Fastboot problems
Fastboot Boot image img ADB boot logo failure
3 replies to this topic
#1 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 07 February 2014 - 10:53 PM
I installed a ROM recently that replaced my boot logo image. I went through the usual steps to flash my boot logo. I did the command : Fastboot flash boot boot.img
For some reason it keeps failing and now my phone boots to Fastboot menu automatically because of the failure.
It says: writing 'boot' . . . .
Invalid boot image
FAILED (remote failure)
finished. total time: 0.196s
I tried multiple .img files and none worked.
I recently moved my adb folder to another partition (from c:/ to f:/) and I don't remember if it only worked previously. I know it has worked for me in the past, I'm just not 100% sure if it was on the c or f partition. Either way It's on the f partition now and will not flash boot logo. Any suggestions?
Thank you in advanced.
#2 cmh714
Posted 08 February 2014 - 06:17 AM
boot.img is the boot image not the boot logo. the boot logo is logo.bin usually.
#3 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 08 February 2014 - 08:08 AM
I made my own raw files with photoshop in .img format (logo.img) and that's the way I have always done it. Are you saying I should try "Fastboot flash boot logo.bin ? Even if they are .img files?
#4 Slickademo
Slickademo
  • 380 posts
  • LocationUSA
Posted 08 February 2014 - 08:21 AM
Duh, I feel dumb. the command was fastboot flash logo logo.img I was referring to the wrong tutorial
  • cmh714 likes this
Also tagged with one or more of these keywords: Fastboot, Boot image, img, ADB, boot logo, failure
