[Bootanimation] ALL CARRIERS/GALAXY NOTE 3: MASSIVE 150+ QMG BootAnimation LiBRaRy KoLLecTioN (3/5/14)
QMG bootsamsung.qmg bootsamsungloop.qmg shutdown.qmg
25 replies to this topic
#1 KaChow
KaChow
    If Only...
  • 364 posts
  • LocationPhiladelphia
  • Current Device(s):S6 (sm-g920f), Moto XT1575(waiting)
Posted 17 February 2014 - 04:45 PM
Here is the link. Thanks AbhishekS
While the Winter Olympic Games came and past, as they always do. We look forward to what is yet to come. But, in the meanwhile, what is here today may not be here tomorrow. Therefore, I present a new treat of an Android KitKat 4.4 Easter Egg, go ahead, download and enjoy!
It is recommended for best performance to use a Custom ROM, and with the speed changes I suggest the User Permissions settings to rw-r-r-T the “T” represents Sticky which is a Special Permission usually located in the lower right menu of Root Explorer. Enjoy!
(if looking for Star Trek Twist it has moved down the thread updated 2/11/14)
Currently there are over 150 "NON-FLASHABLE" Bootanimations that have been formatted into QMG format that can be installed into the system/media directory.
A few notes to start, there are 4 files that I tend to use within the Bootanimations which are:
1)            Bootsamsung.qmg = this is the large file that holds/starts the bootanimation
2)            Bootsamsungloop.qmg = this is a rather small file can either loop or end the bootanimation
3)            PowerOn.ogg = this is file that plays sound during the bootsamsung.qmg and bootsamsungloop.qmg.
4)            Shutdown.qmg = this is a mid-size file that plays a bootanimation as the device turns off, best way to activate is to select Power-> then reboot
While shutdown.qmg’s can be customized to work on different bootanimations, I have developed some bootsamsungloop.qmg’s to function separate of the bootsamsung.qmg, this allows the ability to fully customize the bootanimations that you would prefer to view. These QMG’s are listed in a Category called Intermezzo’s as they are Interchangeable without interrupting.
A few things to keep in mind.
A custom Bootanimation works best with a custom ROM, it simply does, Stock ROMs do not finish the same.
There is usually a delay between the loading of the Bootanimation and after the Safestrap loading screen appears.
QMG files have limitations some will not be as clean as Flashable Bootanimations, while others will present better.
Bootanimation’s require the use of both bootsamsung.qmg and bootsamsungloop.qmg (using one without the other will produce undesirable results.)
With PowerOn.ogg sound files I recommend when setting permissions to use rw-r-r with the “Sticky” Special Permission, sound is often more consistent.
I am only working on Bootanimation’s for this Kollection at this time. Feel free to see if these work on other Samsung Device’s and Tablet’s at your Own Risk.
Please, give credit where due, there are many Bootanimations here, if I left someone out please let me know, if you want to post my work, please extend the courtesy.
With so many Bootanimations it is often hard to remember all of the sources that I pulled them from, the largest source Developer that does simply incredible work and is simply known throughout the Android community for his work is JaeKarr99 which most of the Bootanimations that appear in this LiBRaRy KoLLecTioN are his, I have simply accepted the challenge of using a difficult themeing system and configured it the best I can to keep these Bootanimations in the best form possible. This was done through the guidance of xessus as his walkthroughs and many many countless hours of attempting this work is hopefully showing a positive. Other themers I will mention are Crakanug with the Black Ops II Bootanimation, CyanogenMod with CM, BKJolly, and the many others, if I fail to recognize I apologize it is not intentional nor out of disrespect, please forgive me.
Quick instructions:
Download zips: extract-> go to extracted folder-> cut & paste-> system/media-> change permissions to rw-r-r (see diagram below) Reboot and Enjoy!
#NOTE#  Prior to moving rename existing files in system/media to bootsamsung.qmg.bak, bootsamsungloop.qmg.bak, and shutdown.qmg.bak
I recommend removing the PowerOn.ogg file rather than renaming it, move it to the SD card.
