This is the Rezound Development Section. The only things that should be posted here are ROMs, Kernels and Mods.
If you are posting a ROM, Kernel or Mod, please use the following guidelines to posting!
You need to specify some things in your Topic Title to start with. Let's say you are posting a ROM for the CDMA Rezound, then your Topic Title needs to look something similar to this:
[Rom][Cdma] <Rom Name> <Version#> <Date>
If you notice in the development section, there is already a ROM posted there, you can follow that guideline to see how your Topic Title should look. Kernel posts, should look like this:
[Kernel][Cdma][Ics] <Kernel Name> <Version#> <Date>
Please following these guidelines so that the forums and the threads stay a little more organized and a lot less confusing. Thanks!
[Read] Rezound Development
Guest_BDH_*
, Aug 11 2012 01:30 PM
No replies to this topic
