If you would like to donate to me, please send me a PM with your email address and tell me how much you would like to donate!
Thanks to zhp pilot for the base!
KOA Sense ROM is a Modified Stock 4.03.605.2 ROM (ICS) (Sense 3.6) (GLOBAL) Build. This ROM is still a work in progress. As is right now, you can definitely use this as a daily driver. This build has a crap load of features and they will continue to grow as I have time to update it.
YOU MUST BE ON THE NEW FIRMWARE (4.03.605.2) BEFORE FLASHING THIS ROM!
SUGGESTED INSTALL WITH AMONRA RECOVERY!
Advanced Power Menu
Rooted
Full Init.d Support
Init.d Tweaks
Unsecured Kernel
Zipaligned - With Zipalign On Boot
build.prop tweaks - Battery and a few others
SU and Busybox pre-installed
CPU Sleeper App - Shuts Down 1 Core When Screen Is Off
Extended Quick Settings include:
Auto Brigtness
Bluetooth
GPS
Wifi
Airplane Mode
Mobile Network
Settings
Task Manager
Power Saver
Auto Rotation
Auto Sync
Decreased Auto Brightness Settings
1% Battery Mod - With Accurate Battery Fix
Google Now - No Workaround Needed
Debloated
Wake With Volume Buttons
Added Some Wallpapers To HTC Wallpapers
Sense 4 Themed Keyboard
Sense 4 Clock Widget
Sense 4 Themed Dialer
"Beats For All" Mod
Google Ears
Now Deodexed!!!
Everything!
You tell me!
Download ROM: http://d-h.st/Tkw
(Size 490.18MB MD5: d7fdb196c8aad87f07fa68089ad21db9)
Download latest RUU: https://rapidshare.c...5.2_PH98IMG.zip
(Size 615MB MD5: bcdd450501e390ce323a46b396cd0a49)
Place the RUU file on your external sdcard
Rename the RUU file to PH98IMG.zip
Reboot into the bootloader and let the update run
Reflash your recovery
Format /system
Wipe data/factory Reset
Wipe Cache Partition
Wipe Dalvik Cache
Flash ROM
Reboot
Profit!