Detailed Instructions: Walk-through
For this Bootanimation demonstration, I am going to be using JaeKarr99’s “Marvel” Bootanimation and KalKat579’s QMG/OGG work for both Audio & Visual. Begin by downloading through the Dev-Host Secured link:
Marvel_Bootanimation.zip
Download the above link and begin with them in the file labeled “/”-> “sdcard”-> “/” “download”. Since, these files are in a .zip you will need to Extract them, go ahead and press down on the Marvel_Bootanimation.zip file and select Extract. This will Extract the items to the SpeedSoftware folder which is still located on the sdcard. You can either elect to “Go to the Extracted items” or if you ever need to manually retrieve them just exit the download and go to SpeedSoftware-> Extracted-> Marvel_Bootanimations, then Cut and Move these 3 files and select the “home icon button” in the upper left menu bar or go to the->  “/”-> “system”-> “/”-> “media” and paste the 3 files into this folder. Select the PowerOn.ogg and Move this File to “audio”-> “ui” then paste the file into this folder. Once in this folder select the PowerOn.ogg and press down and select “permissions” change to the below set-up which will display as RW-R-R once completed.
Screenshot_2014-01-02-10-12-591_zps1be67
 **NOTE** The above is often referred to as “644” I suggest Subscribing to this thread and to keep it somewhere, as this configuration is COMMONLY USED in other System Folders…
Exit back to the media file and scroll down the page to find the “bootsamsung.qmg” file press down on this item and select “permissions”-> change to reflect the RW-R-R once completed. Next, repeat the same step with the last file which is bootsamsungloop.qmg. At this point you have taken 2 .qmg files which happen to be the Bootanimation of the “Marvel” logo changed the permission to function properly on boot and installed the sound to run with Bootani. Go ahead and Reboot the device. You are all done. Enjoy!
Let the FUN BeGiN!
  • johnthehillbilly likes this
#2 KaChow
KaChow
    If Only...
  • 364 posts
This is a LiBRARY KoLLeCTioN of BooTaNiMATioNs
-> To Start Off this KoLLeeCTioN I would like to BeGiN it with a FavoriTe Batman… <-
UPDATED 2/17/14 http://www.mediafire...atman_(revision).zip' class='bbc_url' title='External link' rel='nofollow external'>Batman_Bootanimation linkThanks JaeKar99
Batman is the "30th" Bootanimation that I have ready for the library at this moment, there will be more Superhero's, possibly Star Wars, or Star Trek character's kicking off Future BULK ADDITIONS!!!
CREDITS:
First of all I give credit to KalKat579 for peaking my interesting with the Bootanimation's through the QMG format's.
Boot Animations QMG Format [Team Vanguard] UPDATED 11-05-13
KalKat579 <- All Credit Goes To
I also give credit to xessus for his instruction and guidance with the Samsung Theme Designer program and QMG Formatting. Also, a Special Thanks to JaeKar99 who is the "Original Bootanimation Designer" that created large portion of these bootanimations seen here, I have reformatted them for our viewing pleasure! :D
Silver Surfer Preview by KachowPow
Red Orb Thanks JaeKar99
Blu Rotator Thanks JaeKar99
Blue Lines Thanks JaeKar99
Blue Kystal Machine Thanks JaeKar99
Blu Wave Thanks JaeKar99
Red Binary Nex Thanks JaeKar99
Super Mario Shroom’vision
Star Wars Battle
Star Wars Battle Ground Old Republic
Android Blue Cube Shutdown Thanks xessus
Android Blues Thanks JaeKar99
AOKP Thanks JaeKar99
Apple Tippiddy-Tap
[click here for GIF image]
Apple Smash (Updated logo is jumpy)
Atomic numbers Thanks JaeKar99
UPDATED 2/17/14 AeNomolyll-1(current favorite) Thanks JaeKar99
BA_AeNolmoyll Thanks JaeKar99
Baked
For GIF image click here
Beanstown106's_Bootanimation from his current Verizon ROM
Bios similar to what appears on the Hyperdrive ROM Thanks ade_tobat
CM11
Dr. Who Unknown credit
Dr. Who 50th Anniversary
UPDATED 2/11/14 Dr. Who Time Traveler Extended CutThanks JaeKar99
Flyn Vs Thanks JaeKar99
Google
Javanese, the themer is Dark-R his OP is here.
