
  • New GApps with Google Now
  • Editied backup scripts to save Google Now on each flash
  • 5 colored themes for the Theme Chooser (courtesy of Ricardo Cerqueira)
  • Removed the crappy Achromatic theme
  • Replaced Nova Launcher with Apex Launcher (personal preference, install what you want)
  • Removed Launcher2
  • New hosts file (winhelp202's July 3rd, 2012)
  • Added MyVerizon and LoginClientUI
  • Upgraded Play Store
  • Upgraded Superuser App
  • Faster rotation animations (best I can do about the rotation bug. It's a kernel/display problem)
  • Removed the ugly gradient in the system menus
  • Extra kernel modules (Change these under ROM Control > Performance)
  • More verbose installer to show you what's going on during flashing
  • Battery warnings at 10% and 5% instead of 15% and 4%
Changes in v0.2:
  • Fixed Performance settings app crash
  • Fixed typo in updater-script
  • Added correct Verizon Login APK
  • Slowed rotation speed
Screenshots:
Posted ImagePosted Image
Themes:
Posted ImagePosted ImagePosted Image
Install instructions:
  • If coming from another ROM (Including the original AOKP), wipe data/factory reset and wipe /system.
  • Install AliasAOKP_v0.1.zip.
  • Install ICS-GApps-GNow-v6.zip (You MUST use this version of the GApps!).
  • Reboot into your new OS!
If there is an updated version of this ROM, you will not need to reinstall the GApps/GNow. A modified version of dhacker's script will save it for you.
Download:
AliasAOKP_v0.2.zip:
ICS-GApps-GNow-v6.zip:
Enjoy!
  • T3T3droid and Bama like this
#2 nobreak1970
nobreak1970
    Transition Leader from Rombot
  • 130 posts
  • LocationAlabama
Posted 21 August 2012 - 11:12 AM
Absolutely loving this rom. Thanks man.
God bless.
#3 Orasion
Orasion
  • 17 posts
  • Twitter:ndaru_MA
  • Google+:https://plus.google.com/u/0/102203180718906203414
Posted 22 August 2012 - 06:31 PM
I tried this ROM for a while but face a wakelock problem. Maybe its because Google Now being constantly waiting for voice command.
Sadly I forgot to take screenies before I change ROM
#4 tehsusenoh
tehsusenoh
    Developer
  • 17 posts
  • Twitter:tehsusenoh
Posted 28 August 2012 - 07:40 PM
Thanks for copying this over.
I'll resume this project soon, though I have other things in my life that I need to attend to. There are plenty of bugs, and for that reason I would suggest flashing one of the fine ROMs by JP or SPJESTER. They're doing good things.
#5 humbleopus
humbleopus
  • 20 posts
  • LocationGeorgia
Posted 29 August 2012 - 08:03 AM
Thanks for all the hard work on this. Really liked the ROM, except for the alarm clock turning off the phone in the middle of the night. Tried running both stock clock and an app (Gentle Alarm). Happened with both of them. Can't wait for you to get back to work on this!
Ain't nothin' but a simple man... with a really cool phone
#6 xcodybx
xcodybx
  • 48 posts
Posted 31 August 2012 - 09:48 AM
when was this last updated?
#7 tehsusenoh
tehsusenoh
    Developer
  • 17 posts
Posted 01 September 2012 - 12:14 PM
The last time this was updated was August 15th.
#8 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 09 November 2012 - 06:59 AM
Sweet Rom, Love the theming and the feel. But it is very sliggish and slow. I am overclocked to 1.0 still with lots of Lag. If i am inside of Facebook, Or an App and hit the home button, it takes forever for the home screen to load up, all that shows is the App menu Icon, than the homescreen slowly fills in with my apps and weather widget. Anything i can do to speed it up?
Ethan82691
#9 tehsusenoh
tehsusenoh
    Developer
  • 17 posts
Posted 01 January 2013 - 12:29 PM
This was a big problem. However, I am no longer supporting this ROM, especially due to how old it is. My recommendation is top not use this at all.
Once true jelly bean is released, I might redo this one, but for now, stay off!