[for GIF image click here]
Knox RAID ATT ROM Bootanimation Thanks drakeymcmb
Marvel Thanks JaeKar99
Note III Thanks kevinrocksman
#3 KaChow
KaChow
    If Only...
  • 364 posts
Posted 17 February 2014 - 04:46 PM
UPDATED 2/17/14 ReactorThanks JaeKar99
STOCK Verizon Bootanimation
SlimKat Thanks SlimROMs
The Cross Thanks JaeKar99
Nostalgic Collection
AAL-Nex Thanks JaeKar99
Apophamator Thanks JaeKar99
Flaming Red Skull Thanks JaeKar99
Use Your Illusions Part I Thanks JaeKar99 (unsure of development)
Use Your Illusions Part II Thanks JaeKar99 (unsure of development)
Use Your Illusions Part III Thanks JaeKar99 (unsure of development)
Use Your Illusions Part IV (Picture of all 3 images above included) Thanks JaeKar99 (unsure of development)
This happens to be a "Special Bootanimation" as it combines Parts I, II, & III into one Incredible Bootanimation, check it out!!!
Here is a BIG Request... THE MATRIX COLLECTION happens to be the Matrix, Bootanimation and Shutdown, Enjoy! Thanks JaeKar99
Matrix Droid Thanks JaeKar99
Matrix in Blue Thanks JaeKar99
Apple Rotten to the Core Thanks JaeKar99
Pissing on Apple Thanks JaeKar99
Krynisis Thanks JaeKar99
"]For GIF image Click here"]For GIF image Click here[/URL]
Galaxus Thanks JaeKar99
Countdown to Call of Duty ~ Ghost Countdown Thanks JaeKar99
Bbokeh Thanks JaeKar99
#4 KaChow
KaChow
    If Only...
  • 364 posts
STAR TREK WARPSPEED
[click for GIF image]
UPDATED 2/17/14 http://www.mediafire...Twist_(revision).zip' class='bbc_url' title='External link' rel='nofollow external'>Star Trek Twist Thanks zul8er
Star Wars R2D2
STAR WARS HYPERDRIVE
click for GIF image
Alien Blue Bootanimation Thanks JaeKar99
Alien Green Bootanimation Thanks JaeKar99
Alien Orange Bootanimation Thanks JaeKar99
Blowing Smoke Bootanimation Thanks JaeKar99
Motorcycle Bootanimation
[for still image click here]
BKJolly's Pac Man Bootanimation Thanks BKJolly
Wave-Ani_Bootanimation Thanks JaeKar99
click for GIF image
Multi-Color Swirl Bootanimation Thanks JaeKar99
Nexus Beam Bootanimation Thanks PartimusPrime
Kit Kat 4.4+ Bootanimation
Black Ops II FINAL Version Thanks Crackanug
E-Core Thanks JaeKar99
FlyinVs (This is the original version without the Note 3 Logo no Sound) Thanks JaeKar99
Pretty in Pink THIS IS FOR LADIES... THIS IS FOR LADIES... THIS IS FOR LADIES... :) Thanks JaeKar99
SciFiDroid            Thanks JaeKar99
Stargate Thanks JaeKar99
Superman
Supernova Thanks JaeKar99
You are more beautifulTHIS IS FOR LADIES... THIS IS FOR LADIES... THIS IS FOR LADIES... :) Thanks JaeKar99
Hulk-Smash Puny-God (Bonus) +Includes+ an extra Avenger Thanks wally3614
Thor1 Got'em Thanks Preshak
#5 KaChow
KaChow
    If Only...
  • 364 posts
Marvel Avengers Sequence
Pink Floyd Android (Includes On the Run from Darkside of the Moon)
Gimme a break... Gimme a break... Break me off a piece of that KitKat bar.
Android KitKat Side-2-Side Thanks to LGSilva
Android KitKat Rotation in Red (favorite) Thanks to LGSilva
KitKat 4.4 White Android on Black contributed by rob219
2014 Sochi Olympic Winter Games Tribute Bootanimaition
Link to download with Logo         Link to download without Logo
Android Black 4.4 on White
Android KitKat 4.4 Pretty in PinkTHIS IS FOR LADIES... THIS IS FOR LADIES... THIS IS FOR LADIES... :)
Android Black on Red (simple)
Android B&W Flash
#6 KaChow
KaChow
    If Only...
  • 364 posts
Lunar UI Inspired Thanks to MelissaPugs
Orange MIUI Thanks to MelissaPugs
Violet MIUIThanks to MelissaPugs
Blue MIUI Thanks to Melissa Pugs
Green MIUI Thanks to Melissa Pugs
Black on Blue MIUI Thanks to Melissa Pugs
Black on Pink MIUI Thanks to Melissa Pugs
Red on Black MIUI Thanks to Melissa Pugs
White on Black MIUI Thanks to Melissa Pugs
White on Blue MIUI Thanks to Melissa Pugs
White on Plum MIUI Thanks to Melissa Pugs
Black Android on Blue Thanks to Melissa Pugs
Black Android on Pink Thanks to Melissa Pugs
Green Android on Black Thanks to Melissa Pugs
Orange Android on Black Thanks to Melissa Pugs
Purple Android on Black Thanks to Melissa Pugs
Red Android on Black Thanks to Melissa Pugs
White Android on Black Thanks to Melissa Pugs
White Android on Blue Thanks to Melissa Pugs
White Android on Plum Thanks to Melissa Pugs
#7 KaChow
KaChow
    If Only...
  • 364 posts
SlimKat KitKatThanks SlimKat
KitKat 4.4 Thanks Paranoid Android contributed by 117micc
AOKP Thanks Joachim Holler AOKP Contest Winner Contributed by 117micc
AOKP - Kiernan Moore Contributed by 117micc
AOKP Magical Thanks PartimusPrime
AOKP Nekro Thanks PartimusPrime
Cyanogen(mod) Thanks to CM
Nexus L BootAni Thanks PartimusPrime
Nexus F BootAni Thanks PartimusPrime
Nexus X BootAni Thank PartimusPrime
Nexus X-X BootAni Thanks PartimusPrime
Linux Android Bootscreen
Illusion Oreo Flash Mania by KaChow
#8 KaChow
KaChow
    If Only...
  • 364 posts
 Julia Core Thanks to JaeKarr99
Julia Core on Blue Thanks to JaeKarr99
Julia Core Morph Thanks to JaeKarr99
DomoThanks to LumberJack
Android Propaganda Thanks to SimsDelt
The Simpsons (Kanged) Thanks JaeKarr99/KachowPow
                Intermezzo The Simpsons (No KC kanged) KachowPow
 Napoleon is Terminated by KachowPow
Kill Bill blue-screen by KachowPow
Apple Electrocution
Android Takeover II Contributed by j3ffm1II
Android Takeover III Contributed by j3ffm1II
Family Guy- Peter vs. Mr. Washee Washee
Hyperdodecahedron Thanks prepaidguy9081
World War Z
#9 KaChow
KaChow
    If Only...
  • 364 posts
Posted 17 February 2014 - 04:47 PM
Reserved.
#10 KaChow
KaChow
    If Only...
  • 364 posts
How to install and run QMG Bootanimations on ANY Samsung Device.
More than likely when you first bought your device if brand new from the carrier or manufacturer it came stock with the bootsamsung.qmg and bootsamsungloop.qmg pre-installed in the system/media file. After Rooting and Unlocking flashing a bootanimation.zip the bootsamsung.qmg disappeared as it was replaced by the Bootanimation.zip (either Flashed or through a ROM), you may still have the bootsamsungloop file in the system/media folder but it does not serve a purpose. This walk-through will demo how to run these QMG files once again. The purpose of these is they work best on devices that cannot use Flashable bootanimations, such as Verizon and AT&T’s Note 3 which are currently locked. After spending enough time working with these QMG’s I’ve found some very useful benefits of them that far benefit greater than Bootanimation.zips.
In order to get these QMG files to work, you will first need to move or delete the Bootanimation.zip folder from the system/media folder. (See below)
If you are hesitant to deleting this folder I suggest moving it to the audio folder just to preserve and keep it out of the way. Next, pick a bootanimation that you would like to try and download it, then manually extract it and move the QMG files into the system/media folder go ahead change the permissions to RW-R-R-T (I suggest the T as it is Sticky and the bootanimation runs smoother and more consistent, the T is available in the special permissions in Root Explorer.) Also, if it has been a while I also suggest going into the system/media/audio/ui and look for the PowerOn.ogg file I would suggest deleting this file or moving it to the sd card as it is the stock sound file and certainly running the bootsamsung.qmg file, you certainly do not want that interrupt the bootanimation play.
#11 livinginkaos
Posted 17 February 2014 - 05:35 PM
Nice !
#12 KaChow
KaChow
    If Only...
  • 364 posts
Posted 17 February 2014 - 06:02 PM
Nice !
Thanks! Now, that I have some open space I'll add some more. :D  These will look nice on your S4's and Galaxy Tab2. :D
#13 KaChow
KaChow
    If Only...
  • 364 posts
Posted 17 February 2014 - 06:40 PM
I've added to post#10 a walk-through on how to install QMG Bootanimations on ANY Samsung device. :lol:
#14 johnthehillbilly
Posted 17 February 2014 - 07:32 PM
Good stuff bro :)
Tapadriving.... hillbilly style!!!
  • KaChow likes this
#15 jayrod
jayrod
  • 6,525 posts
  • LocationWilmington NC
  • Current Device(s):Taimen
Posted 18 February 2014 - 11:56 AM
Gonna have to check this out later!
Sent from my Platyraptor extreme ultra maxxxx 4gLTE/GSM/ABC/123 Nick Knack Pattywack Ermegherd GED, MD,RNA,DNA,YMCA Edition S4! Via the 4th dimension....NOW RUNNING CARBON
#16 KaChow
KaChow
    If Only...
  • 364 posts
Posted 18 February 2014 - 12:09 PM
Excellent, it'll give me sometime to refresh the links. Apparently, Dropbox killed 45 of my links which I'm right now going through a frenzy trying to upload all those to mediafire, which this is the Shared folder that those links will be located within and all new Bootanimations going forward... https://www.mediafir.../Bootanimations
Here's the 3rd most recent Bootanimation, (hint) haven't seen some of these characters in a long-long-long time (GIF only shows about 1/4-1/3 of them)....
#17 KaChow
KaChow
    If Only...
  • 364 posts
Posted 18 February 2014 - 07:36 PM
Links are fixed... ;)
#18 KaChow
KaChow
    If Only...
  • 364 posts
Posted 28 February 2014 - 11:51 PM
This is the 2nd to the most recent Bootanimation made... Pink Floyd Android which plays On the Run from Darkside of the Moon on bootup.
#19 KaChow
KaChow
    If Only...
  • 364 posts
Posted 05 March 2014 - 07:36 PM
And here is the latest most recent Boot animation happens to be Android KitKat Easter Egg also on display in the OP, currently....
#20 livinginkaos
Posted 05 March 2014 - 07:38 PM
I want to see someone take the moto x animation and right when the vzw is to show have a bomb come in and blow up the planet. Is that doable? Ha ha ha
sent from my One Max, damn it's big
